E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > N55 JB4 Overboost/AFR Issue
      08-22-2018, 01:14 AM   #1
vtn86
Drives: 335i xDrive
Hi All,
Newer to this forum and am having a bit of issue with my JB4 tune on an otherwise bone stock car. Purchased used a few months back and got around to installing this weekend. Install was pretty straight forward, previous owner had some settings in there that required adjustment i.e. Oil gauge hijack to IAT, gauges read for 135i, and a small few other things. After initial install, you could tell there was a bit more power, but not much. Put maybe 30 miles on it, mainly freeway, but was not impressed. Went home and did some research and realized that it had an old firmware update. Did an update, went for a test drive, and WAY more power. Great! But...car did a 2 hazard flash and jumped into Map 4. I didn't realize this was a safety feature and tried it a couple more times with the same result. Did one last run and the CP blew.
Limped it back home and back to researching after installing an ARM CP (had one ready to go). Besides the standard note from BMS; which eludes to a likely O2 sensor fault, is there anything else I should be looking at as potential fail points?
Note, the log is in MAP 1, which targets 13psi. I'm experiencing near 20, obviously likely the issue, but what could be the cause?
Logged a map and linked below.
Thanks in advance for your help!
https://datazap.me/u/vtn86/map-1?log...-5-9-18&solo=4
      08-22-2018, 08:19 AM   #2
sd306
sd306's Avatar
Drives: X5 40i
1. Definitely stop driving it with the jb4 enabled, that AFR is way too lean and is knocking.
2. Post your JB4 settings or attach the csv so we can see what they are.
3. Also, do you have a Jb4 bef? This is a flash tune that supplements the JB4 - it's not necessary, but just curious.
4. Also the cars ecu has a stock flash, right?
5. No other fails points if you're only planning to run map1.
- I would recommend an oil catch can to keep crap out of the intake. BMS sells one that is great.
6. Also, do you have the MAF sensor installed? I believe it's no longer needed, but can't remember if you also need to make an adjustment on the JB4 settings: "Plug 3 (MAF
sensor, purple) is no longer used for any application. If you have an older harness with a purple
patch on it you can cut it off the harness or tuck it out of the way unused. "
http://www.burgertuning.com/instructions/n55_stage1.pdf
X5 40i
      08-22-2018, 08:19 PM   #3
vtn86
Drives: 335i xDrive
1. Done
2. Not 100% sure which settings you want me to post - is this something that can be screen shot from the "settings" tab on the bluetooth app?
3. No BEF
4. Yes
5. Plan to do a few things in the future, but just want it to run well on basic settings first.
6. Yes on MAF sensor, would prefer to run it if possible.
Thanks for your response!
sd306380.50
      08-22-2018, 08:24 PM   #4
vtn86
Drives: 335i xDrive
I think you meant this for #2...
Firmware 5/17//1
Interface JB4 iOS 8461
Engine E Series - N55
TMAP_V 2
AvgIgn 5.3
DWP 50
MethTriggerMode 0
FF 66
MethSafeMode 2
MethAdd 0
MethScale 0
MethPSI 0
VIN ...2BNN22068
E85_Setup 0
VFF_Offset 132
fuel_30 10
fuel_35 20
fuel_40 20
fuel_45 30
fuel_50 35
fuel_55 40
fuel_60 40
fuel_65 40
fuel_70 40
BoostSafety 17
PID Gain 14
AutoShiftRed 20
Fuel_OL 0
FUA 0
1st_limiter 0
2nd_limiter 0
3rd_limiter 1
FUD 0
N20_TMAP 10
6CylMode 40
LastSafety 1
duty_15 0
duty_20 0
duty_25 0
duty_30 0
duty_35 0
duty_40 0
duty_45 0
duty_50 0
duty_55 0
duty_60 0
duty_65 0
duty_70 0
sd306380.50
      08-22-2018, 10:28 PM   #5
weehe126
Drives: 2017 340i
I think the N20_TMAP needs to be 0. Whatever it is for the stock sensor. N54tech would help you a lot more.
      08-22-2018, 10:59 PM   #6
vtn86
Drives: 335i xDrive
Moved it to zero. Seems to be a little smoother, but same issue still persists. Thanks for that!
      08-23-2018, 10:08 AM   #7
vtn86
Drives: 335i xDrive
Latest update. Changed all the user settings to default, similar results although overall the Tmap setting appears to have smoothed things out quite a bit. Will post updated log tonight.
      08-23-2018, 11:34 AM   #8
Mike@N54Tuning.com
Joint Chiefs of Staff
Drives: 2007 335i, 2015 M3
Seems like you are using ISO firmware with the non-ISO board. See directions on how to convert linked here:
http://www.n54tech.com/forums/showthread.php?t=13189
      08-23-2018, 01:05 PM   #9
vtn86
Drives: 335i xDrive
Thanks, Mike. Previous owner said it was already converted. I’ll read through and give it a shot.
