BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Cosmetic/Visual (Exterior + Interior) Modifications
BPM
      06-29-2008, 09:14 PM   #1
CatchM3
CatchM3's Avatar
Drives: 2020 X6M Competition DG
2008 E90 M3  [9.00]
How to remove M3 trunk lip spoiler correctly?
Ok folks, I purchased a CF M3 lip spoiler for my trunk lid.
The question is how do you suggest I remove my OEM M3 spoiler? And when I do, how do I remove the remaining residue on my trunk?
Thank you for you suggestions and tips. I will post pictures during the process. I estimate my lip spoiler should be arriving sometime this week.
Anthony
2020 X6M Competition // Donington Grey // Executive Package// Bower and Wilkins Sound System // Driver Assistance Package // CF Trim
      06-29-2008, 10:31 PM   #2
Dundas
Drives: G82 xDrive BSM
It’s been a few years but what worked well with my E46, as I recall, was slowly working fishing line between the spoiler and the trunk lid to separate them and then Goo-Gone to remove the residue of the 3M double-sided tape.
      06-29-2008, 11:57 PM   #3
Big Windy
Big Windy's Avatar
Drives: None
This could work...some people use dental floss, but that might not be strong enough. Also would recommend a hair dryer. Be careful with the goo-gone, you might want to dilute it because it could damage the clear coat.
      06-30-2008, 12:34 AM   #4
Dundas
Goo-Gone didn't hurt the clear coat. Doing it on a hot, sunny day helps.
      06-30-2008, 12:31 PM   #5
SV Concepts III
Drives: BMW Duh
Use a heat gun or hair dryer to soften the tape on the bottom of the spoiler then use floss or fishing line to get between the trunk and tape.
      06-30-2008, 02:40 PM   #6
nusevad
O! So Sour!!
nusevad's Avatar
Drives: Fast 240z / Slow M3
1971 Datsun 240z  [0.00]
2008 M3  [9.60]
Is the OEM lip spoiler held on by 3m double sided tape too?
      06-30-2008, 02:44 PM   #7
!Xoible
Drives: ....
2008 M3  [4.00]
2007 335i  [9.00]
2008 528i  [8.00]
2006 Infiniti - G35 ...  [8.00]
3m tape and windex
i would heat it up with a hair dryer, then put a wool thread in there
      06-30-2008, 02:48 PM   #8
Big Windy
Big Windy's Avatar
Drives: None
Originally Posted by ///Mantis View Post
3m tape and windex
wool thread???? interesting. anything that makes it better than fishing line or floss?
      06-30-2008, 03:50 PM   #9
badfish
badfish's Avatar
100
Drives: E92 AW M3
2008 M3  [0.00]
If it's impossible to remove with goo gone, goof off, or any of those other adhesive removers, sometimes you have to use what's called an eraser pad. This is what professional shops use and I'm sure if you don't want to buy the pad itself, you can go to a body shop and they will make quick work of your tape for next to nothing. Sometimes that stuff is really hard to remove so that's why you use these pads. They are safe and you can buy pads that will fit your drill.
      09-03-2013, 03:12 AM   #10
M3ZCP6MT
M3ZCP6MT's Avatar
72
Drives: 381 ///M3
Great tips. Thanks guys.
/// M3 + 6MT + ZCP + ///MPE = A Healthy Addiction ///
      09-03-2013, 06:42 PM   #11
Johndong888
John
Johndong888's Avatar
Drives: '12 M3, '18 S560, '16 G63
I see you're interested in the CF spoilers lol.
I used heat gun, then fishing line and it popped right off. The hard part is removing the existing tape. Used goo-gone and a lot of fingernails lol. Finished up with a polish then alcohol wipe down to ensure proper adhesion. I used the OEM bmw betalink for the new CF spoiler. It's alot of work lol but I know for sure it will stay on.
Current - 2012 AW/FR E92 M3 | 2014 AW X5 | 2015 MB S550 | 2016 RR V8 (White FTW)
Mods - BPMTune Stg1/Servo, Euro Visors & Side Mirror, IND Gloss Blk Pkg, OEM Perf. CF Trim/Spoiler, Grills, Lights, Pedals, Umnitza V4 AE, ModeCarbon GTS V1, 19" HRE P40
Sold - 2008 BSM/Black E92 335i
      09-03-2013, 08:19 PM   #12
vastano
Drives: F15 X5
heat + fishing line, then goo gone + plastic razor, then alcohol (not the beverage)
DL335D580.00
      09-03-2013, 10:33 PM   #13
M3ZCP6MT
M3ZCP6MT's Avatar
72
Drives: 381 ///M3
Thank you very much for your tips
So it's definitely something simple you can do yourself rather than paying the body shop to do it? So maybe an hour? I suppose my spoiler should be a bit easier since it is less than 4 months old?
