BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis Stretching spring noise when braking
      07-10-2019, 02:12 AM   #1
M5F90
Drives: 2020 BMW M5 Base
Hi everyone,
My first BMW!
2018 540i, 10k miles. When I brake and do not put much pressure to stop the car slowly, there is a string stretching sound coming from the front right before the car stops completely. I can't attach an m4a audio file recorded with my phone, so here's the link to that m4a audio file on my OneDrive:
https://1drv.ms/u/s!Amtebgmy4A9omes2Q8RiqDcC2o_Puw
What's that might be?
      07-10-2019, 08:24 AM   #2
AddyDaddy
AddyDaddy's Avatar
Drives: i5 M60, M5's, 535.335, M550i
Originally Posted by BMW540i View Post
Hi everyone,
My first BMW!
2018 540i, 10k miles. When I brake and do not put much pressure to stop the car slowly, there is a clicking noise in the front like a metal spring "click, click, click, click, click" right before the car stops completely. I can't attach an m4a audio file recorded with my phone, so here's the link to that m4a audio file on my OneDrive:
Just bring it to dealer and take the tech for a ride so he acknowledges it. They are pretty liberal with warranty repairs or complete replacement. I've warped rotors 2 times on previous BMW's and dealer put new pads and rotors both times without questioning.
2013 535i M, Carbon black 20' 6 M wheels, totaled.
2018 750M ,
2013 M5 , Individual Silver, Bolt ons-Straight piped
2019 M550 686BK Black Chrome 20"wheels, filters, Evolve Stage 1, Res delete
2024 i5 M60 Cape York Green
      07-10-2019, 10:21 AM   #3
M5F90
Thank you for reply, but before taking my car to the dealer I wanted to hear opinions from experienced drivers on what that noise might be. Otherwise what's the purpose of the discussion board right?
      07-18-2019, 02:16 AM   #4
M5F90
Visited dealership, the mechanic had no clue about the noise, said that an extended test drive is needed.
      07-20-2019, 11:01 AM   #5
Martin30x
Drives: 540i xdrive
Its uper controll arm. Rubers.. getting mine done. Since I had modified car its no longer under warranty. Each upper controll arm cost 400usd + fitting. Silly price and wheel alignment is needed.
You looze bolts on that controll arm and all noise go away but you cant drive like that. .
      07-22-2019, 02:15 AM   #6
JorgeCastillo
Drives: BMW M2 F87
My 2018 520i 9k miles does the exact same noise when hitting the brakes.
BMW540i Do you have some news on that?
I have to visit my dealer soon...
Greetings from Germany!
      09-16-2020, 04:25 PM   #7
M5F90
Comments section from the invoice:
ROAD TESTED VEHICLE WITH CLIENT VERIFIED LOUD CREAK NOISE COMING FROM RIGHT SIDE OF THE VEHICLE TESTED VEHICLE WITH SHOP FOREMAN (RH) TESTED FOUND NOISE COMING FROM RIGHT FRONT HUB AREA LOUD CREAKING TYPE NOISE REMOVED RIGHT FRONT WHEEL AND REMOVED BRAKING COMPONENTS INCLUDING ROTOR CLEANED ALL MATING SURFACES AND LUBRICATED ALL CONTACT POINTS RETESTED SAME NOISE PRESENT AS PER SHOP FOREMAN REMOVED AND REPLACED FRONT BRAKES COMPLETE AS A SET DUE TO PULLING ISSUE. RETESTED AFTER ROAD TEST NOISE NO LONGER PRESENT
