M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Exhaust flap activation
      08-18-2019, 09:52 AM   #1
Scott Z
Drives: 2023 M4
Does anyone know what’s going on in comfort, sport and sport+?
I had assumed in comfort they remain closed regardless of throttle position.
Sport closed at low throttle position, open at full throttle, closed at highway speeds.
Sport+ open most if not all of the time.
Just finished installing the TechnicPnP (TechnicPnP.com) ASD removal harness this morning. Very happy with the results but now a bit confused on the exhaust flap positions within the different driving modes.
      08-18-2019, 11:08 AM   #2
COChris
COChris's Avatar
Drives: M2C
I think the flap opens in Comfort mode above 4K rpm
      08-21-2019, 03:53 PM   #3
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
More complex than that.
Comfort does open at higher load / rpm.
Sport open from idle then closes about 3k then opens about 3.5k. Closes higher up on light load.
Sport+ open more than sport but not sure exactly.
      08-21-2019, 07:11 PM   #4
tokki
Drives: M2C
Its vacuum/pressure activated so even in Efficient mode, sometimes they can open up under load. Likewise, even in Sport+ mode, if there isn't sufficient vacuum pressure, the valves will stay closed. The modes simply change the threshold to how much pressure is required to actuates the valves opening and closing.
EDIT: I'm wrong on this ^
2019 M2C Sunset Orange 6MT
Eventuri Intakes
Eisenmann Valved Full Exhaust
      08-21-2019, 08:23 PM   #5
Scott Z
Drives: 2023 M4
Don’t think thats entirely correct. At idle and low rpms you can hear the valves open when switching from comfort to sport.
      08-21-2019, 08:36 PM   #6
Dav3
Dav3's Avatar
949
Drives: G87 M2/E89 35is/F21 M140i/GT4
1. Press the power button without pressing the brake pedal
2. Set Sport+ Mode through M buttons on steering wheel
3. Press on the Accelerator half way through at least (car is off)
4. Start the car while pressing the brake pedal
Now your car starts up with valves open
5. Switch the car off and get underneath the rear after it cools down
6. Remove actuator cables on both left and right side
Now your car always has its flaps open
7. Drive for a week or so with this setup and then you will recognize when it is open or not
With ASD bypassed it's much easier because everything you hear is real
///M_ZA175.00
      08-22-2019, 12:17 AM   #7
doughboy
doughboy's Avatar
1545
That's not right I'm afraid.
They are operated by electric stepper motors and controlled directly by the DME.
They only open / close when the DME requests it in accordance with the software mapping.
Even the old vacuum version pre F8x didn't open due to load. Vacuum was provided by avacuum pump and stored in vacuum canisters for use so it didn't run out.
      08-22-2019, 09:23 PM   #8
tokki
Drives: M2C
Ah, perhaps you are right. This is how it was explained to me by the Eisenmann exhaust vendor.
Eventuri Intakes
      08-24-2019, 06:53 AM   #9
cb804
cb804's Avatar
2351
Drives: 340 xDrive, M2C
I'm looking at the Bimmerlink app just so that I can keep the exhaust valves open. Any long term issues with keeping the valves always open? I actually like the sound of the car - just want a little more of it!
If I want the valves open all the time do I have to use the app each time I start the car or is the last setting saved?
m2