      09-03-2013, 10:34 PM   #14
M3ZCP6MT
M3ZCP6MT's Avatar
72
Drives: 381 ///M3
Thanks for your tip. Plastic razor on the paint? Should I apply express wax before using the razor (as in claying?)
      09-04-2013, 05:27 AM   #15
vastano
Drives: F15 X5
the reason you use a plastic razor instead of a real razor is so it wont scratch the paint.
Give this a look:
http://www.autobodytoolmart.com/plas...FVNo7AodGGEA7g
      09-04-2013, 01:18 PM   #16
Johndong888
John
Oh it's extremely simple. The old spoiler removal is. The residue tape is super annoying though but like vastano said, you could try the plastic razor.
As for installation, some people swear by 3m tape so that could be an option. I stuck with oem beta link
      09-04-2013, 01:29 PM   #17
W///
W///'s Avatar
7485
Drives: F82GTS, E36/E92M3, Z4M
Give this a look:
Damn it. So you had no idea about the exhaust hanger tool, and I had no idea about this. Would have saved my finger nails. Great to know.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT
08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT
07 E85 Z4M Roadster, Alpine White/Red, 6MT
99 E36 M3, Techno Violet/Dove Grey, 6MT
      09-04-2013, 06:34 PM   #18
M3PO
M3PO's Avatar
84
Drives: '08 IB E92
It's possible too cut the paint with fishing line if you get carried away with the sawing motion. I use(d) a t-shirt and heat. As you heat, pull one layer of the shirt under the spoiler with a slight sawing motion. This puts some upward pressure on the spoiler as well.
I don't like to put Goo Gone on the paint so I use a 3M Eraser wheel.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R
      09-06-2013, 12:50 AM   #19
Hujan
Hujan's Avatar
Drives: M3
Where does one get a 3M eraser wheel?
Also, how are people lining up the new spoiler to make sure it goes on properly? I envision myself putting it on all wrong. I was thinking maybe a grease pencil to mark where the edge should go?
      09-06-2013, 02:04 AM   #20
1QuikWS6
No 55mph
1QuikWS6's Avatar
1621
Drives: F32 435ix MSport
  • Mark center of spoiler with grease pencil
  • Mark center of trunk lid with grease pencil
  • Dry test fit
  • Its easier to use (2) people when doing install to line up center marks & both ends - peel off tape liner and stick down pressing firmly along for best tape adhesion. Best to do this after the car has sat out in the sun and the car/spoiler are warm (3M also makes an Adhesion Promoter, but I've never used it & had no problems)
For those that us BetaLink - hopefully you will never have to remove the spoiler to repaint - because removing parts adhered with BetaLink will damage the paint underneath
You can get the 3M Eraser Wheel here (but these are mainly used for pin stripe removal not adhesive residue):
http://www.amazon.com/3M-7498-STRIPE...m+eraser+wheel
3M also makes an aerosol adhesive residue remover that does not harm paint found here:
http://www.amazon.com/3M-03618-Adhes..._bxgy_hi_img_z
I have always just used fishing line & Goo Gone with absolutely no problems or damage...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      09-06-2013, 07:49 AM   #21
anselmw
Drives: 2001 M Coupe
Mine come in today from IND, will most likely use the heat gun, fishing line technique. I have also always used goo b gone with no issues but may try the #M adhesive remover to see how that works. I am going to use 3M tape instead of the betalink.
2011 M3 Sedan
2001 M Coupe
2020 Macan Turbo
2018 GT3
      09-06-2013, 03:30 PM   #22
M3PO
M3PO's Avatar
84
Drives: '08 IB E92
I got mine on eBay. It's not that hard to line up. It's obvious where it should be on the trunk. The only part you need to worry about is making sure that it's even side to side. The performance spoiler is a touch shorter than the trunk so you just need to make sure the same amount of trunk is showing on each end.
m3post
