10-30-2018, 06:21 PM | #1 |
Rep 303
Wheel Locks for Wheel Spacers?
So I’ve got a 2019 M550i on order, optioned with 20" 668M wheels and MPSS non run-flats. I’m thinking I’ll run wheel spacers; probably the 15F/20R setup that seems to be popular on this (super informative) forum.
Are extended wheel locks available to use with spacers? Does anyone have a good source?...Thanks. |
10-30-2018, 11:52 PM | #2 | |
Rep 18,685
Others are selling the non regular Hex Head lug bolts, but not a proper wheel locks.
10-31-2018, 03:20 PM | #3 |
Rep 5,140
McGard (the OEM supplier to BMW) has alot of different lengts.
For wheel bolt size M14x1.25 the following part numbers are availible: 27226, 27mm (w/o spacers) 27229, 32mm (5mm spacers) 27230, 37mm (10mm spacers) 27244, 42mm (15mm spacers) 27231, 47mm (20mm spacers) mcgard.de You might use the longer 27231 47mm for both front and rear, but check carefully for clearance if you use the longer wheel locks with 15mm spacers up front. |
ellisina4239.00 |
10-31-2018, 03:56 PM | #4 | |
Rep 18,685
10-31-2018, 08:07 PM | #6 | |
Rep 303
