04-24-2019, 03:57 PM | #1 |
Rep 425
major OCD
had a new front tire installed at the dealer today because of some sidewall damage. my beautiful front driver side black 437 came back defiled with this crooked strip of day glow mini-weights on it....... i'm not even going to talk about the amount of tire mounting paste on the rim and sidewall that the tech left for me.
04-24-2019, 05:23 PM | #3 |
Rep 780
If it really bothers you go to a tire place and have them use black weights. Typically BMW don't use those....can't imagine why not.....likely just to annoy over-paying customers like you and me.
"I would rather cry in a BMW than smile on a bicycle." Ma Nuo |
///M TOWN16569.50 |
04-24-2019, 08:45 PM | #4 |
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
Yeah, not sure what is up with the color of those. I'd definitely want black weights. GL!
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
04-25-2019, 10:53 AM | #5 |
Rep 1,718
I have always wondered why they can't put these weights elsewhere on the rim, like more to the inside so they are not as visible. Is there a technical/physical reason? Or is is just laziness/apathy on the part of the tech?
OP- these are particularly horrible, can they at least be painted black? |
04-25-2019, 11:10 AM | #6 | |
Rep 425
get in the zone
particulardude379.00 ///M TOWN16569.50 |
04-25-2019, 01:51 PM | #8 |
Car Guy
38
Rep 115
Better to have all that tire mounting paste all over the rim as opposed to having scratches. As for the weights just mask off and paint the weights. No biggie that is what I do normally.
2018 BMW M2 Long Beach Blue
2022 Lexus IS 350 F Sport |
04-25-2019, 01:55 PM | #9 |
Rep 425
yes
it's actually not a lot of weight....those are relatively tiny....1/4oz? they just look obnoxious. two "regular" sized weights (what I have from the factory on the other three wheels) sized weights would equal that big hideous strip.
04-27-2019, 04:29 PM | #12 |
Rep 2,956
In this day and age dealers and tire shops should stock both silver and black wheel weights especially given the rise of OEM black wheels. This looks horrible and I would take it to a place that has black weights.
04-27-2019, 05:00 PM | #13 | |
Rep 439
2008 SGM 128i - 3 Stage IM - 130i Tune - Dinan Camber Plates - BMW PE - Injen Intake - 1M Mirrors - LCI Blacklines - M4 Spoiler - Blacked 263's - Aero Bumper - Aero Side Skirts - OMGSplitter - AFE Intake Scoops
04-27-2019, 05:23 PM | #14 |
Rep 425
fixed.
i took the wheel off the car today and replaced with 1/2 oz black weights. the horrible day-glow mini-weights the dealer used were only 5 grams each.....hence the 8" long obnoxious strip of them. I feel much better now.
05-30-2019, 05:03 PM | #17 |
Rep 396
That is just wrong on so many levels. Firstly, bad colour choice for the weights. Secondly, that looks like 11x5g weights. The same balance could have been achieved by hiding 1x30g weight behind one of the right spokes (as per the picture orientation) and 1x25g behind one of the left spokes. Third, the weights can be placed further inside the rim – they wheel is balanced radially, not laterally so the assertion that they have to be near the outside edge is untrue. Finally, the tyre should have a small painted dot on it somewhere – this indicates the point of minimum static weight balance (of the tyre only). This dot is normally positioned adjacent to the valve stem since the valve normally corresponds with a heavier spot on the wheel and the two offsets will cancel each other out. However, if a wheel comes up really out of balance like yours seems to be, the tyre can be rotated on the rim before you need to start adding weight. In your case, the paint dot should be opposite (not adjacent) the valve stem. If it isn’t, your tyre tech is incompetent or lazy.
