E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Radiator replacement
      10-19-2018, 01:01 PM   #1
bsad0521
Drives: 2011 e90 335i
Hey guys I have the tiniest hairline crack in the upper connector of my radiator. Not loosing a ton of coolant but im going to replace it before I do.lol Do you have to remove the intercooler to drain the coolant out before I start, or can I just undo the lower radiator hose to drain?
      10-19-2018, 06:45 PM   #2
Chris1337
Drives: 2012 e92 335i
For the sake of not making a mess, jack up the car and look for one of the coolant lines and just drain it through there. You can also take off your front bumper and do it through the plug.
      10-23-2018, 05:48 PM   #3
rich_mane
rich_mane's Avatar
139
Drives: 2011 E92 335i
You can just undo the lower hose to drain, there's really no problem with that other than the mess it will create lol.
But I think the intercooler has to come out anyways when replacing a radiator. I could be wrong but I remember dropping my intercooler to get the radiator out.
      10-24-2018, 07:36 AM   #4
bsad0521
yea i just took the intercooler out. everything went fine until the bleed process. I overtightened the lower screw by the lower radiator hose and didnt let that tiny hose sit flush in the connector. coolant was going everywhere lol. loosened it up and we were good. thanks for the help guys.
      11-06-2018, 01:45 AM   #5
AnthemX
Drives: 2011 335i xDrive M Sport
Was it a tough job? Any tips? My new rad is on order.
      11-14-2018, 02:21 PM   #6
bsad0521
Well it was my first time so if I would suggest anything it would be to take your time. everything wont slip in and out so easy like the diy videos. and when you get to those two smaller hoses towards the bottom corners of the radiator that are connected only by a screw, do not over tighten the screws because it will not let the hose sit properly in the housing and will leak.
e90post
