07-09-2019, 02:50 PM | #1 |
BimmerPost Supporting Vendor
24163
Rep 190,725
Capristo M2 Competition Exhaust w/ Carbon Fiber Tips & Valve Control
The iconic CAPRISTO Valved Exhaust System offers the best of both worlds through its capability to produce an aggressive exhaust note under acceleration, and a more subdued sound for city driving. This feature is possible using vacuum-actuated valve flaps that open and close depending on driving conditions and input from the driver. At lower engine speeds and during cruise operation the valves are closed and produce a deeper exhaust note. At wide-open throttle, the valves open releasing the full symphony of the engine. The exhaust valves are backpressure-controlled and user programmable via the included CES-3 Control Module. The programmable control unit provides 3 modes operated via a remote key fob: Cruise Exhaust valves open at higher RPMs Sport Exhaust valves open at lower RPMs and hard acceleration Open Exhaust Valves Remain Open Both the Cruise and Sport mode can be individually programmed for specific backpressure allowances to determine when the exhaust valves open. This allows precise control of the exhaust based on the drivers personal tastes and tolerance. CAPRISTO Exhaust systems are engineered and manufactured utilizing advanced 3D Laser-Scanning, CAD Design, Digital prototyping, and CNC-bending/milling at our factory in Germany. Each system is made of high-grade T309 (1.4828) Stainless Steel and hand polished to a mirror finish. After extensive research, this specific alloy was chosen for its sonic resonance properties, low weight, and durability which are close to the properties of Inconel (used in F1). IMPORTANT *The exhaust system is designed to be installed directly into existing OEM mounting points*
07-09-2019, 03:18 PM | #2 | |
Rep 1,406
Drives: 2020 SO - M2C
07-09-2019, 07:45 PM | #3 |
24163
Rep 190,725
Someone complained to Youtube about a copyright claim so we had to delete the video.
Capristo do not have it posted on youtube, but you can check it out on their website direct
07-09-2019, 11:21 PM | #4 |
Rep 251
No electric valves though. It uses a remote control system
instagram: https://www.instagram.com/big_fabri/?hl=it
07-10-2019, 12:50 AM | #5 |
Rep 479
Drives: CB E46 and SG E92 M3s
Well thats a diff sound. Crazy loud. I like though.
07-10-2019, 10:33 AM | #7 |
24163
Rep 190,725
In person its a lot different than a straight pipe, but its definitely one of the more aggressive and loud exhaust
