E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Losing Coolant Quick
      11-27-2018, 04:25 PM   #1
DYOOS
DYOOS's Avatar
Drives: 335i E90 N55
Hey Guys I've been losing coolant pretty quickly and it's really worrying me. I have to fill up about 33 oz every 5 to 7 weeks. I've had a couple of mechanics check it out, but they can't seem to find where I'm leaking. They're not BMW specialists, but mechanics nonetheless. I'll be taking it to a BMW specialist shop soon, but wanted to see if anyone has experienced coolant loss and how you've resolved it.
IG: @dyoos335i
      11-27-2018, 06:20 PM   #2
redwildcat17
redwildcat17's Avatar
31
Drives: 2011 e90 335i xdrive m sport
Following
      11-27-2018, 07:50 PM   #3
Welcome to NBA Jam
Is it the shoes!?
Welcome to NBA Jam's Avatar
3884
Drives: (Sold) 2011 E92 335i ZMP 6MT
Did they do a pressure test? When was your OFHG done last?
      11-27-2018, 08:12 PM   #4
DYOOS
DYOOS's Avatar
No pressure test. They just did a check with their eyes I believe.
I replaced my OFHG some 2k miles ago so really recent. I'm not getting any overheating, but I do get the error where my coolant is low.
IG: @dyoos335i
      11-27-2018, 08:46 PM   #5
rich_mane
rich_mane's Avatar
139
Drives: 2011 E92 335i
A pressure test would definitely be the best thing to do.
The expansion tank is known to fail. I've replaced mine, it was leaking through the seams connecting the top and bottom half. Replaced my radiator as well after a crack formed near the upper rad hose.
DYOOS88.00
      11-27-2018, 10:05 PM   #6
DYOOS
DYOOS's Avatar
This is what I've been thinking as well. Will need to tell this to the BMW shop I'm going to this week.
IG: @dyoos335i
      11-28-2018, 12:29 AM   #7
Azines
Drives: 2012 E92 335i Xdrive
I second the expansion tank, I was adding coolant every other day for a week before I noticed the seal on my expansion tank broke, and was leaking when the engine reached operation temps. It's a simple DIY and the tank can be found relatively cheap.
      11-28-2018, 02:56 AM   #8
juld0zer
Australia
480
Drives: Prev 135i 7DCT, Now 130i 6sp
Expansion tank seam split
Expansion tank cap failing to hold pressure
Crossover plastic pipe above the radiator. Brittle and breaks when disturbed
Any rubber hoses swollen due to motor oil contamination
Radiator end tanks
Turbo coolant lines orings
Oil filter housing not repaired properly (bolts not tight enough, damaged or shoddy gasket)
Coolant pump
Loss internally via cylinders
Heater core
Usually it is one of the first half or a few of them
Pladi718.00
DYOOS88.00
NRigs94.00
      11-29-2018, 08:16 AM   #9
NRigs
Drives: 2011 BMW 335xi
I was first leaking coolant from my expansion tank. You can easily see the leaks from there as the seams were split and there was liquid everywhere. Expansion tank is an easy DIY also. A month later my radiator was leaking. I found it was leaking from there by adding UV dye to my coolant and using a black light to see where it was leaking from. After the shop replaced my radiator I have not leaked anymore coolant. I did have to top off my coolant a couple times after the radiator replacement but everything has been perfect since.
Current: 2011 BMW 335xi | Wedge Tuned | Meth | VRSF DP | VRSF 5" Intercooler | VRSF Chargepipe | BMS Intake | xHP Stg 3
Totaled:2014 Audi A4 CTS K04 APR Tuned
      12-13-2018, 09:27 PM   #10
Herakles
Drives: United States
I finally found my leak- noticed coolant coming from the seam between top expansion tank cap and side - ordered new tank for 57 and coolant - bother under 100- will do it
Myself - probably a 500 Jon at bmw ...
2011 335 Msport Xdrive
Space grey
purchased on 8/7/15
      12-14-2018, 08:35 AM   #11
NRigs
I would order a new cap as well.
      12-14-2018, 10:14 AM   #12
Zygote55
Drives: 2011 135i DCT
Can you provide a link or part numbers?
      12-14-2018, 06:28 PM   #13
lucasmiller2015
Drives: 2020 M340i
2011 BMW 335i  [0.00]
Tank: 17137640515
Cap: 17117639020
Coolant: 82141467704
2020 M340i | Mineral Grey Metallic | Premium | Exec | Adaptive M Suspension | Harmon/Kardon
Previous: 2011 E90 335i | Black Sapphire Metallic | 2007 E90 335i | Monaco Blue Metallic
      12-15-2018, 02:33 PM   #14
Herakles
Just did my expansion tank today !! Do happy
Space grey
purchased on 8/7/15
      12-18-2018, 10:18 AM   #15
Zygote55
Originally Posted by lucasmiller2015 View Post
Tank: 17137640515
Cap: 17117639020
Thank you!
      03-12-2019, 05:32 PM   #16
dyrus587
Drives: e90 335i
i've been experiencing a heavy amount of coolant loss as well. 07 335i
i have to refill half the reservoir tank every 1.5 weeks but there are only 2-3 drops where i park which does not add up to that amount of leakage
any opinions?
      03-13-2019, 02:11 AM   #17
TheGoodTheBadTheUgly
Drives: 2011 E90 335i xDrive
any opinions?
Did you try to check the plastic under belly to see if the coolant leaks there and evaporates? Try giving a quick look arround the frame of the expansion tank and see if you can spit the marks or pattern left by the coolant leaking its way down to the ground.
      03-24-2019, 03:29 PM   #18
Azines
any opinions?
I had the same issue, had to add coolant every 10 days, there was no sign of leaks. Had the car taken to my mechanic and after running the car, they found out the radiator was slowly leaking and evaporating over time. Had to get the radiator replaced. BEHR unit for about $200. No problems since.
      06-13-2019, 11:54 PM   #19
DYOOS
DYOOS's Avatar
Closing the loop here. Got a new coolant tank installed and fixed the issue.
IG: @dyoos335i
e90post
