BMW X5
      02-27-2019, 07:58 AM   #1
chuckins9
2021 X5 M50i
Drives: 2021 X5 M50i
M-Sport Brakes Squeaking
I have noticed my m-sport breaks squeak quit often, I contacted my SA and he's telling me its normal.
Anyone else experiencing this, I don't see how this can be normal.
      02-27-2019, 08:05 AM   #2
jra0113
jra0113's Avatar
Drives: 2019 X5 xDrive 50i
No squeak here
2019 BMW X5 xDrive50i
2017 F150 King Ranch
1967 Camaro Pro Touring
      02-27-2019, 08:09 AM   #3
bigdaveindubai
Drives: 2018 540i
When you notice it squeak by chance had you just recently put any kind of shine product on your wheels?
2018 540i
2019 X5 xDrive40i
2012 Boss 302 #2147
2017 Shelby GT350
2017 F250 KR
      02-27-2019, 08:12 AM   #4
Tlon
Drives: 2019 X5
I bedded the brakes when I first got them -- lots of videos on how to do it and discussions on here -- and so far (about 2.5k miles), no squeaking. Maybe try that?
      02-27-2019, 08:12 AM   #5
chuckins9
2021 X5 M50i
No I haven't done anything to the wheels. I live in the northeast, so we have salt and stuff on the roads. But it just seems to happen almost every time I break. It's extremely annoying!
      02-27-2019, 08:14 AM   #6
chuckins9
2021 X5 M50i
I'm at about 2k miles. It seems to have got worse over time. I can try this though.
      02-27-2019, 08:20 AM   #7
bigdaveindubai
Drives: 2018 540i
Good luck my friend. I hope you get it fixed.
2018 540i
2019 X5 xDrive40i
2012 Boss 302 #2147
2017 Shelby GT350
2017 F250 KR
      02-27-2019, 08:35 AM   #8
rmorin1249
rmorin1249's Avatar
817
Drives: 2019 X5 MSport 40i
My experience with MSport brakes is that they do tend to be noisy and VERY dusty. That's why I opted to not order them. Very effective on the track but for normal driving, not needed. You could change the pads to try and make them less noisy.
COL(Ret), US Army Hagerstown MD
2019 X5 40i MSport Alpine White/Coffee (my 13th BMW)
2015 Mercedes SL400; 2009 Lexus RX350
      02-27-2019, 09:12 AM   #9
AndroidRobot
AndroidRobot's Avatar
Drives: 2022 Porsche Boxster GTS
  [0.00]
2022 Porsche Boxste ...  [0.00]
Noisey? I had 16.3k miles on the X3 M40i and the brakes never made a noise. 1800 miles into my X5 and it's quiet as can be. If you properly bed them (I didn't on my X5) they're very quiet. Non-MSport brakes are so tiny even if you don't need the additional stopping power the size alone should be a reason to buy them.
2022 Porsche Boxster GTS Gentian Blue
2023 Porsche Spyder Python Green (on order)
2022 BMW M3 Comp AWD IOMG/Kyalami Orange (SOLD)
2018 BMW M2 Mineral Grey(SOLD)
2019 BMW X5 50i Carbon Black/Tartufo (SOLD)
      02-27-2019, 10:52 AM   #10
magbarn
Drives: '17 540i Msport
Are you driving mostly city without any hard braking on the highway? I've noticed BMW brakes like to squeak if all you do is city driving in the 30-50MPH range from stoplight to stoplight. They like to braked hard occasionally going from 80-0 like you would coming off the autobahn...
G30 540i Msport
G05 X5 xDrive40i Msport
Retired '03 330i, '10 335d
      02-27-2019, 11:46 AM   #11
TechCTU
TechCTU's Avatar
768
Drives: 2024 BMW X5 M60i
Good info. Mine are not squeaking, but I only have about 200 miles.
Should they be bedded or not? If so, when?
      02-27-2019, 01:18 PM   #12
bigrobb2
bigrobb2's Avatar
Drives: 2019 X5 40i
I had an instance where it sounded like I was dragging a banshee down the highway for a few miles. Sound was coming from rear side. Once I jammed on the brakes it went away.
      02-27-2019, 01:22 PM   #13
AdamL
Drives: BMW X5 40i M Sport
My dad has got a 440i m sport and had a similar issue. Dealer told him it was a build up of brake dust which is less likely of you drive the car hard as the dust clears more easily. He has found that giving them a good spray with the hose whilst cleaning the car gets rid of it.
      03-06-2019, 01:24 PM   #14
Influence
Drives: 2020 X3M, 2016 X5 35i
If you check some of the other model forums you'll see that this is a common problem. Apparently, when the rotors rust (not sure if it is dust, as I keep my car really clean and it still happens) a bit, they get noisy and start squealing. The only way to get rid of the rust is with heat. If you are in the Northeast (like me) with our current cold temperatures, there is almost no way to build up enough heat in the brakes to clear the rust, so you are stuck with the squealing until spring. My '17 340i with the Track package and Msport brakes does the same thing. No squealing in the spring/summer, but they start squealing late fall and all winter long.
      03-06-2019, 01:52 PM   #15
mbarrett635
Drives: 2019 X5 40i
Mine don't squeal, nor do I see rust on the rotors. My car sits outside all the time (I'm in snowy cold central PA), and often sits for days at a time. How long a time does yours sit, for rust to develop?
      03-06-2019, 02:24 PM   #16
Influence
My car is driven almost daily (at least 4 times a week for about 60 miles each time). The car is garage kept too. Note that this is only an issue with the MSport brakes (technically the pads themselves). It could be glazing, which also requires heat to get rid of. I don't brake like a maniac, so that could be part of the problem. Fact is, it seems that no one has come up with a concrete reason why this is happening with the MSport (Blue caliper) brakes/pads.
      03-07-2019, 02:35 PM   #17
mbarrett635
Drives: 2019 X5 40i
I have the MSport brakes as well, which is why I mentioned that mine don't make noise. Perhaps you should try a few controlled hard stops to deglaze your pads?
      03-07-2019, 04:10 PM   #18
mnewnam
Drives: '21 Mineral White X5MC
I have the MSport brakes and no squeak or squeal here.
      03-31-2019, 05:01 PM   #19
Denk
Denk's Avatar
1006
Drives: 2021 X5M
It's normal. My Sport brakes on an M240i squeaked a lot, my M40i didn't. Str8 from the horses mouth, some do, some don't and sometimes it just depends.
xbimmers
