02-17-2019, 05:57 AM | #1 |
Rep 1,200
<> RED M2C <>
Featured on BIMMERPOST.com List of mods thus far: Performance: MaximumPSI Crank Hub (Installed by Lang Racing) Wagner Intercooler ESS Charge Pipes Evolution Racewerks J-Pipe VRSF Downpipes AA Midpipe AeroTurbine TR252 Resonators Cerakoted Exhaust by High-Tech Coatings ECUTEK RaceRom(Tuning by Ian@Bend Calibration - Same tuner as my E46 M3 and long time friend) Bend Calibration Ultimate Filter Kit w/ Flex Sensor (sends ethanol content to DME) Upgraded -6AN PTFE Stainless braided fuel line Bridgestone RE-71R Tires (255/35/19 Front, 275/35/19 Rear); Previously 245/265 Cup2's Suspension: TCKline Double Adjustable Coilover Kit with Camber plates 500f/700r H&R Front and Rear Sway Bars Bimmerworld Rear Camber Arm Bearing Kit SPL Front Lower Control Arms SPL Front Tension Rods SPL Front Endlinks SPL Bumpsteer Adjustable Tie Rod Ends SPL Rear Toe Links with Eccentric Lockout SPL Rear Upper Arms SPL Rear Traction Links SPL Rear Swaybar Endlinks Powerflex Diff Bushings (Front and Rear) - Street Durometer Bimmerworld Premium Wheel Studs Aesthetic: Full wrap in 3M Dragon Fire Red, all carbon fiber coated in XPEL Ultimate Clear Glanz Ceramic Coating XPEL XR+ 35% Tint Clearplex Windscreen Protector M Performance 763M Wheels (AutoPro Ceramic Coated with black stems and weights) M Performance Front Lip M Performance Side Skirts M Performance Diffuser Shuttergang Labs CS Style Spoiler Acexxon Slotted Rear Reflector Insert Bimmercode coding (ASD deleted before first startup along with a bunch of other functional improvements) MMR Performance Aluminium Billet Gear Shift Paddle Set First track session at Big Willow back in January (Oil slick previously spread by corvette on Turn 8); This was my last session of the day and sloppy lines but was having a great time with the car. My best sessions were 1:38 with plenty to improve. Took some more photos out at Supercars by the Beach (cars and coffee) and added MMR Shift Paddles. I originally was interested in the Pedal Haus Paddles but these peaked my interest. They're definitely an improvement. I'll keep a lookout for the Pedal Haus ones to compare as I've always been a big fan of their products and will likely get their pedals like I have in my E46 M3. Baseline Dyno - AA Midpipe with Shell 91ACN Fuel in SAE format (Lower than STD, but is preferred format) Some new toys...ECUTEK with tuning by Bend Calibration: Getting the MaxPSI Crank Hub installed at Lang Racing: Some folks have mentioned they don't like to see the muffler hanging below the rear diffuser of the car. Many have used black high temp paint on the muffler. I've gone a different route with same visual result...here is a teaser: Here's the cerakoted muffler from the back side: Without Lightbar: With Lightbar: Here is a video of Racerom Map Switching on Ecutek: Also some revs of non-burble sport+ mode with AA Mid and VRSF DP's: Flex sensor and upgraded Stainless Braided PTFE fuel line installed along with Zeitronix ECA2 Can Bus device which taps into the BMW CAN to send the flex content to the DME for on the fly calculations which is only possible through ECUTEK RaceRom software. I made a huge improvement to the exhaust...added a couple Aero Turbine resonators! Videos don't really do it any justice but it's removed the last bit of rasp that was present and replaced it with a nice snarl and smoother tone. With more miles, the resonators have started breaking in and continue to make it sound better...I might be biased but this is definitely the best S55 twin turbo exhaust note I've ever heard...no more weedwacker rasp. Full setup: VRSF Downpipes, Active Autowerke Midpipe, AeroTurbine TR252 Resonators with OE rear muffler. Took some iPhone driveby videos to try and capture the sound of the exhaust with the resonators: Baby Dragon got to stretch her legs finally...not bad for stock intake. Only mods are exhaust and flex fuel. (May 21, 2020) Got some more goodies in : Most of my suspension parts (Minus Coilovers which are currently waiting for stock to come in from Europe). Well after a bit of wait for Koni to ship their dampers to TCKline (Covid shipping issues), I finally have my front coilovers! TCKline Dual Adjustable fronts and they've been tweaked with love from my suspension guru Dan Law @ DER Motorsports. (E46Forum members probably remember him and he's still doing the same awesome setups; was on the phone with him for hours discussing what my goals were and soon I'll find out how it feels after some miles of dialing it in.) I have the rear D/A setup along with the full line of SPL Parts ready to install and H&R Sways. Likely just putting the Coilovers and Front Sway with endlinks in right now and will do the rest once suspension has settled. Also got this fancy new Injector Dynamics ID750 fuel filter installed with a flex sensor/filter bracket courtesy of Bend Calibration. They are currently the only offering with a high quality fuel filter that exceeds the Bosch required specification for their fuel system components. Hopefully this will avoid potential injector failures or other fuel system problems.
