10-27-2018, 01:51 PM | #1 |
Rep 4,532
Tested the stock F90 Air Intake System.
Not bad, but some room for improvement. My Corvette ZO6 was much worse. My X5M was slightly better. All stock systems. Only outlier is my F90 has the RaceChip on 7, so it will require more CFM than a pure stock F90 and that will cause more pressure drop. Possibly 5hp more loss than pure stock due to the filtered restriction. Also this is without the Charcoal filter, just stock air filters. Next test will be a higher flowing panel filters. r33_RGSport
10-27-2018, 04:44 PM | #3 |
Rep 192
Good info!
I never had a F10 but heard the F10's didn't get any performance increase from intakes? If so, will it be worth going aftermarket for the F90? Also, what's up with $2000+ intakes? My RS7 had a $500 roc euro intake which added sliggt power and dramatically improved sound too lol The Eventuri definitely looks nice just would like to see the benefits it adds besides a nicer engine bay. |
10-27-2018, 07:46 PM | #4 | |
Rep 18,713
In stock form, the stock filter is sufficient, aftermarket is not helping. But with higher boost, less restrictive air filter will help. In combination with catless downpipe, it just will amplify the gain.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
10-27-2018, 09:11 PM | #5 | ||
///M
6654
Rep 3,683
Life is too short...enjoy your life
///M |
r33_RGSport12966.00 |
10-27-2018, 11:14 PM | #6 |
Rep 5,233
I had several different Intake set-ups on the 2 F10 M5's I owned and will say this:
- Power Gains are minimal. - Sound is greatly improved as are looks. - Very little bang for your buck IMO as intakes are expensive. - Charcoal Delete + Drop-Ins improve sound (nowhere near intakes) and provide the same minimal power gains. I'm undecided as to what I'll do on my 19' M5C but more than likely start w/ charcoal delete + drop-ins.
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND LONG GONE: 09' E60 M5|02' E39 M5 |
onfireX53618.50 |
10-28-2018, 12:03 AM | #7 | |
Rep 459
What aftermarket intake systems did you have on the F10? |
10-28-2018, 07:52 AM | #8 | |
Rep 4,532
10-28-2018, 08:35 AM | #9 |
Rep 4,532
Not my FlowBench, but a typical test of panel filters with different media. On my Bench, the Green picked up a lot of CFM over the my stock ZO6 filter...was worth 10-15hp.
10-28-2018, 09:17 AM | #11 | ||
Rep 5,233
10-28-2018, 09:21 AM | #12 | ||
Rep 5,233
10-28-2018, 10:21 PM | #14 | |
Rep 18,713
It will be like driving in Summer weather all year long or living the LA life. For us in LA won't matter much for 11.5 months on the performance, but worth 11.5 months of popping up the hood during shows.
10-29-2018, 12:25 AM | #15 |
Rep 260
10-29-2018, 12:58 AM | #16 |
Rep 89
I disagree, I would prefer more volume as close to turbo outlets as possible, intercoolers will cool down the air then.
10-29-2018, 07:30 AM | #17 | |
Rep 4,532
Short Rams will work If the stock system has a high PD and they eliminate that. No question and they have a spot for looks , cost , sound , some performance gain , etc. Best is no/low PD and ambient. |
10-29-2018, 10:06 AM | #18 |
514
Rep 1,437
What filter replacements are currently offered. I looked for BMC and couldnt find.
2022 Individual M5 Comp
Venetian Violet 2021 X6M Comp 2024 i4 M50 on order IG @purpleM5Comp_NY |
10-29-2018, 11:50 AM | #20 |
Rep 5,233
On the F10 M5 platform oiled drop-ins created issues with MAF sensors so going with non-oiled or dried out oiled filters was important.
F90 M5's have no MAF's so should not be any issues although I've not yet done this so not speaking from my own experience.
