E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > How to achieve readiness ?
      09-26-2018, 11:10 AM   #1
Hunter3
Hunter3's Avatar
Drives: 2013 BMW 335xi e92 N55
I have a 2013 335xi N55 with catless DP JB4 I went to do my emissions inspection and failed. I was under the impression the JB4 would hide the codes and allow me to pass. Is that not true ? And if so is returning to stock downpipes the only way to pass ? I've also read just put it on map 0 and that should work but I have not tried that yet.
      09-26-2018, 12:18 PM   #2
weehe126
Drives: 2017 340i
Codes and readiness are two different things. Codes will bring up the CEL, readiness means it's actually working. Most states you can pass emissions with 1 item not ready. So you would need to get the other items good.
      10-31-2018, 08:51 AM   #3
jaytes
Drives: 2011 335ix M-sport
Hi Hunter3,
Curious to know if you found a work around for this? I just failed my inspection cause my "Service Engine Soon" light was on. I was at readiness and was able to pass that with 1 fail (DP installed) But I failed cause that stupid light was on. If I clear the codes with the JB4, I will not be able to achieve readiness. Did setting it to Map 0 work?
      11-04-2018, 08:45 AM   #4
E46toE90
Sparkling Graphite Metallic FTW
E46toE90's Avatar
151
Drives: lci m-sport e90 n55
N55 you need an 02 simulator.
      12-03-2018, 07:09 PM   #5
Cory S
Cory S's Avatar
Drives: 2011 335i-X
THIS.....
2011 335i X-drive 6AT / Pure turbo / 500AWHP/526TQ
e90post