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration 1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder Last edited by Commanderwiggin; 01-12-2022 at 01:10 PM.. |
78
///M Houbi1655.00 JackyStuntin154.50 2PUTT512.50 skiparock182.50 Altra265.50 hellrotm4142.50 philinit23.00 AndrewC198910931.00 CSBM52722.50 808elise378.00 CWads6937.50 specka71.00 termigni1081.00 heavyD^23688.50 CaptChaos54.50 euckersw0.00 jessetaylor1171.00 HODLM363.50 ddk632585.00 ORG52.50 ///M TOWN16543.50 hansomatic-2500.00 JustChris17487.50 dmboone254972.00 02M3ForMe4261.50 HJ478.00 BayAreaBimmers359.50 Red Bread4463.00 Flexray4.50 Jirman4.50 clee1982797.50 Benzima1324.00 Dr.Deep1827.00 Jason40864.50 N54sDUSTxi18.00 ///Cardia299.50 ernests78.50 Killed by Death12464.00 dtmurf481.50 |
02-17-2019, 09:28 AM | #2 |
Former P-Car Owner
272
Rep 237
Looks great, and the 763 look awesome.
2018 BMW M2, Orange wrapped!, Journal
1999 BMW M3, Cosmos Black, S54 swapped |
Commanderwiggin2050.00 |
02-18-2019, 01:14 AM | #3 |
Rep 151
Looks awesome!
02-18-2019, 10:23 AM | #4 |
BimmerPost Supporting Vendor
9587
Rep 10,878
Great choice in mods and color of the wrap!
02-19-2019, 02:53 AM | #5 |
Rep 7,298
If only this car came in Toronto Red, Ferrari Red, or Imola Red from the factory...
9
Commanderwiggin2050.00 CSBM52722.50 HODLM363.50 ///M TOWN16543.50 clee1982797.50 admranger2984.50 antzcrashing1910.00 Killed by Death12464.00 6speed_M23633.50 |
02-19-2019, 03:57 AM | #6 |
Rep 1,200
1000x agreed!
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration 1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder |
02-19-2019, 07:34 AM | #7 |
Doc Brown
1176
Rep 2,174
Looks great!
02-19-2019, 10:46 AM | #8 |
Da Baus
283
Rep 259
Oh my. This is the devil in M2's cloak. Looks great and definitely unique!
M2 LBB/6MT/VFstg2/V1 stealth/JRC valve delete/Dinan/
Fabspeed/Wagner/ER/Eibach/UCP/RTD RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID E46 330ci --> S54 M3 xplant vzv 3bananas (retired) |
02-19-2019, 03:51 PM | #9 |
Rep 307
Wow, that pops!
I generally prefer blue, but this....THIS looks good. REAL good. |
02-19-2019, 04:20 PM | #10 |
Rep 6,926
02-19-2019, 04:22 PM | #11 |
Rep 2,104
Looks fantastic!! BMW, please take notes! If not standard, at least Individual, please!
Commanderwiggin2050.00 admranger2984.50 |
02-20-2019, 08:55 AM | #12 |
Rep 164
This looks amazing. Nice work
02-20-2019, 10:14 AM | #13 |
Rep 2,829
Drives: E36M,E46M,E90M,X5M,i3,M2,i8
Looking good
BMW I12 i8 Frozen Yellow- H&R springs, 22" Radenergie F10 Monoblock Forged /// F87 M2 Aw -Vorsteiner Aero Kit, VFF-107,Macht Schnell-Springs,VF-Engineering/Hex tuning Stage Two,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe/// Wish list :Mexico delivery 2024 BMW M2 (G87) |
02-20-2019, 12:40 PM | #14 |
Blackcoat
23
Rep 46
That looks super dope
02-20-2019, 06:58 PM | #15 |
148
Rep 854
Definitely off to a great start, for sure a head turner!
02-20-2019, 07:19 PM | #16 |
Rep 25
Looks amazing! Can we get some closeups of the spoiler?
02-21-2019, 01:34 AM | #17 |
Rep 39
I think red looks great, should of being a factory colour!
02-21-2019, 09:48 AM | #18 |
Rep 361
Nice! Who is this Shuttergang?
02-21-2019, 10:41 AM | #19 |
Rep 479
Drives: CB E46 and SG E92 M3s
Perfect!
02-21-2019, 01:39 PM | #20 | |
Rep 45
02-21-2019, 08:02 PM | #21 |
Rep 1,200
A UK company, when I was searching for a CS style spoiler they came up and I liked it better than the RKP offering. Shuttergang had great communication, the shipping from UK to USA was super fast, the weave was above expectations and they had a nice air freshener in the box too which ended up in my wife's car and she liked it.
Rock Sweden268.00 |
02-21-2019, 10:07 PM | #22 |
Rep 479
Perfect!
