Code 315A (P2421) Fuel tank valve: jammed open - may not be what you think?
09-14-2018, 05:32 PM | #1 |
Rep 217
Awhile ago, SES light came on, check and code 315A (P2421) - came up when the fuel tank is low... Initially, fuel tank breather valve was replaced (under intake manifold), cleared code, thought it's fixed. It came back on again on the next 1/4 tank of gasoline, so I did more research and replaced DMTL pump and replaced fuel nozzle lid. Again, the light came back again when fuel is just right below 1/4 tank. Any ideas guys? I'm going to check the hose connection at the breather valve again this weekend.
Perhaps I gotta switch out the charcoal canister?? That's a $300 bucks 😭 Also, fuel nozzle keeps shutting off as I pump 😣😡😠 Annoying af... maybe the new breather valve was a DOE unit...? Any advice is welcome. TIA, guys.
09-14-2018, 06:09 PM | #2 |
Rep 1,753
Fuel shutting off at the pump early is def a venting issue with the canister. So looks like you have to replace that part anyways.. maybe it will fix more issues.
09-17-2018, 06:18 AM | #4 |
Rep 124
I am also having very similar problems. About 3 months ago when my fuel tank was under 1/4 tank, a code came up which was for the fuel tank vent valve(under the intake manifold). I replaced it and it seemed to be all good, but then last week again when I was under 1/4 tank, the same code came up. I also have a bitch of a time filling my gas tank at the gas station. The dam clicker keeps going off when I try to fill my tank. I've tried pulling the nozzle out a bit, rotating it, trying different gas stations and no luck.
MHD Custom Map by DocVu Tuning | Rod Sutphin Trans flash | VRSF 7.5 Race FMIC | BMS Chargepipe | VRSF DP | RB Stage Ones | RB INLETS | Fuel it stage 2 lpfp
Street of Rage59.50 n55n55n55n551.50 |
09-17-2018, 09:45 AM | #5 |
Rep 255
I'm not sure if this is totally related because I can't remember the codes but I was having a very similar issue a while ago. Was getting a CEL saying the dmtl pump had no connection and was stuck open I believe. I replaced the pump and the CEL did not go away. Eventually I found this thread:
https://www.e90post.com/forums/showthread.php?t=950374 After pulling the rear, drivers side wheel off I found the wiring going to the pump was frayed and one of the wires had been broken. Soldered in a new wire and all was well. Hope this helps. |
09-17-2018, 10:59 AM | #6 | |
Rep 217
Much appreciated.
09-23-2018, 02:11 PM | #8 |
Rep 217
I haven't received the canister yet. FCP shipped it out this past tuesday, usually 5 business day with UPS and I'm in L.A., Cali. Gotta way until next weekend...
10-01-2018, 10:44 AM | #9 | ||
Rep 217
flipmode if you haven't gotten any code and you can tolerate the shut-offs, just wait until it gets worse, I guess. Mine was gradually getting worse over 1.5 years ownership of the car.
10-01-2018, 10:56 AM | #10 | |
Rep 6,290
I had a questions and similarly-ish issue on this actually. How fast was the nozzle clicking off, at like how many liters/gallon? In my case it seems to click off. I found that if I stop pumping my gas for 3 seconds every 20 liters (5.2 gallons) until full it's fine and never clicked off early. |
10-01-2018, 11:09 AM | #11 | |
Rep 124
10-01-2018, 12:29 PM | #12 | |
Rep 1,753
10-01-2018, 02:03 PM | #13 | ||
Rep 217
-------------------------------------------- Quick summary: several weeks ago I pulled out the old canister, which looks perfectly fine, with very minimal white residues, which is normal... I tried to use air compressor to blow air in and out (clear our passages), according to several Youtube vids, thinking it may delay or fix the issue. It doesn't help at all. Lol Also, as i mentioned above, breather vent valve and DMTL pump were replaced and did not help the situation as well. So i bit the cost and bought the canister and crossed my finger at the gas station yesterday as I was pumping Just hope this would help anyone with this issue now or in the future. Thanks again Pladi
Pladi718.00 n55n55n55n551.50 |
10-01-2018, 02:46 PM | #14 | |
Rep 1,753
10-01-2018, 04:09 PM | #15 |
Rep 217
I wonder if previous owner(s) had filled up with cheaper ACN91 gasoline that caused the canister to clogged or heavily filtered out the fume..
10-01-2018, 04:39 PM | #16 | |
Rep 6,290
But thanks for the reply, thankfully your issue is not what I'm getting and it's just what others have said reading past forums, it's just how the car is and tilting the gun does help. |
10-02-2018, 12:26 AM | #17 | |
Rep 217
TheMidnightNarwhal2657.00 n55n55n55n551.50 |
10-02-2018, 12:55 AM | #18 |
Rep 7
I'm actually having the same fill-up problem, 10-15 clicks just to get 10 gallons & P2421 code. You got a link to the canister? Is it the Activated Charcoal Filter? I don't know what to look for.
10-02-2018, 11:13 AM | #19 | |
Rep 217
https://www.fcpeuro.com/products/bmw...er-16137163596 You maybe able to find it cheaper on ebay from a legit seller.
10-03-2018, 04:34 PM | #20 |
Rep 7
Thanks! This will be awesome if I can finally fill up a full tank of gas, and pass my emissions properly.
Street of Rage59.50 |
10-26-2018, 07:21 AM | #21 |
Rep 124
I ended up finding a used Activated Charcoal Filter at the wreckers and switched mine out a couple weeks ago. I can say after swapping it out, this also fixed my problem filling up at the pumps!
