07-02-2008, 02:39 PM | #1 |
instagram 997turbotom
279
Rep 7,376
z4m diff swap into 3.0 car?
Other than the diff from the M, what else is needed from the swap? Do you also need the halfshafts?
07-02-2008, 04:16 PM | #2 |
Midlife Crises Racing Silent but Deadly Class
1820
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
You just need the entire subframe from the M.
http://www.realoem.com/bmw/showparts...33&hg=33&fg=30 http://www.realoem.com/bmw/showparts...93&hg=33&fg=05 The diff carrier is integrated into the rear subframe. If you compare the diagram below for a none-M: http://www.realoem.com/bmw/showparts...38&hg=33&fg=30 As you can see, the front of the diff on the M bolts onto the subframe from the side (1x) and back (2x). The non-M diff bolts onto the subframe from the side (1x) and the front (2x). I believe you can not swap the internals from the M diff to the non-M diff, since the M diff internals are much larger than the smaller non-M diff. |
