E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Good Ideas for checking boost leaks
      09-22-2018, 12:38 PM   #1
LoneWolfPistol
LoneWolfPistol's Avatar
Drives: Decent
Please share your exsperinces, I was told to do a " Smoke test ". Getting that done but still open to suggestions. SN: I checked all piping (i.e. Chargepipe, intercooler connections and found nothing.
335i | FBO |
______________________
      09-22-2018, 02:08 PM   #2
SnapCoupe
BMW Portland
Drives: Z4M Coupe/E90 335i
With all of the boost leaks I have chased down and fixed, typically I go in this order to get to the bottom of them.
1. Can you hear a leak? I have had bad boost leaks that sound like a whoopie cushion and also ones that just sound like more turbo noise. If you can hear the leak, more than likely its a bigger one. Typically I try to track down its location by sound first.
2. Visual inspections. Throw some gloves on and dig around the engine bay. Pinch some of the couplers and make sure they haven't slid off from their original locations.
3. Smoke test. Sometimes its hard to find smaller leaks if they're hidden deep in the engine bay. Smoke testing will assist in finding cracks, loose connections, and other smaller leaks that are open. The down side of a smoke test is the turbo plumbing is not under pressure, so if a leak only occurs under boost it probably won't show it.
4. Running a "diag test" through ISTA. I know this isn't available to everyone, but it is really helpful for finding boost leaks that only occur under pressure. Unfortunately the car does not build boost if you just rev it in neutral. ISTA has a test that builds full turbo pressure in the system to help locate expanding turbo plumbing.
Hope this helps!
2011 335i N55/6MT/M-Sport
MHD Stage 2+, VRSF Downpipe, VRSF 7" FMIC, BMS Intake, BMS Chargepipe, Performance Exhaust Mod, F10 550i Clutch, BMS CDV, BMW Performance SSK, M3 Control Arms, ST Coilovers, Apex ARC-8 wheels, Michelin PS4S
      09-23-2018, 07:49 PM   #3
LoneWolfPistol
Drives: Decent
still no luck, Smoke test next
      09-25-2018, 02:01 AM   #4
ckanderson
Drives: 2013 335i Xdrive
Smoke tests do work very well. I've owned other turbo cars in the past (Supra mostly) that had 2-3 boost leaks that I found using a smoke test.
Granted I did them myself so they were free, are you just doing this as preventative maintenance or chasing a problem?
      09-25-2018, 07:38 AM   #5
Wolf 335
Wolf 335's Avatar
Drives: 2007 E92 335i
Where did you attach the smoke machine?
      09-25-2018, 09:31 AM   #6
Kev0
Drives: 2012 BMW E92
I've seen people attach them on the intake side by removing the filter. That's how my local mechanic found 2 leaks on the intake side up to the turbo.
      09-27-2018, 08:10 AM   #7
LoneWolfPistol
Drives: Decent
Chasing a problem, I already found one major. but theres a second I haven't found as of yet
335i | FBO |
      09-27-2018, 08:12 AM   #8
LoneWolfPistol
Drives: Decent
Hmm. Seems like I would have to cap off a lot to keep the pressure. I honestly never done this before so pics diagram help a bro out lol
335i | FBO |
      09-27-2018, 10:45 AM   #9
lwgrenier
Drives: 2011 e92 335i XDrive
Boost leak test worked for me. I followed this DIY:
https://www.1addicts.com/forums/show....php?t=1143853
      09-28-2018, 05:45 AM   #10
LoneWolfPistol
Drives: Decent
Thanks! just what I needed
335i | FBO |
e90post
