BMW 5-Series (G30) Forum Engine, Exhaust, Drivetrain, Tuning Modifications Test
      05-16-2019, 07:53 PM   #1
M62019
Drives: 2013 X3
Test
Test
MoeMo87183.50
clee1982797.50
      05-16-2019, 11:16 PM   #2
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
540, is it?
Remus or AC Schnitzer would be your best bet for the exhaust.
Then H&R lowering spring with some wheel spacers if you are not planning to change the stock wheels.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
SPRING Sale!! 04/01 - 04/15 - Code: "SPRING2024"
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      05-17-2019, 01:22 AM   #3
MoeMo87
Drives: 435xi, M550i
Originally Posted by dips009 View Post
Looking for recommendations on for a louder exhaust and lower springs.
Attachment 2055312
Attachment 2055313
Attachment 2055314
Attachment 2055315
Car looks really good!
Did you paint the rear gloss black? Do you have any pics of the back of your car in sunlight?
What kind of rear spoiler lip is that?
      05-29-2019, 08:01 PM   #4
M62019
Drives: 2013 X3
Originally Posted by r33_RGSport View Post
540, is it?
Thanks!! Found the H&R's which supposedly lower by 1.2" all around.
r33_RGSport12906.00
      05-29-2019, 08:07 PM   #5
M62019
Drives: 2013 X3
Here is the lip spoiler, its the non-M type spoiler:
https://www.amazon.com/NINTE-Painted...omotive&sr=1-6
Brighter pic is attached.
MoeMo87183.50
lago1974166.00
      05-29-2019, 08:46 PM   #6
r33_RGSport
540, is it?
Yeap, I have installed them on 530e and 540.
Gives a good drop.
      05-31-2019, 09:13 PM   #7
M62019
Drives: 2013 X3
Gives a good drop.
Any issues with wheel rubbing or taking it to car washes?
How is the overall ride quality after the drop?
      05-31-2019, 10:21 PM   #8
r33_RGSport
Gives a good drop.
No wheel rubbing.
Drive through carwash though, it would be something you want to avoid with lowered car.
Ride quality is very good.
So far all of them are M Sport suspension. So it may ride differently on non M Sport.
      06-28-2019, 01:44 AM   #9
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
REMUS exhaust sounds the best
https://x-ph.com/sale/
Phone number 702-494-9435
      06-28-2019, 02:43 AM   #10
Martin30x
Drives: 540i xdrive
With armytrix exhaust and its dongle you will a lot problems with car alarm while left dongle in..
3ddesign looks sounds good. Never seen real how it sounds.
All exhausts sound good if delete resonator (grab cat -back).
Buy AC shnitzer lowering springs. (But have them fitted in proper garage beacuse all wheel alignment must be done again).
Next week I will be playing with MHD flasher as they said got switch to drop coolant level to same level as M cars. 106C down to 95C. I D and in sport to 85C.
Car will last much longer.
      07-01-2019, 11:32 AM   #11
Warp Ten
Warp Ten's Avatar
Drives: 2019 BMW 540xi
I recently had installed a BMW M Performance Exhaust on my 540xi. It is definitely louder than stock. There is some drone around 2,000-2,400 rpm under light to moderate throttle that I am surprised BMW allows to exist since it is easy to fix in design. The transmission seems to shift back to that point when changing gears under normal to moderate acceleration. Not sure I am entirely satisfied with it but will live with it for a year and see if I want to go back to stock or get a different exhaust. Saved the original muffler and valance. I enjoy the exhaust on my Z06 because it is adjustable for sound levels and does not drone. --Bob
2019 540xi M Sport, Carbon Black/Cognac, 2014 328xi, 2016 Corvette Z06; Previous:2010 BMW 535xi M Sp, 2008 335xi, 1998 M3 Sedan,1980 528i, 1977 320i, 1976 2002
      07-02-2019, 07:18 AM   #12
aadum
aadum's Avatar
Croatia
80
Drives: 330xd e92 ,520d f10, 540i G30
540, is it?
Remus will not fit his rear diffuser, not sure for acs but probably the same story....
Remus requires 550i rear diffuser as it has huge exhaust tips....
It will fit only if he modifies rear diffuser as 99.9% of e bay stuf will not fit
I had the same issue and had to modify
Springs I would recommend eibach as they are almost same as stock but much lower....H&R are traditionally stiff/harsh.
      07-02-2019, 07:20 AM   #13
aadum
aadum's Avatar
Croatia
80
When you install it can you give an reviewon MHD as I am considering their S1 map too.
      07-12-2019, 06:58 PM   #14
lago1974
lago1974's Avatar
Drives: 2019 540i xDrive
2023 X5 M50i  [8.50]
Hey dips009
My car is very similar to yours and I am considering a rear diffuser. I see yours is gloss black. Do you know what brand it is / where you got it?
Thanks!
