E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > 2011 N55 E93 VSRF Catless DP
      12-15-2018, 02:51 PM   #1
nate93
Drives: 2011 E93
I am getting fixed to receive my VSRF catless DP.
I have 4 questions.
1) How bad was the smell with this downpipes installed it’s because I have an E93, that’s convertible?
2) Installing catless DP, will that affect MPG and trigger the DME to run rich?
3) The downpipes fix from VSRF, do you know if that just suppresses the CEL light or it actually alters the signal going into the DME?
4) For the DP fix from VSRF Is there an connector that I can get so I can plug and play and won't have to splice any cable?
      12-15-2018, 02:56 PM   #2
MTK24
MTK24's Avatar
Drives: 2011 335I X Drive
I actually like the smell after having downpipes installed. The smell is not that noticeable and bad.
It improved my MPG, and you can hear the turbo spooling a lot faster and louder. Also helped with a little turbo lag when not in drive sport
I can't comment on the DP fix since I flashed with MHD to remove the code
Vermillion Red
      12-15-2018, 04:02 PM   #3
Divbetic
Drives: 2011 135i
I also like the smell after installing the DP, especially after adding a couple gallons of e85. As far as the fix goes, it should be altering the signal before the DME so the car believes a cat is present. As it stands right now there isn't a plug and play version unless you make your own. For pigtails, I purchased a 2011 n55 o2 sensor and n55 harness used at a local junkyard for pretty cheap.
2011 135i 6MT
PS2 | Fuel-It PI | MHD
      12-15-2018, 04:21 PM   #4
Inkmerchant
Drives: 2012 335i N55/ 2006 330i N52
VRSF DP review
- When at a stop light or backing up from a garage the smell is definitely there. From a 1-5 rating (5 being unbearable) I'd rate the smell at a 2.
- The DP's alone didn't affect MPG. Unless you end up flooring it more since the sound is more intoxicating.
- VRSF DP fix I believe alters the DME, I'd recommend spending your money on MHD or JB4 instead that way you don't get a CEL and you take full advantage of the DP.
- Not that i know of, just grab a tune and be done with it.
      12-15-2018, 04:23 PM   #5
nate93
Drives: 2011 E93
Yes, I am interested in learning to make the connector myself. Do you have any instructions of which connectors to get and diagrams of the cables? I am an electrical engineer. So once I see it, it won't be hard.
      12-15-2018, 04:26 PM   #6
nate93
Drives: 2011 E93
Thank you for your response.
But those flashes or tune (JB4 or MHD) will only suppress the CEL only though, it wouldn't allow me to pass emission, right?
But I might as well get them though. I need to get a FMIC before I tune my car though.
      12-15-2018, 06:05 PM   #7
Inkmerchant
Correct, both performance tunes will only suppress/delete the CEL. For emissions on the other hand I wouldn't fully trust the DP fix. I've read on some others forums that even though the DP fix deletes the CEL it's still a hit or miss when getting your smog done. Best if you know someone that'll pass you without cat's or get used to installing and uninstalling your DP yourself. N55's are much easier to work with than the N54's since its only one pipe instead of two.
      12-16-2018, 01:15 AM   #8
scrllock
Drives: 2011 E90
I have 4 questions.
The smell isn't that bad, but I can't drive with the windows down without getting a headache and feeling ill. Some people are just more sensitive to it, personally I'm switching to HFCs to see if it helps enough.
      12-16-2018, 02:14 AM   #9
Hannibal4444
Drives: N55--E93 6MT
@nate93
Wiring diagram for 02 sensors press (I) top left to see legend of wiring diagram
https://www.newtis.info/tisv2/a/en/e...ntrol/CkQHyyQ2
This Pic helps too
      12-16-2018, 06:08 PM   #10
BKBMW335I
Drives: '11 E93 335I
I have 4 questions.
1. I haven't noticed a smell, I have an E93 also.
2. I haven't had a problem with running rich, running lean has been more of a thing.
3. I actually had someone else take care of mine by just disconnecting the wiring itself there so no code comes up at all.
4. Sorry see #3
Mods: MHD Stg 2, xHP Flashtool Stage 3, VRSF 3" Chargepipe, Megan 4" Downpipes, Pure N55 Inlet, Outlet, VSRF 5" Stepped Intercooler, GFB Diverter, BMS N55 Intake, Michelin Pilot Super Sport Tires, BMS Sport Oil Cooler Valve, CF Spoiler, CF Kidney Grille, CF Mirror Covers, CF Eyelids, CF Wheel Hub Covers, CF Diffuser, M Sport Racing Strip, 20% Tints, and Golf Tee Mod
      12-16-2018, 07:58 PM   #11
nate93
Drives: 2011 E93
Thank you all! You guys are amazing
      12-16-2018, 11:20 PM   #12
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
Thanks for the input folks, we appreciate it!
      12-19-2018, 03:12 PM   #13
alddiem415
Drives: 2011 335i xdrive
Im dealing with vrsf dp fix right now.. i think you should get ****** catsim..
Im returning the vrsf dp fix that i bought from Tiago
      12-19-2018, 09:43 PM   #14
nate93
Drives: 2011 E93
Why? I haven't bought it yet, I was thinking about getting one. Can you please elaborate? Have you spliced your cables?
e90post
