10-02-2018, 08:03 AM | #1 |
Rep 658
Drives: i7 xDrive60
Will the new X5 have the key that stops transmitting while put down
This must be the best new feature on the new 3-series. This must prevent steeling bmw parked on the driveway with the keys inside the house using a signal repeater. I wonder if the X5 I have on order also will have this?
"New movement sensor in key monitors if key is being carried (and therefore is always transmitting) or has been put down on a table, for example, allowing it to switch into standby mode with the transmit function deactivated"
/Fredrik
i7 xDrive60 -23 Sold: iX -22, X5MC -20 (F95), X5M50d -19 (G05), X5M50d -17 (F15), X5M50d -14 (F15), 116d -13 (F20), X5 3.0D -10 (E70), M3 -10 (E93), 320DX -10 (E91), 320D -08 (E91), X3 30D -07 (E83), 335 -07 (E92), 325 -05 (E90), 320 -02 (E46), 318 -00 (E46), 320 -93 (E36), 318 -89 (E30) |
10-02-2018, 03:39 PM | #2 |
Rep 109
I hope this is the case.
I have already lost the F15 40d this way and don't relish parking the new G05 50d outside the house in case it happens again. |
10-02-2018, 04:46 PM | #3 |
Rep 790
I can confirm the X5 key DOES go to sleep after 45 seconds once it stops detecting motion. It was mentioned during the training session I was able to watch today. In fact there was a whole video demonstration regarding it.
- Scott
Current Cars: 2019 X5 xDrive40i M-Sport, 2018 Camaro ZL1 Past BMWs: '16 528i, '00 M-Coupe, '14 X1 sDrive28i, '00 740iL, '02 325i, '99 M-Coupe, '00 323Ci, '79 323i, '83 320i |
10-03-2018, 06:50 AM | #4 |
Rep 658
Drives: i7 xDrive60
That's great!!!
/Fredrik
10-03-2018, 12:59 PM | #6 |
BMW Client Advisor
3452
Rep 2,504
Drives: 2020 M340i
Key goes to sleep after 60 seconds of no movement.
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. |
10-03-2018, 08:40 PM | #8 |
Rep 790
That’s correct. If you are in an area where that is a serious concern, then I wouldn’t walk around with the key in your pocket...it wouldn’t ever go to sleep.
jersey john22.00 |
10-04-2018, 08:46 AM | #9 |
BMW Client Advisor
3452
Rep 2,504
Drives: 2020 M340i
Wild Blue3683.50 jersey john22.00 |
10-06-2018, 01:50 PM | #10 |
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
Wrong forum. You're about 14 years off.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. |
02-10-2020, 07:14 AM | #11 |
Rep 8
Hi Jay!
Today I tried to test key fob sleep function and did the following: closed the door using comfort access, put key fob on the ground right next to the car, tried to unlock the car after: 1 min and then after 2min. I could still unlock the car after that time.... Is there any way to verify that I got the new version of key fobs (checking serial number, etc.)? It seems mine don't enter sleep state Thanks for the response! |
02-11-2020, 03:07 AM | #15 | |
Rep 2,420
02-12-2020, 02:21 PM | #16 | |
Rep 182
02-12-2020, 03:43 PM | #17 |
Rep 599
You are sure the BMW X5 key goes to sleep after 60 seconds? My previous generation X5 was broken into using a signal repeater.
I always put my keys in the fridge or in a RFID blocker sleeve. It would be nice if I no longer have to do this. |
02-12-2020, 03:54 PM | #18 | |
Rep 2,420
Can't find anything in the manual. I would presume if the function was present it would be mentioned or would state in the Q&A something like if your key doesn't work move it around. |
02-12-2020, 04:06 PM | #19 |
Rep 1,151
Easy to check, put the key down next to the door and try opening using keyless entry after 60 seconds.
My GLE key goes to sleep after a period of time and you can also do this instantly by pressing the lock key twice, if you do this you have to press any button on the key to reactivate it. |
02-13-2020, 01:41 AM | #20 |
Rep 1,790
02-13-2020, 03:24 AM | #21 | |
Rep 2,420
General article mentions bmw 1 and 8 and x6. Not the x5. On the other hand they mention all new BMW with comfort acces would have the feature https://www.motoringresearch.com/car...ess-car-theft/ |
mcsa65.00 |
02-13-2020, 02:26 PM | #22 |
Rep 82
Carried out the key test tonight re the powering down after a minute without movement and yes it did go to sleep after 60 seconds. That’s great as I have also been concerned regarding theft with the comfort access My car was built in July 2019.
mcsa65.00 |
