E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Meth Kits AEM vs Snow with MHD
      12-06-2018, 09:24 AM   #1
NRigs
Drives: 2011 BMW 335xi
Does anyone have either of these kits with the controller with MHD? What percent mixture water and meth are you using? Do you have a custom tune or are you using an OTS map?
Any info helps. Thanks!
Current: 2011 BMW 335xi | Wedge Tuned | Meth | VRSF DP | VRSF 5" Intercooler | VRSF Chargepipe | BMS Intake | xHP Stg 3
Totaled:2014 Audi A4 CTS K04 APR Tuned
      12-18-2018, 12:56 PM   #2
NRigs
Anyone?
      12-18-2018, 01:33 PM   #3
Pladi
Pladi's Avatar
Drives: 2011 335i xdrive
MHD has nothing to do with controlling your METH kit. Although i dont have a meth kit installed on my BMW i did on my mazdaspeed. Aquamist one.
The meth controller will adjust that amount mased on ur boost/MAP sensor or MAF, as well as for direct injected PWM of injector. Those are some of the popular modes.
So as long as you spray in conjunction with one of those parameters or a combination of 2 you should be good. This control is done from the meth controller. It reads ur DME info. ( Case of aquamist controller)
You can than tune with this but the tune does not "control the meth". It will work together with it.
Idk if i was clear enough.
      12-18-2018, 02:30 PM   #4
NRigs
Yes, that is clear. Thank you for the info. I am interested to see if anyone is using these two particular kits though. To be more specific; connected to just one nozzle through the charge pipe and which nozzle size are people using, are people using an OTS MHD map or custom map, and what mixture of water meth is being used. Is 50/50 the best and safest that is geared towards both power and cooling?
      12-18-2018, 05:24 PM   #5
Turbod
Turbod's Avatar
Drives: 2014 E84 X1 35i M Sport
I had the AEM controller with the BMS Cooling Mist kit while running MHD. I didn't tune the car differently with methanol but also think I may have had an issue with the flow since I didn't see as much benefit as when I was running the FSB on the JB4. At the time I was running about 50/50 mix.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      12-18-2018, 09:16 PM   #6
Pladi
Pladi's Avatar
Ant speak for specific kits and nozzles. But the biggest benefit of running these kits is to advance timing. That gives u torque. Thats why meth kits are so popular with diesel cars. Meth and water are soo good at supressing knock. You have to have a custom tune to take advantage of this supression.
e90post
