06-23-2019, 04:04 PM | #1 |
Rep 158
Clear Coat Scratch Repair
My dealership's cosmetic repair tech recently removed a hair-thin, ~10"-long scratch in my clear coat (my body color is Mineral White Metallic, if that matters). He sprayed some kind of solution on a microfiber cloth, wiped over the scratch lightly, and it disappeared in seconds. Does anyone know what that solution might have been, or if there's something similar I could research?
At first, I figured he just removed the dirt from the scratch, making it invisible. But upon closer examination, he actually removed or filled in the scratch, which was previously discernible when running my nail over it. |
06-28-2019, 08:09 PM | #3 |
Rep 127
It’s probably spray wax which didn’t technically remove the scratch, but filled it in. To remove the scratch you’d need to take the clear down either through polish, compound or wet sand depending on scratch depth. Even those magic scratch removers are removing a bit of clear, just without the use of a machine.
If the scratch isn’t that deep this isn’t necessarily bad...you could keep using wax to fill it and provide protection. There are lots of brands out there but I’m partial to Adams polishes or mezerna. Meguiars pro lines are good but hard to find locally. |
12-29-2019, 03:39 PM | #5 | |
Rep 418
Drives: ‘20 X5/M50i (ordered); &
12-29-2019, 07:44 PM | #6 | ||
Rep 158
01-08-2020, 08:33 AM | #7 | |
Rep 418
My guess is he cleaned it off with detail spray or liquid wax. A “scratch” in the clear coat can be buffed out but not with a MF towel and spray. Good news is it’s fixed. |
