Do I need an upgraded N55 fuel pump? If so, which one?
11-05-2018, 04:03 PM | #1 |
Rep 849
Hey guys. I have a 2013 E92 FBO 6MT 335i.
Do I need an upgraded fuel pump? I like to run map 5 with about 4 gallons of e85, but i've noticed the car doesn't like more e85. Will a fuel pump help? Will it consume a lot more gas under normal driving? Will the pump itself be a lot louder?
Current: 2016 F82 DCT M4 FBO Daily.
11-05-2018, 05:16 PM | #2 | |
Rep 1,210
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD 2019 Audi TT RS | 10.5@130 SOLD 2020 F97 X3M | 11.0@123 2023 G80 M3 xDrive |
11-05-2018, 09:14 PM | #3 |
Rep 129
Yup, for late E92's the HPFP has limited flow due to design changes between the early and later builds. My rail pressure crashes under higher boost levels or too aggressive onset. The OP's comments ^^ are spot on.
11-05-2018, 11:06 PM | #4 |
Rep 849
I see that a few companies have created HPFP for f30's...
Nothing for e92 or is port injection my only solution? I heard port injection is "unsafe." Is that true? Low pressure fuel pump wouldn't provide "upgrade" of any sort?
11-06-2018, 12:38 AM | #6 |
Rep 754
I have the same hpfp as you, the lpfp upgrade won't help anything. Our hpfp is maxed out around e30 with good boost/timing paired together. The cheapest option is Fuel-it!'s new chargepipe injection which replaces the TBI that they previously sold. If you don't want to end up paying 2k+ for TTFS upgrade then you'll need port injection which can be unsafe in certain situations. Fueling imo is the biggest issue on the N55 platform
2006 Z4 M Roadster Black/Imola Red, FBO VF-Engineering, e85 Flex Fuel-Sold
2012 BMW 135i N55 DCT Alpine White/Coral Red, FBO, TBI, Full e85, JB4 BEF-Sold 2006 Z4 M Roadster Black/Black-Sold 2021 M2 Competition DCT Hockenheim Silver |
11-06-2018, 06:40 AM | #7 | |
Rep 291
11-06-2018, 09:07 AM | #8 | ||
Rep 754
E92TiAg335i216.00 |
11-06-2018, 09:32 AM | #9 |
Rep 291
Ah I see. I thought you also get a port injector controller or some way of controlling the injectors. That too doesn't turn off the injector when DME cuts fuel or such a control is not possible?
11-06-2018, 09:38 AM | #10 | |
Rep 754
Ex: https://bmw.***********.com/threads/...-failure.2166/
E92TiAg335i216.00 |
11-06-2018, 11:45 PM | #11 | ||
Rep 849
I daily my car and need it for work. No car= me getting fired due to pissed off clients... So i'm basically done with any mods then as i'm FBO already
11-06-2018, 11:46 PM | #12 | |||
Rep 754
11-07-2018, 02:37 PM | #13 |
Rep 1,210
I would buy a methanol kit and run chargepipe methanol injection and use E20 or E30 in the tank. You will be turbo limited but this will allow you to max out the stock unit if you want.
12-03-2018, 07:01 PM | #15 |
Rep 1,163
THIS^^^^
2011 335i X-drive 6AT / Pure turbo / 500AWHP/526TQ
12-07-2018, 07:41 AM | #16 |
Rep 149
Is it common for these N55 HPFPs to go out? I'm FBO, JB4 and MHD BEF and I have fuel cuts now that the weather has got colder (Higher Boost). Or could it just be that the pump is old and worn out? Got about 66k on the car, not driven much the last 5 years.
2011 335I, E90, AT, Sport Package, FBO, Eibach 1" Lowering Kit w/ Koni Orange. MHD, 88k miles 2nd owner - Sold
2003 330XI, MT, bone stock, 160k miles - Sold 1988 325I Coupe, MT - Retired, 280k miles - Sold 2019 X7 XDRIVE 40I - Wife's |
12-07-2018, 08:18 AM | #17 | |
Rep 127
12-07-2018, 09:09 AM | #18 |
Rep 149
I've just had bad misses/fuel cuts recently, re-gapped plugs to .021" to try to help mitigate the issues with no avail. Wondering what else it could be.
12-07-2018, 09:17 AM | #19 | |
Rep 3,189
12-07-2018, 09:34 AM | #20 |
Rep 149
Fuel cuts, I put it in sport mode, turn traction and DSC off, take off from a roll, like 50 mph and it down shifts then I feel it cutting out rapidly through the pull. I know what it feels like when it cuts fuel due to loss of traction, that sucks too, but its usually just one cut. This is like repetitive cuts.
12-07-2018, 09:47 AM | #21 | |
Rep 127
12-07-2018, 12:52 PM | #22 | |
Rep 255
