01-22-2019, 08:58 AM | #1 |
Rep 186
Snow tire change out
Hi guys,
I have never switched out to snow tires in my Jeep so I am new to this theory. Does anyone see any issues with simply changing the all season tires annually with snow tires using the same 20 inch wheels that come with the msport? Also, seems like the consensus favorite for snow tires are continentals??? Thanks |
01-22-2019, 09:48 AM | #2 |
Rep 1,075
Yes. You can mount the winter tire on the same BMW rim that you have your run flats on.
It means dismounting run flats and mounting new winter tires. With road force balancing (recommended) it can be expensive - like $150 dollars each time you do that. Dealer charges even more. Run flats are tough to dismount so there will be some rim nicks. Best is to get inexpensive rims from tire rack and let them mount snows on for you. This way you just bolt new wheels on. Remember to order them with TPMS sensors. After bolting on - reset tire pressure monitor and you are all set. Remember if you have M brakes - only 20" wheels will fit Not many Run flat options for snows, so most people get regular snow tires and carry a kit to plug/repair. As to what kind of snow tire you need - depends on where you go in NE. I'm in Boston as well and drive to NH/Vermont - 6-10 times a season to ski, etc. So for me it is more important to have the snow tire that can handle the cold/wet roads and feel like a regular performance tire vs pure snow traction and digging in deep snow cover. So I prefer Michelin Pilot Alpine SUV 5 - you will not know you have snows on - they drive as well as any performance tire and are V rated. On the other end of spectrum is Nokian Hakkapelita - studded/ or non studded tire. Great in deep snow and ice ( i drove on them in Russia). Most of my friends in Vermont have those. It is good for packed snow, but on regular pavement you will feel it and the car will not handle the same (noise, spinning wheels, poor cornering etc) |
FiatLux11.50 |
01-22-2019, 10:03 AM | #3 | |
Rep 186
FiatLux11.50 |
01-22-2019, 10:59 AM | #4 |
Rep 106
+1 for the Nokians, but they're tough to find someone who has them in stock.
Currently run them on my RR Evoque and intend to get a set of winter rims / Hakka's for the X5 ) |
01-22-2019, 11:40 AM | #5 | ||
Rep 579
FiatLux11.50 |
01-22-2019, 12:56 PM | #6 | |
Rep 5,448
01-22-2019, 01:05 PM | #7 | ||
Rep 579
01-22-2019, 03:57 PM | #8 | |
Rep 1,075
20s should fit in trunk with folded seats. Might meed to stand one diagonally. I'm storing them in my sub. |
FiatLux11.50 |
