E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > BMS Oil Catch Can Installation Fitment
      09-12-2018, 09:27 PM   #1
DYOOS
DYOOS's Avatar
Drives: 335i E90 N55
I got my BMS Oil Catch Can installed recently, and the fitment of the engine cover won't fit how it used to. This is because of the thick tubes from the catch can.
Has anyone else that's installed the BMS OCC running into this problem as well? I thought about trimming the side of the engine cover to give more space for the tubes to clear, but wanted to check in here to see if anyone else had any tips or feedback on their installation.
In this picture you can see the left side of the oil-fill cap is rubbing against the plastic
In this picture you can see that the tubes are pushing up against the side of the engine cover plastic causing it to not fit correctly
This is how it was installed
This is how my engine looked without the BMS OCC installed. You can see that the oil-fill cap is a lot more noticeable
IG: @dyoos335i
      09-12-2018, 10:07 PM   #2
dpark
Drives: BMW 335i E92
Trimming is the only way if you want it to sit flush
      09-12-2018, 10:51 PM   #3
Welcome to NBA Jam
Is it the shoes!?
Welcome to NBA Jam's Avatar
3884
Drives: (Sold) 2011 E92 335i ZMP 6MT
You need to increase the size of the hole in side of the the engine cover with either a dremel or grinding attachment on a drill.
      09-12-2018, 11:38 PM   #4
DYOOS
DYOOS's Avatar
Which part do you guys recommend trimming, the section where the tubes pass or the circular section for the oil-fill cap?
I was thinking it'd be easier to trim the section where the tubes pass and make it wider. This way the tubes don't push the engine cover out of place.
IG: @dyoos335i
      09-13-2018, 10:04 AM   #5
Welcome to NBA Jam
Is it the shoes!?
3884
Definitely where the tubes pass. If facing the engine, I trimmed the section closest to the front, and around the top right "corner" of the hole. You won't even notice it once you're done.
DYOOS88.00
      09-13-2018, 10:50 AM   #6
N55Jamaican
Drives: 2011 BMW 335i E90 LCI
I am sorry if I hijacked OP thread. Just have a question. If I going to install sing turbo in my N55 where would OCC be relocated to?
(JB4 stage 2, in my garage)Now CoBB V3 , VRSF 3.5" Stainless Steal catless DP, 7" VRSF FMIC with upgraded lower CP.
      09-13-2018, 10:18 PM   #7
DYOOS
DYOOS's Avatar
That's the route I was thinking. Now need to go buy a dremel. This is going to be fun
IG: @dyoos335i
      09-25-2018, 12:01 AM   #8
DYOOS
DYOOS's Avatar
Got a sweet dremel and cut about 1/2 inch from the top to the right side to give the tubes more clearance. You can cut about a centimeter or so more and the oil cap will fit better, but I'm happy with the fitment for now. Doesn't bother me nearly as much anymore. I may trim off more if I'm really ...really bored one day.
IG: @dyoos335i
      11-01-2018, 10:55 AM   #9
cranelec
Hey WTTNBA...(another E90 member whose posts FORCED me to go FBO against my will) great advice as usual.
After speaking with two forum vendor/sponsors regarding the difference between Mishimoto vs BMS catch can for my N55, the sponsors suggested BMS due to the ease of installation.
I installed the BMS catch can on a Sunday morning and was completely pizzed off that the damn engine cover wouldn't fit.
After reading your contribution to this thread, I regained my composure an trimmed the cover accordingly.
Thanks again for the guidance!
e90post
