M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Oil temp
      06-20-2019, 12:51 AM   #1
Bloodynine
Drives: M2 Competition
Oil temp
Hi all,
I just wondered what your oil temps averaged on a spirited drive and stabilised at.
Thanks,
      06-20-2019, 04:55 AM   #2
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
105-110deg C
The thermostat opens about that temp so that brings in the oil cooler rad and stabilises it a bit.
      06-20-2019, 02:39 PM   #3
chmura
chmura's Avatar
1558
Drives: 2019 M2 Competition
I noticed in comfort the engine runs hotter than in sport + setting.
I am certainly positive sport + enables more cooling than any other modes.
2019 M2 Competition- October 2, 2018 ED
2011 BMW M3 Sedan Alpine White
Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD**
      06-20-2019, 02:59 PM   #4
doughboy
doughboy's Avatar
1545
Never noticed that, I'll have a look next drive out...
      06-21-2019, 07:14 PM   #5
hlm2c
Drives: M2C
Sport+ has enhanced cooling and also keeps the turbos spooled for longer so boost is more easily accessible.
      06-22-2019, 02:18 AM   #6
Bloodynine
Originally Posted by doughboy View Post
105-110deg C
Thanks I’ve got the Fall line oil cooler guard on now and it’s been tuned - just seeing if it’s running a bit hotter.
      06-22-2019, 02:55 AM   #7
doughboy
doughboy's Avatar
1545
Thermostat should keep it steady under normal use. The only time it should climb is high load and or high ambient when the stat is fully open and then it can't add any more cooling.
Oil filter / stat housing is also water cooled too which helps.
      06-22-2019, 08:25 AM   #8
Big Fabri
Big Fabri's Avatar
Italy
95
Drives: Lamborghini Huracan
how is that possible with the cooling
      06-22-2019, 11:54 AM   #9
M2C_PLUS
M2C_PLUS's Avatar
1774
Drives: BMW 1M
2020 BMW M2 Comp  [0.00]
2020 BMW X3M Comp  [0.00]
2011 BMW 1M  [0.00]
Originally Posted by Bloodynine View Post
Hi all,
Thanks,
I have the same set up as you and the oil temp is the same as when she was stock on a spirited drive. Stays around this in MDM mode Sport Plus.
      06-22-2019, 03:00 PM   #10
doughboy
doughboy's Avatar
1545
It will be the same under normal use because that is what thermostats are for....
Yours shows 105deg C, perfect (each mark is 5deg). Thick marks are 70 / 95 / 120 / 145 / 170.
N54 limp mode was 146degC, hit that at Donnington in my old 335i tourer.
Over 100degC is good as that boils off moisture / condensate from the oil which is essential for keeping things in good nick.
      06-22-2019, 04:29 PM   #11
Bloodynine
I drove for a good few hours today and kept an eye on the temp but it never really went above 110
As a side note it’s rapid but controllable - I’ll WhatsApp you my thoughts just wanted to give it a bit of time so I could get a good feel for it!
M2C_PLUS1774.00
      06-23-2019, 01:57 AM   #12
M2C_PLUS
M2C_PLUS's Avatar
1774
Drives: BMW 1M
2011 BMW 1M  [0.00]
Thanks for refreshing my 5 x tables ffs
      06-23-2019, 03:51 AM   #13
doughboy
doughboy's Avatar
1545
Haha sorry it does read like that.. No offense intended
M2C_PLUS1774.00
      06-23-2019, 04:53 AM   #14
M2C_PLUS
M2C_PLUS's Avatar
1774
Drives: BMW 1M
2011 BMW 1M  [0.00]
Only messing mate, none taken.
      06-23-2019, 05:46 AM   #15
vale007
Drives: e82 1 M coupe
at my tuned N54 e82 1 M coupe (FMIC, DPs, ecu flash) i always run into trouble above 120celsius degrees oil temp., hot mode, power reduction. (420hp/680nm)
at the S55 f87n M2 Comp never high oil temps, flashed or not flashed even flat autobahn vmax chasing always approx 100-105degrees celsius. (state 1+, turbo back exhaust which is with 2x100cell highflow cat, no GPF and ecu remap 550hp/750nm at dyno).
but, I was in hotmode once or twice, power reduction. maybe the water temperature was too high? so, where to check the water temp!? the top mounted intercooler (heat exchanger) was at the stock car always really cold, like water condensation in its aluminum surface! with the tune, its warm now, approximately 30 degrees celsius, no condensation drops on it!
do i need to upgrade the water radiator? heat exchanger? or both? is there an upgrade waterpump also? I haven’t found one yet.. what to do?
litchfield offer upgrades(forge, csf), wagner and vsrf also;
https://www.litchfieldmotors.com/bmw...m4-f82-cooling
https://www.wagner-tuningshop.de/pro...0001003-2.html
https://www.wagner-tuningshop.de/pro...0001124-2.html
https://www.vr-speed.com/vrsf-s55-to...0-f82-f87.html
best!
      06-23-2019, 08:05 AM   #16
NEfan508
NEfan508's Avatar
Drives: 2019 M2C
I still get confused with Celsius
I drive slow the first 5 min to get the juices flowing
      06-24-2019, 03:46 PM   #17
Proctor750
Drives: E30 M3
heavyD^23688.50
msdss497.50
      07-04-2019, 07:54 AM   #18
Twt
Twt's Avatar
634
Drives: 2017 M2
CRS Cooler
My factory oil cooler was trashed from track debris, so I upgraded to the CRS unit.....perfect fit and adds volume. After install I noticed a 20+F degree reduction just on the street...haven't tested on track yet.
      07-04-2019, 08:02 AM   #19
doughboy
doughboy's Avatar
1545
The thermostat should keep it at 105degC regardless of cooler size, you need to make sure oil runs above 100degC so that moisture is boiled off and the oil kept in better condition.
tokki203.50
      07-04-2019, 08:32 AM   #20
M2driverWV
Drives: M2
Originally Posted by Twt View Post
I realize space is premium but that's a bad spot for picking up debris into it. Should come factory with protection.
      07-04-2019, 10:46 PM   #21
Twt
Twt's Avatar
634
Drives: 2017 M2
I built my own protection for front coolers:
      07-04-2019, 10:52 PM   #22
Twt
Twt's Avatar
634
Drives: 2017 M2
[attach]2092224[attach]
m2
