BMW M2 Forum > Regional Forums > UK > Bilstein b6 dampers for f8x
      06-27-2019, 01:56 PM   #1
SIE_M2
Drives: Bmw m2
Complete set of bilstein dampers, covered less than 1500 miles.
Can be paired with eibach/H&R springs.
If paired with eibach a would suggest trimming the rear bump stops
£550
Collection preferred
Staffordshire area
      06-28-2019, 01:25 PM   #2
JayM2
Drives: BMW M2
Hi mate, Interested in these and currently running eibachs... how did you find these dampers compared to standard, did they provide the improvement you were after?
Why do you say the bump stops need trimming if fitted with Eibachs.. Do they effectively raise the car because they are stiffer and made for the standard spring length..??
Cheers, J
      06-28-2019, 01:43 PM   #3
SIE_M2
Drives: Bmw m2
The b6’s are better dampers for sure-significantly better handling. The eibachs on my m2 dropped the rears probably more than the advertised 20mm-probably closer to 25mm which made the ride great on smooth/ok roads. The roads I take to work are semi rural and ride was slightly crashy which was rectified by trimming tears about 10mm.
      06-28-2019, 01:44 PM   #4
SIE_M2
Drives: Bmw m2
Rears not tears
      07-02-2019, 03:58 PM   #5
SIE_M2
Drives: Bmw m2
Bump...these should also fit KW HAS
      07-25-2019, 02:36 AM   #6
SIE_M2
Drives: Bmw m2
Bump £450
      04-22-2020, 06:59 AM   #7
SIE_M2
Drives: Bmw m2
Sold
      04-24-2020, 02:42 AM   #8
Penetrator
Drives: M2 Comp
Glad I didn’t buy these in the end as they don’t work with KW HAS kit as the collars aren’t interchangeable
      04-24-2020, 06:50 AM   #9
SIE_M2
Drives: Bmw m2
So I have recently been told.
Initial info from bilstein rep.
Good luck with the search for dampers/coils
m2
