08-23-2019, 02:09 PM | #1 |
Rep 33
Non run-flat tyres for 440i Gran Coupe
Hi I'm considering buying a 1 year old 440i Gran Coupe. I found the suspension a bit harsh on the run flats on the car. Is it OK/Safe to change the tyres to non-run flats? (I know the car doesn't have a spare wheel so I would have to buy the BMW gunk kit in case of a puncture). Presumably the change won't affect the handling? Thanks for your help guys.
08-23-2019, 02:37 PM | #2 |
Rep 14,121
Drives: G82 M4C X-Drive
The change will IMPROVE handing. Michelin Pilot Sport 4S is probably the best high performance street tire right now. Get the repair kit. Note that the M cars are run non-runflats and only have a repair kit in the trunk. Have AAA and drive stress free!
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
jmrCRX0.00 |
08-24-2019, 08:11 AM | #3 |
Rep 125
Drives: 2024 BMW 228i Gran Coupe
I drove Porsches (5 different Caymans) for > 10 years and they all had no spare tire. I had AAA, GEICO, Porsche Roadside.......I never worried about it. I did have 3 different ocassions with flats but the Roadside was excellent. My wife drives an Audi A3 with the sport suspension and Pirelli PZeros and no spare tire. I fully expect you should drive your car with equal confidence and enjoy the handling. When my RFs get worn a bit more, I fully intend to take my own advice and go to Michelins or Pirellis non-RFs.
08-24-2019, 08:21 AM | #4 | |
Rep 672
Desertnate391.50 |
08-24-2019, 10:07 AM | #5 |
Rep 10,272
It's difficult if not impossible to make a mistake with Michelin PS4S tires. In cold weather, these tires will lose grip. Any plans for a dedicated winter wheels / tires set?
08-24-2019, 10:37 AM | #6 |
Rep 1,827
+1 on the Michelin PS4Ss. Had them put on about a month and a half ago, they're pretty amazing. I've run Conti Extreme Contact DWs, Michelin A/S3+, and PZero Nero GTs. The MP4Ss feel better in almost every category: ride, handling, and noise (haven't had rain yet, but they're supposed to be great in the wet as well). They are pretty pricy, but about on par, if not cheaper, than replacement runflats.
Also, the BMW Mobility Kit is pretty overpriced imo. I carry one of these in my trunk: https://www.amazon.com/dp/B003RNWOAQ..._UDvyDb4SRG8AB More or less, the same thing for about 1/3 the price. Might pick up a tire plug repair kit as well because I've heard sealants can be a PITA, potentially even ruining the tire and/or TPMS sensor. That said, I've been lucky enough to avoid any flats *knock on wood*. Did get a screw in a tire once, but the screw itself plugged the tire enough to not lose any air before I could take it to the shop for a free patch.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
08-24-2019, 10:59 AM | #7 |
Rep 3,748
I have UHP summers... indy 500, gmax rs, ventus s1 evo3.... cost nearly half... them mpss. Just saying. You will never reach those limit on the street.
08-24-2019, 07:54 PM | #9 |
Rep 268
If you are looking to add a bit of comfort I would recommend you consider going to a slightly larger size. I went from 225/45-18 run-flats to 235/45-18 non run flat all seasons and would recommend it. You can look up using 235/45-18. It is a slight change but it helps a bit and looks completely stock.
08-25-2019, 12:27 AM | #10 |
Rep 2,433
Drives: 2021 M2C
I plan on going to non RFT as soon as I burn up the tires my car was bought with.
08-25-2019, 12:58 AM | #11 |
Rep 503
Every BMW I get I switch to non run-flats as soon as the first set runs wears out. It always makes a huge difference. I normally get Michelin PSS. Recently looked at other types, and the tire shop kind of screwed me over so I ended up with AS/3s. Not really impressed with them unfortunately. Maybe because I came from the PSS, but these feel almost as bad as run flats.
Bottom line, spend a few extra bucks and get a quality, non run-flat tire. It is worth it. |
11-23-2019, 09:34 PM | #12 | |
¯\_(ツ)_/¯
947
Rep 1,762
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC |
11-24-2019, 10:02 AM | #14 |
Rep 2,433
Drives: 2021 M2C
11-24-2019, 01:04 PM | #15 | |
Rep 34
johnung4531.00 |
11-24-2019, 01:38 PM | #17 | |
Rep 5,395
Drives: 2015 BMW 335i x-Drive Auto
You can also take advantage of moving to a different size without spending big money on new sized wheels. My stock runflats were 225/45-18. Kept my stock BMW 400M (18.0" x 8.0") wheels which I like. Got Michelin's in 245/40-18 which is the best handling size. I also could have gone for handling with some extra comfort with 245/45-18. Slightly more sidewall also takes up more wheel/fender gap, making the car appear to have been dropped some. Best flat option that I found was the Slime "8-minute" compressor kit for about $45 at Walmart. Unlike others, Slime is supposed to wipe right out and not damage TPMS. I carry a full spare on trips to avoid any trip disruption. Found a perfect scissor jack and breaker bar with 17mm socket that all fit in underfloor trunk storage area. See photos for details. Hope this helps! |
MmmmmM22591.00 |
11-24-2019, 08:46 PM | #18 |
Rep 2,433
Drives: 2021 M2C
11-24-2019, 10:21 PM | #19 |
Rep 5,395
Michelin PS4S rubber compound is not designed for under 40 degrees F. I did a lot of research looking for my first set of real winter designed tires with winter rubber compound. My area has moderate snow with about 25" and 20 days of driving in snow per season. If there was more snow, I would have chosen Bridgestone Blizzak WS90. I did choose Michelin X-Ice i3. They are quieter and handle a bit better on cold icy wet roads which is what my average winter driving day is like. Anxious to mount them next week as it's getting too freakin cold! Winter sucks!
11-26-2019, 12:19 AM | #20 |
Rep 187
I just put Eagle Exhilarates on my 17 440ix GC. The change from the stock RF Conti SSRs is AMAZING. I live in Chicago and we recently had a few days with snow on the ground. With X-Drive, the tires were grippy enough, but I could definitely still see the benefit of winter tires. As soon as that snow's gone though, even when it's 20 deg (F) they are very stable and predictable. A great common ground. So happy the run-flats are gone!! I went with the Exhilarates specifically because they do a bit better in the cold.
11-26-2019, 06:39 AM | #21 | |
Rep 140
I had to put on a different set for testing because of vibration and odd noise. I have a post on that. We put on a set of the Goodyear Assurance WeatherReady. It isn't a performance tire, but I may just keep them. They aren't all that quiet, either, but the ride is phenomenal (at the expense of some performance, yes). I forgot what a tire that isn't a run-flat or performance tire felt like. Maybe I'm getting old enough to buy a Buick...
Also own: 2012 Z4 35is M Sport Adaptive (Atacama Yellow)
