08-26-2018, 09:35 AM | #1 |
Rep 483
Trying to make sense of all the downpipes and the downpipe info I see being posted.
So far I've seen: VRSF VM ER CG AFE Wagner Prob missing a few... All are posted by their respective retailers with the company's generic write-up: more flow, less restriction, x-inch input and output flanges... when looking at catted options, they all have minimal info, like "add cat?" And a price. Some provide cpsi numbers and cat diameter. No one provides flow rates (cfm), very little info out there for comparing things. All I know is that most aftermarket cats have 200cpsi except for afe which has a 400cpsi. Can anyone help out by providing either more info and/or a better way to compare to figure out what's good and what's better? With the ambiguous data being supplied by manufacturers and retailers, the only thing to go on is price... |
08-26-2018, 10:03 PM | #2 |
Rep 1,456
I can only speak to the CG DS-1 catted DP.
It is the largest out of all of them in terms of diameter (5"). I've been running it for a little more than a year, including 8-9k miles during that time period. No CELs ever. And with no tune (intake, DP, and catback exhaust only), I made 344 hp / 375 lb-ft of torque on an SAE dyno at sea level on 93 octane. So I'm quite pleased with how the setup has been working together. Cost: When I purchased it last summer, it was under $700. Now, I think the cost has gone up quite a bit and I'm not sure why. At a ~$1k price point, idk if I'd get this, but at the price I got it for, I'm satisfied.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2 |
Genieman245.50 |
08-27-2018, 12:24 PM | #3 | |
Rep 216
+ MPPSK +JB4 =fun daily driver |
Genieman245.50 |
08-27-2018, 01:35 PM | #4 | ||
Rep 483
Since no one is providing ALL of the particulars of the cats, it's hard to assess which has both highest flow (max power) and greatest ability to reduce smells, pollution, and highest probability of passing emissions testing. Here is what I've gathered so far from the manufacturers who provide info, most have a 200 cell cats, AFE has a 400 cell cat. FABSpeed and Wagner have 200 cell cats with 300 cell HJS cat options... CG ds-1 has highest cat diameter at 5", most others are 4-4.5 inches in diameter. Judging based on pictures, some are longer than others while some have smoother transitions between pipe and cat... |
08-27-2018, 05:35 PM | #5 |
Rep 1,457
CG DS1 seems to be the most popular. I got mine for under $700 from ECSTuning about 2 months ago and they don’t seem to carry it anymore and the prices have gone up close to $900 or around that range on the actual CG website. My guess is because it doesn’t throw a CEL. Sounds great with my MPE and def blocks out at least 75% of the odor although you can still smell a tiny bit, but nothing insane like a cat less. I usually go with the cat less down pipes, but this time around I wanted to keep the car catted and this one does seem to be the largest on the market.
Genieman245.50 |
08-28-2018, 03:31 AM | #7 |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
BCS in the UK make one.
100 cell cat with 40grm washcoat. |
08-28-2018, 06:34 AM | #8 |
Cheapskate
4450
Rep 4,993
The reason why there isn't a lot of information is because they're all pretty much the same. The differences in flow that you mentioned don't amount to a noticeable hp gain. The main thing between catted and catless is the smell and sound.
ceedawg467.50 |
08-31-2018, 05:07 PM | #9 | |
BimmerPost Supporting Vendor
24259
Rep 190,933
As long as its the same cell count
kern4174449.50 |
08-31-2018, 06:51 PM | #10 | ||
Rep 483
08-31-2018, 09:12 PM | #11 |
24259
Rep 190,933
400 CPSI is too restrictive in my opinion, you might as well just keep the stock one
wassy497.50 |
09-02-2018, 12:44 AM | #12 |
2JZ-GTE
3053
Rep 4,006
Anyone hollow out the Oem cat
09-02-2018, 06:40 AM | #13 |
Cheapskate
4450
Rep 4,993
Not yet but that's what I plan on doing. It's a pretty common mod in general.
09-02-2018, 09:59 AM | #14 | |
24259
Rep 190,933
You are better off getting an aftermarket downpipe and keeping the stock one intact.
09-03-2018, 03:46 AM | #15 |
2JZ-GTE
3053
Rep 4,006
I was curious because in certain states if you can pass a visual and ODB 2 returns no errors, you will pass smog. Your smog guy might even overlook the fact that the cat is hollowed out as long as everything else lines up.
