03-24-2019, 04:02 PM | #1 |
Rep 1,325
What coding for 10.25” screen?
Hi guys,
Fitted a 10.25” from a business nav on my late 2014 vehicle. What coding do I need to do to enable it to work? Currently it’s just blank. Running e sys but may have bimmer code by the end of the week if I can’t get the former working! Cheers |
03-24-2019, 04:37 PM | #2 | |
Rep 565
HU_ENTRYNAV > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 10.25_1280x480 HU_ENTRYNAV > 3001 EXBOX > DISPLAY_VARIANTE = breites_display |
DarenF9.00 |
08-07-2022, 07:47 PM | #4 |
Rep 3
I’m replacing a damaged display. Got hold of a 10.25” as a replacement for the upgraded 8.8” in my 2013 328. Screen is blank and don’t seem to have the option to switch to 10.25” in my BimmerCode app. Any ideas?
08-07-2022, 07:59 PM | #5 | |
Rep 421
Drives: 2017 F31 328dx
CID_Apix_Mode = APIX2 CID_COM_Mode = MMI CID_COLOR_DEPTH = 24bit CID_DISPLAY_RES = 1440_540 CID_DISPLAY_SIZE = 10_25 CID_TOUCH = aktiv CID_HMI_TOUCH = aktiv DISPLAY_VARIANTE = breites_display DISPLAY_SIZE_RESOLUTION = 10.25_1440x540 DIMMUNGSVARIANTE = neue_dimmung |
08-07-2022, 08:50 PM | #6 |
Rep 3
Thanks for the response! Display size is not an option that comes up when I search display (in expert mode) in the head unit. Only display variant.
When I’m in demo mode it shows up but when connected to the car it disappears. Last edited by Dselkins; 08-07-2022 at 09:13 PM.. |
08-08-2022, 12:48 AM | #7 | |
BimmerPost Supporting Vendor
665
Rep 1,978
Drives: 2020 G20 320i M Sport
If you have NBT with the 8.8" screen already, it will work without any coding since both the 8.8" and 10.25" screens use the 1280x480 resolution.
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
shiftdnb376.50 |
08-08-2022, 11:15 AM | #9 |
665
Rep 1,978
If it's a 2013, you're running on CIC so the head unit wouldn't be compatible with the larger display since that would only work on NBT.
shiftdnb376.50 |
12-02-2022, 05:49 AM | #10 |
Rep 1
10.25 screensplit
Hi guys, im new here and could really use some help with the android screen i have retrofitted, i originally hade the 8.8 and i have tried all screen resolutions but nothing have helped. the car is a 328 2013, pretty sure it is hu-entrynav
12-17-2022, 05:56 PM | #11 |
Rep 4,884
For the Android displays, you leave the car coded as 8.8. In the Android factory settings, pick the proper size. If it's a 10.25" screen, then you want the 8.8/10.25" option.
03-08-2024, 10:06 AM | #12 |
Rep 10
Hi
Can someone advise me? I have a BMW2 active tourer F45 year 8.2014 entryNav_Nav. I want to change the display from 8.8 to 10.25. It is possible? Is entryNav the same as NBT? If it is not possible to change the display, is it possible to add some module to get android functions? Thank you for your reply |
03-08-2024, 10:10 AM | #13 | |
Rep 1,325
If you go on Facebook and post in the owners clubs you’ll get better responses. Eg this one for 3 series https://www.facebook.com/share/HR4mH...ibextid=K35XfP Or the general BMW owners page https://www.facebook.com/share/8iHYp...ibextid=K35XfP |
03-08-2024, 10:20 AM | #14 | |
Rep 10
03-08-2024, 10:25 AM | #15 |
Rep 1,325
