03-05-2019, 06:03 AM | #1 |
Rep 7
F30 Door Lock Actuator
https://youtu.be/1tHoVlCFAn0
My driver side door lock started doing this on Saturday. I thought okay no big deal I will take it to the dealership and get it fixed. I get there and I get quoted a bit over $900. I'm not paying that. So I have to keep unlocking my door with the physical key for a few days. Now yesterday this happens. https://youtu.be/qiviOuWwfco Now I know for sure I need a door lock actuator. I ordered the part overnight for $75 and have also ordered the inner door handle that gets sticky since I'm gonna have to take the door panel apart anyways. My question is, am I on the correct path? If so I tried yesterday to take the door panel out but it's actually quite harder then I thought. Any suggestions or videos to how I can safely take this panel out? Any help is appreciated. Thanks! |
03-05-2019, 07:17 AM | #2 | |
Rep 552
Taking the door panel off is quite straight forward. Take of the door handle trim and there are 2 torx screws you need to undo. Then you need to pry it from the bottom edges. Once you can get your fingers under the door card then it's easier to pull off the door card. I have dismantled a door before. It was easy to loosen the actuator but wasn't easy taking it out. You have to remove the window glass and regulator. |
03-05-2019, 07:31 AM | #3 | |
Rep 2,655
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Tune Stage 2 - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI
03-05-2019, 08:55 AM | #4 | |
Rep 7
03-05-2019, 09:34 AM | #5 | ||||
Rep 552
The window switch plugs can be difficult to unplug. The door side impact bar making the actuator difficult to remove. Can't remember how I removed it in the end. I actually have two spare passenger side front door actuators lying around. |
03-05-2019, 02:01 PM | #6 | |
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
The Kies Motorsport Bimmertech Soft Close installation video is a good guide for this work, however they fail to mention that for the driver's door it's very important to remove your key lock/unlock mechanism (key cylinder and shaft that turns the lock on the actuator) from the door before trying to remove the actuator. I ended up breaking that shaft while pulling out my actuator, and it's not sold as a separate piece. |
kingmonkey880.50 |
03-05-2019, 02:44 PM | #7 | |
Rep 7
Okay I see what you are saying. Thanks for the video and heads up on that cylinder and shaft! I will work on the car tomorrow when I receive the actuator. I will update this post with results (hopefully nothing bad lmao). |
03-05-2019, 03:55 PM | #8 |
Rep 16,102
Find a speaker replacement video to see how to remove the door panel. There's a few out there. You'll want to get a set of plastic trim removal wedges.
bavarianride1509.00 |
03-05-2019, 06:13 PM | #9 |
Rep 3,540
Another tip, wet your fingers before touching the adhesive that holds the foam weather/noise panel to the door. That stuff also comes off more cleaning in colder temperatures, versus the additional tackiness and stretch it gets when warm.
10-21-2019, 06:22 PM | #10 |
Rep 1
Sorry to necro an old thread, but I'm having a very similar issue. Sounds a lot like I need a new actuator for the passenger side door in my '15 F30.
My problem is though that I can't get the passenger side door open at all. Exterior handle unlocks and locks other 3 doors, but not the passenger side. Interior handle doesn't unlock door. Central lock doesn't unlock it, key fob doesn't, etc. I went so far as to take off the door panel with the passenger door still closed, but I can't for the life of me figure out how to actually unlock the door so that I can un-bolt the actuator assembly. Any suggestions? Other than taking to the dealership? |
06-22-2022, 03:42 PM | #11 | |
Rep 1
I know this is years late but I too just broke off the key cylinder lortion that feeds into the actuator because the Kies video didnt show it and I saw this too late. Did you just buy a new key cylinder with the 2 keys and portion that extends into the actuator or did you find another solution? Any special way this meeds to be rotated when reassembling to make it work? Actuator seems to work before I reassemble but I cant get the door fully closed ao the car lets me.drive it in the meantime. Frustrating.
Tags |
actuator, door, door not closing, f30, lock, lock stuck, not closing |
