E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > MHD Stage 2+ Spark Plugs
      09-13-2018, 12:05 AM   #1
TheGoodTheBadTheUgly
Drives: 2011 E90 335i xDrive
Let me make this as simple as possible.
I have a 2011 E90 335i xDrive N55.
I have the BMS cold air intake
I have the ETS Charge Pipe
I have the 7" ETS FMIC (Not Installed Yet)
I have MHD on Stage 1 at the moment.
I am missing catless downpipe.
So I plan on going stage 2+ as soon as I get my downpipe and FMIC installed, but I wanted to know which spark plugs should I use and with which gap.
Do I need some specific coils or I can keep my stock ones?
Thanks!
      09-13-2018, 02:15 AM   #2
Bfurrow95
Drives: 2011 BMW 335I E92 Coupe
Thanks!
BMS sells some NGK plugs that I've found work pretty well.. I got the 1-step colder plugs for now. They have the gap on their site, but I think it's .022.
      09-13-2018, 12:42 PM   #3
And you are running Stage 2+? How is the cylinder correction looking and on what octane level.
Thanks!
      09-13-2018, 12:50 PM   #4
Bfurrow95
Thanks!
I'm just on stage 1 right now. I still need to get downpipes and find a good source for fuel. Stuck on 91 octane down in southern AZ. I'm not sure about cylinder correction though.
      09-13-2018, 01:24 PM   #5
Soden82
Drives: 2011 BMW M3
2011 BMW M3  [0.00]
You can keep the coils stock for now unless your getting misfires. As for plugs you can get one step colder ones from BMS. They're NGK and are gapped to 0.022"
2009 BMW 335i 6MT
*big single (eventually)*
For now...
MHD tuned
VRSF Race IC
DCI
ATM exhaust
      09-13-2018, 01:36 PM   #6
Alright so the NGk ones on the BMS they are already pre-gapped (I guess not)?
I have nearly 105km on my car so I do not mind changing the coils. Would you recommend anything for a change?
      09-13-2018, 10:25 PM   #7
DYOOS
DYOOS's Avatar
Drives: 335i E90 N55
I just got FMIC and catted downpipes installed recently along with NGK 1-step colder spark plugs. I believe Bfurrow95 and Soden82 said that they come gapped at the recommended .022, but correct me if I understood wrong.
I haven't had any problems so far, but I've only driven the car about ~50 miles since going FBO. I did get the check engine light to pop up. Believe that's bc of the catted downpipes. Planning on flashing MHD S2+ soon and hopefully it fixes it.
IG: @dyoos335i
      09-13-2018, 11:19 PM   #8
Supermoon
Supermoon's Avatar
South Korea
166
Drives: 2011 e92 335xi
I use stock bosch plugs without any issues.
I don't think NGK plugs are needed for OTS pump gas maps.
2011 E92 335i xDrive
Pure Stage 1 | DV+ & Inlet | Injen Intake | M3 Cowl | ETS 5" FMIC & CP | Aquamist HFS4 Direct Port | CSF Radiator | Wagner Catted DP | BMW PE | Apex FL-5 | Michelin PS4S | 335is Engine mount | SDW Monoball thrust arms | UUC Swaybars & SS Brake lines | Bilstein B8 | Dinan Springs & Shock mounts | Whiteline RSFB | M3 Rear Control arms | Manzo Toe arms | Wavetrac LSD
      09-13-2018, 11:43 PM   #9
Alright that is very good. If you could give me any type of feed back on your Stage 2+ that would be great, because up here in Canada fuel is garbage so I have to make it work in a way that I still have a car lol.
      09-13-2018, 11:44 PM   #10
Yeah I was reading that the stock bosh plugs are to be used up to 475 hp. I think I picked that up on BMS's website. But I was thinking since I was going to change my spark plugs anyways, should I get the 1 step colder one?
      09-13-2018, 11:48 PM   #11
Supermoon
Supermoon's Avatar
South Korea
166
I wouldn't use NGK unless I have to.
They are cheaper but wear out faster.
      09-14-2018, 12:36 AM   #12
DYOOS
DYOOS's Avatar
NGK last about 15-20k mile and Bosch plugs about 20-30k. I read around the forums that 1-step colder spark plugs are recommended for cars that have an additional 100 hp.
I'm FBO plus other minor things, and getting MHD and xHP tuned soon. Wanted to try the NGK 1-step colder spark plugs so just gave em a shot.
IG: @dyoos335i
      09-14-2018, 06:57 AM   #13
bbnks2
Drives: 135i N55
I just pulled the N20 plugs out of my car after 30k miles. They still looked fine. No visible wear to the electrode or ground strap. Changing plugs any sooner than 30k miles just seems like a waste of money to me. Only replacing mine because I rebuilt the motor. One step colder plugs looked to be running perfectly fine. No signs that they were too cold. In fact, it looked like I could probably run a 2-step colder plug. This is on a very hard driven car running stage 2+ or a custom E30 tune making 24psi.
      09-14-2018, 11:38 AM   #14
So right now on your stage 2+ your are running the stock Bosch ones? In that case I would do the same since you have a pretty similar build. I heard some of the stock models from Bosch don't have the BMW logo on them and do not act 100% like the genuine stock one. Is it true?
And btw, is the catted DP from wagner worth it or I should just slap on the catless?
      09-14-2018, 11:42 AM   #15
Supermoon
Supermoon's Avatar
South Korea
166
The right one ends with S.
Wagner catted? Worth every penny!
I already got PE and PPK.
No way I run catless.
      09-14-2018, 11:43 AM   #16
Perfect I'll look into it thank you! Other than that, do you recall where you purchased the plugs from? ECS?
      09-14-2018, 11:47 AM   #17
Supermoon
Supermoon's Avatar
South Korea
166
Yea ECS. Check FCP too.
Bosch ok for now.
Try gapped N20 plugs if u upgrade turbo.
      09-14-2018, 11:48 AM   #18
Bosch ok for now.
Okok, but for now I am only going to go FBO with MHD Stage 2+, but I'll keep that in mind. Thanks for everything mate!
      09-14-2018, 04:22 PM   #19
DYOOS
DYOOS's Avatar
I bought my NGK 1-step colder spark plugs from BMS and they just confirmed that they don't come gapped at 0.022". You have to gap them yourselves. Wish I knew that when I got mine installed. I haven't had any issues, but I want to pull them out and gap them properly now.
IG: @dyoos335i
      09-14-2018, 07:53 PM   #20
O well, better now than never. Sorry I had to make you learn it that way
      09-15-2018, 07:14 PM   #21
redwildcat17
redwildcat17's Avatar
31
Drives: 2011 e90 335i xdrive m sport
Vrsf catless with pe exhaust and ppk. Couldn't be happier sounds amazing.
      09-15-2018, 10:24 PM   #22
bbnks2
Drives: 135i N55
If you aren't having problems then what do you think a tighter gap is going to do for you??? You don't need to gap down plugs on a stock turbo n55.
e90post
