BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    Rear Differential Warning
      01-14-2019, 03:23 AM   #1
BURAKUSTA
Turkey
126
Drives: 2011 E92 M3 COUPE
Translates into drive carefully because rear slip differential has limited performance abilities. This occurs the moment i start up the car, anyone had seen this before ?
      01-14-2019, 04:48 PM   #2
turbomcgee
Drives: 2018 M5
I had this one day error one day after start up, ended up being low battery voltage. They replaced the battery and its never come back.
      11-06-2019, 12:39 AM   #3
hugogu
Drives: BMW M3 2008 DCT
Hi, I have put 7,500 miles on mine, for the first 7,000 I had no issue at all. I unfortunately scraped the side skirt and had to get that fixed. After I got the car back (took 6 weeks) it started to behave badly ...
Goes into park after start/stop at light. Getting warnings about all assist systems, screens black out, rear diff locks up wheels under downshift (happen twice now), and I can reliably reproduce the problem now.
I do think it's linked to heat (been cold here lately ... 15-20C), all other times I have been driving in warm weather (25-45C).
It kind of alternate giving me rear diff warning, driver aid systems (8 different warnings, always comes at the same time), loss of maps/navigation (apple car play still work though), and engine shutting down 'randomly' going up hill.
Every time a 'reset' (turn off the car, lock it, and start it again) reset and problem is gone (for a bit).
BMW reprogrammed the car, but problem did not go away, next I will take it in and have them replace the battery (based on the other suggestion here).
I do not think there is any 'real' issue, and given 7,000 problem free miles I do not think there is any 'bad' HW/SW ... They did see a low voltage warning as well.
Let me also know if you get the problem fixed ... losing power / engine / gear in a curve going uphill is ... problematic ... and locking up me rear wheels in a steep curve (on-ramp) was also brown-trouser-time.
      11-07-2019, 09:51 AM   #4
Drm5
Puerto Rico
30
Drives: F10 M5 sakhir orange
check battery ... after 6 wks it might be low
m5post
