E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Coolant in oil?
      10-30-2018, 05:11 PM   #1
lwgrenier
Drives: 2011 e92 335i XDrive
Coolant in oil?
It looks like oil has been spraying or leaking from the oil cap at the front of my engine. No codes, car runs fine. I pulled the cap off and saw white residue around the edge of it. Could this mean coolant in the oil? It looks like my ofhg might be in the beginning stages of deteriorating. Also if I’m guessing oil leaking from cap means something. Maybe bad Pcv?
      10-30-2018, 06:29 PM   #2
rich_mane
rich_mane's Avatar
139
Drives: 2011 E92 335i
If only these cars had a dipstick, you could take a look at it there and see if the oil still looks that same consistency at the pan. But it's not too uncommon to get a little of that water/oil mix at the oil cap when the weather is a bit colder. You could drain it and make sure it still looks like oil and not a milkshake if you wanna be extra sure.
And if the cap is leaking I'd start with a new cap and see if that fixes the leak. Could just be a worn seal and look into more if it continues to leak after that.
lwgrenier117.00
      10-30-2018, 06:49 PM   #3
lwgrenier
I checked the coolant and it looked okay so hopefully that’s just what it is. Car had just been driven for the first time in a few days too.
As for the cap, you’re right. I’m still learning not to spend more on expensive parts when it could just be something simple
      10-31-2018, 12:01 AM   #4
xxMike61
xxMike61's Avatar
78
Drives: 2011 335i Coupe
That amount looks normal when its colder and car hasnt ran in a bit. Wipe it and check if it happens again
2011 335i M-Sport E92
MHD E30 | Phoenix Racing CP | K&N Drop In Air Filter |Fuel-it Stage 2 LPFP | xHP Stage 3 | VRSF DP | ARM 5" FMIC + Hose Upgrades | GFB DV+ | VMR 19" v703
lwgrenier117.00
      10-31-2018, 07:23 AM   #5
bbnks2
Drives: 135i N55
Pretty normal...
Oil leaking from around the cap is from the rubber seal flattening out over time. A little trick that helps it re-seal is to take the rubber o-ring out and flip it over. There won't be any indentations from sealing on that side.
lwgrenier117.00
      10-31-2018, 09:42 AM   #6
lwgrenier
Originally Posted by bbnks2 View Post
Pretty normal...
I'll do that today!
e90post