      08-23-2018, 01:10 PM   #10
vtn86
Drives: 335i xDrive
Is it really just sniping the two diodes...?
      08-23-2018, 02:19 PM   #11
Turbod
Turbod's Avatar
Drives: 2014 E84 X1 35i M Sport
There is only one you need to cut. You don't have to remove it completely if you don't want to. Just cut one leg and bend it out of the way.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      08-23-2018, 04:21 PM   #12
vtn86
Drives: 335i xDrive
You guys are awesome. I’ll try and get to it soon, probably over the weekend and report back. Thanks!!
sd306380.50
      08-23-2018, 10:38 PM   #13
vtn86
Drives: 335i xDrive
Did the ISO mod. Not doing the safety trigger anymore. Here are the updated logs for Map 1 and Map 5 post ISO update. The AFR around just before 3k rpm are concerning but besides that, it appears we're in much better shape! I imagine this is something running a BEF should clean up unless there's something else you guys spot. Thanks for your help!
Map 1
https://datazap.me/u/vtn86/map-1-aft...log=0&data=1-4
Map 5
https://datazap.me/u/vtn86/map-5-aft...log=0&data=1-4
      08-28-2018, 09:01 PM   #14
sd306
sd306's Avatar
Drives: X5 40i
Your JB4 settings should match the ISO default settings here:
Also, again you need to remove the JB4 MAF connector on the JB4 from your MAF sensor as it's no longer used. You don't remove the stock MAF connector - you just leave it as if it was stock plugged in. See this video for more info. I set the video to start at 4:33 where they talk about this:
X5 40i
      08-28-2018, 09:07 PM   #15
sd306
sd306's Avatar
Drives: X5 40i
Map 1
Map 5
The AFR is still way too lean - stop pushing it. Match the default settings as I posted and don't use the JB4 MAF sensor plug (leave the stock one installed as it would be on a stock car).
Post your settings again - screenshots of each area of the app are fine or how you typed it out above.
X5 40i
      08-29-2018, 11:20 PM   #16
vtn86
Drives: 335i xDrive
I thought those were the flex fuel wires...here are the updates.
One thing I did notice immediately once I plugged the wires up like OE, is that the FP_H was hovering at 14-17 at idle/slow cruise rather than 4-7.
https://datazap.me/u/vtn86/log-15356...log=0&data=1-4
Firmware 5/17//1
TMAP_V 2
AvgIgn 6.7
DWP 60
MethTriggerMode 0
FF 100
MethSafeMode 0
MethAdd 0
MethScale 0
MethPSI 0
VIN ...2BNN22068
E85_Setup 0
VFF_Offset 132
fuel_30 10
fuel_35 20
fuel_40 20
fuel_45 30
fuel_50 35
fuel_55 40
fuel_60 40
fuel_65 40
fuel_70 40
BoostSafety 18
PID Gain 25
AutoShiftRed 60
Fuel_OL 60
FUA 0
1st_limiter 0
2nd_limiter 0
3rd_limiter 0
FUD 0
N20_TMAP 0
6CylMode 0
LastSafety 1
duty_15 0
duty_20 0
duty_25 0
duty_30 0
duty_35 0
duty_40 0
duty_45 0
duty_50 0
duty_55 0
duty_60 0
duty_65 0
duty_70 0
      08-29-2018, 11:51 PM   #17
vtn86
Drives: 335i xDrive
I wonder if I should go to the 5/15//1 firmware just to see what the impact may be...
      08-30-2018, 07:23 AM   #18
Mike@N54Tuning.com
Lastest log looks normal, AFR is how it's mapped out within the DME. Only way to richen it up if you wanted to do that would be to add the back end flash map but no need. Biggest issue I see is lack of octane, can you mix in E85 for more power on map5?
Mike
      08-30-2018, 08:41 AM   #19
vtn86
Drives: 335i xDrive
More than willing to do a BEF, but thought this JB4 should be able to run fine on its own. The latest log actually hit a safety with those wires not connected and the factory plug used. Will mix in some e85 once I’m comfy with the setup on normal fuel! Any thoughts around the fp_h readings?
Should I leave the plug undone or plug it back in...
      08-30-2018, 09:06 AM   #20
vtn86
Drives: 335i xDrive
Random thought, is there any way the Jb4 already thinks there’s a BEF and isn’t adjusting afr as expected?
Edit: never mind on this question.
      08-30-2018, 11:45 PM   #21
vtn86
Drives: 335i xDrive
Here's the latest...
BEF installed. Getting a little tiresome. Overboost safety. Any settings I should change with BEF?
      08-31-2018, 12:26 PM   #22
Mike@N54Tuning.com
You are over boosting, based on the settings you should not be. Photo of JB4 board itself? If you want better/faster advice you'd want to use BMS' support forum.
Mike
e90post
