11-02-2018, 07:10 PM | #1 |
Rep 4,532
Flow Bench Tested the F90 secondary Cat.
BIG THANKS to Miko M for sending me his catalytic converter ! Test would not happen without him.
Factory secondary cat flows 542cfm at 28" H20 For reference, an open 2.50" pipe flows 515cfm. An open 3" pipe maxes my bench at 702cfm. |
11-02-2018, 09:05 PM | #6 |
///M
6652
Rep 3,683
Knowing that 3" flows at about 30% more, is there a way to calculate the amount of gain you get as far as TQ/HP?
Life is too short...enjoy your life
///M |
11-02-2018, 09:44 PM | #7 | |
Rep 4,532
For example. Applying Flowbench numbers of the 2017 ZO6 cats to the chart will forecast a 35ish HP gain by eliminating all four catalytic converters on the 650HP stock engine. But, you remove them and a Dynojet will show around an 18hp gain at the rear tires. Converted back to engine hp to compare will be around 21hp vs the 35 chart hp. Cats are not good for power production,,,period...but a lot of variables go into hp gains by removing them. Turbos will spool quicker, but peak boost is DME controlled. Backpressure is reduced,,,always a good thing,, |
11-03-2018, 07:19 AM | #8 |
///M
6652
Rep 3,683
I could hear turbo spool as soon as I replace the lower down pipes ( upper still EOM ) and I noticed it's little more responsive too, at start throttle.
Thanks for taking the time and posting this!!
///M |
M 4EVER191.00 |
11-03-2018, 08:23 AM | #9 |
Rep 4,532
As soon as a drop in air filter becomes available, I’ll remove the entire air filter assembly and see if it has any restrictions. Green is looking at making me a custom panel drop in.
If anyone has a primary catalytic converter, let me know. Would like to flow it also. |
11-03-2018, 07:50 PM | #10 |
Rep 175
Heres a pic of an Eisenmann lower downpipe vs a stock downpipe. At this kind of cost for these, does it make sense to get a muffler shop to punch out the cats?
01-21-2019, 11:31 AM | #13 |
Rep 89
Most muffler shops charge $300.00 to delete a resonator on a Honda Accord and then replace it with a piece of pipe with welds looking like potatoes. Our pipes are 3D scanned and 3D modeled for 100% direct fit, hours of r&d on a development car, TIG welded by certified welders for art like welds and perfect flow, used highest grade 310 and 304 stainless steel, mandrel bent, cnc flanged, using high durability flex pipes.
FSociety3812.50 |
01-21-2019, 03:00 PM | #14 | |
Rep 18,686
The material doesn't cost more than $10. :
01-21-2019, 03:33 PM | #15 | |
Rep 66
Punitive147.00 |
01-22-2019, 11:26 PM | #16 |
Joint Chiefs of Staff
24095
Rep 190,633
Thank you for taking the time to do these tests OP
onfireX53617.50 |
01-23-2019, 07:52 AM | #17 | ||
24k GOLD
148
Rep 1,453
02-09-2019, 07:51 PM | #18 | |
Rep 87
Reading between the lines the F90 secondary cats don't seem to be a real factor when it comes to making more power but as with any turbo car removing some flow restriction behind the turbo should help spool / response. |
02-10-2019, 08:25 AM | #19 | ||
///M
6652
Rep 3,683
I agree, its really helpful understanding the difference/gains you are getting by changing to aftermarket parts
///M |
M 4EVER191.00 |
08-04-2019, 10:57 PM | #20 |
IG @bmwF9xG80
3813
Rep 7,592
Thanks for this Miko M and onfireX5
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
08-06-2019, 06:17 PM | #21 |
Rep 292
I haven't been here for long time. Like to see what's new.
Both of them did awesome job giving us results on down pipes and air filter. This is what everyone likes to see here is another test. https://www.bimmerpost.com/forums/sh...php?p=24236012 |
bm3tuning70.00 |
