BMW 5-Series (G30) Forum DIY Discussions / Guides / Instructions Inner door panel removal
      12-15-2018, 11:25 PM   #1
tbcrain
Drives: 2018 BMW 530e - jet blk
I was able to remove the door panel without any trouble. I was expecting to see the normal foam insulation, but instead found a hard plastic shell behind a fiber insulation. Anyone know how to remove the hard plastic panel to get to the wires in the door handle?
      12-16-2018, 11:17 AM   #2
Dobie Dog
Dobie Dog's Avatar
Drives: 2021 F97 X3M Comp
Post #6 in the thread below should help you. Fast forward about 10 minutes in.
https://g30.bimmerpost.com/forums/sh....php?t=1485900
Life is short...Drive fast
      12-16-2018, 07:05 PM   #3
tbcrain
Thanks Dobie Dog. I didn't see anything in that video that will help me. I was able to get the panel off the door. What I need to do is remove the plastic panel in the picture above that is behind the insulation. I removed the 6 screws and loosened all the large white fasteners. That loosened it some but it was still attached in some areas. I was afraid to force it. I need to get to the wiring behind that panel.
      03-25-2020, 11:21 PM   #4
jpt99
2024 m340i, 2022 X5 M50i, 2019 m550i
Drives: 2022 X5 M50i, 2019 m550i
Any luck? I’m in the same boat.
      03-26-2020, 10:46 AM   #5
roxxor
roxxor's Avatar
1118
Drives: 2024 iX50
Steps to remove it are shown in the door disassembly instructions on the below link:
https://www.newtis.info/tisv2/a/en/g...ont/1VnZ3URBXu
