E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Check engine with JB4
      10-06-2018, 01:06 AM   #1
vladorlov96
Drives: 2011 BMW 335i M package
hey guys, I'm new to the BMW family but I have an issue which I hope I can get answers for. I have a 2011 e90 335i JB4 tuned. Also I have aftermarket downpipes and a chargepipe. Now, every day or so I keep getting a check engine light that tells me about catalytics and o2 sensors. which I just clear with JB4 app and it goes away. The errors are
38A4:No description found
38B4:No description found
3106 Catless downpipes installed.
I also ran the codes with FiXD which is another scanner tool and it gives me catalytic converter and o2 sensor errors. Now, I assume, CEL comes on because of downpipes. car runs and drives great, not feeling any difference. Did anybody have the same issue before? please help!!
      10-06-2018, 03:14 PM   #2
HiRev335i
Drives: 09 E92 335i sport pkg
Your more than likely getting the codes because of your downpipes. Jb4 alone no longer has auto clear to keep those codes at bay when running catless. Your other alternative is to run MHD which does. Or you can add the BEF along with your Jb4 and if anyone else could also chime in..... if I am correct that'll work as well.
      10-08-2018, 04:16 AM   #3
Dambaehaseyo_e92
Drives: 2011 E92 335i n55 auto coupe
What do you mean JB4 no longer has auto clear? I still have mine on and it auto clears the CEL. I occasionally turn it off just to make sure nothing else is wrong with the car. The first two codes he has are tuner codes and the downpipe which is perfectly normal.
      10-08-2018, 10:13 AM   #4
orteeze
Drives: 2018 YMB F80
Newest firmware doesn't allow auto clear is what he's talking about.
2008 MB 335i-SOLD
2011 AW 335i M Sport- SOLD
2011 BSP 335i-SOLD
2011 BSP 335is- FOR SALE
2018 YMB M3- Current
      10-08-2018, 07:25 PM   #5
Tonkatoy
Drives: 2011 335I N55 convertible Red
yea they took it off. you just have to go to 1 and 2 on jb4 on the steering while.
is it a catless downpipe. if so go to area 74 and buy the chip
Jeff Dunemann
      10-09-2018, 06:18 AM   #6
orteeze
Put a back end flash using MHD and disable the code in tuner pro. Use your Google Fu powers; it can be done fairly easy. You won't regret it.
2008 MB 335i-SOLD
2011 BSP 335i-SOLD
      10-09-2018, 06:37 AM   #7
vladorlov96
Thanks! another question, does back end flash do anything else good besides clearing off errors? sorry never had to deal with it before ((
      10-09-2018, 09:03 AM   #8
orteeze
Here's a link to N54tech where you can find the information you need.
https://www.n54tech.com/forums/showthread.php?t=43151
2008 MB 335i-SOLD
2011 BSP 335i-SOLD
      10-09-2018, 09:22 AM   #9
Bullcitybmmer
Drives: 2013 335i e92 msport
If you were to search MY POST HISTORY you might find the answer to this.
Go to n54tech, download the appropriate BEF bin. Download tunerpro, and code it out- Boom, no more CEL. I'm not sure that the BEF adds any more power, but it does add driveability. It effectively has the JB4 only controlling boost, and the BEF controlling your timing, fueling, etc.... it's just all around much smoother, and I'd say it's worth doing.
      10-09-2018, 10:15 AM   #10
vladorlov96
Thanks for all your replies!! will be doing further research and hopefully get the BEF process going
e90post
