E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > N55 Software Update
      08-20-2018, 05:15 PM   #1
rborane
Drives: BMW M4
N55 Software Update
My 2011 335 N55 is having random cold start surging issues where the idle will surge for a bit and rev on its own, and then eventually settle down to normal idle. I've read this is a common issue with 2011 N55's and that a software update from BMW is the fix.
If I flash the ECU with MHD, do I still need to update it through BMW, or does it essentially do the same thing and get rid of the surging issue?
      08-20-2018, 05:40 PM   #2
Turbod
Turbod's Avatar
Drives: 2014 E84 X1 35i M Sport
Unless MHD has changed from the original release they would be flashing your car to an older ROM. Could it fix the issue? Maybe. My guess is a dirty MAF or a MAF that isn't sealed correctly. Are you running the stock intake?
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      08-20-2018, 06:19 PM   #3
E92n55slo
Drives: 2011 e92 335 x drive 2016 m2(s
Mhd has an option cold cold start reduction or something like that, fixes the issues
      08-20-2018, 06:22 PM   #4
BourneJack
Drives: BME E90
+1
      08-20-2018, 07:11 PM   #5
rborane
Drives: BMW M4
Yes stock intake. This is the service bulletin I found. Maybe worth going to the dealer and presenting this?
I guess what im asking is even if BMW updates the DME, and then I flash MHD, does that overwrite the BMW update? Or will there be an updated DME still?
https://www.scribd.com/document/1519...T-Stalling-TSB
      08-20-2018, 10:15 PM   #6
Turbod
Turbod's Avatar
MHD flashes an older ROM. If you pay BMW to flash one it will flash back once you install MHD.
2023 G80 M3 xDrive
      08-21-2018, 12:19 AM   #7
maddmatth
New Zealand
555
Drives: F82 M4, E92 335i
I have a DCT and I do not have this issue with the MHD ROMs, both with and without cold start noise reduction. It's probably based on a ROM that already has this fix, considering that TSB is from 2013, long before MHD was released for N55.
      08-21-2018, 07:13 PM   #8
LiquidREVUP
LiquidREVUP's Avatar
Drives: 2011 335i E90 N55 6AT
Try cleaning MAF first
https://www.e90post.com/forums/showt...46#post8937746
Daily E90 N55 6AT:
VRSF 7’’ HD core FMIC | VRSF 2.5’’ Lower CP | VRSF 3’’ Upper CP | VRSF 3.5’’ Catless DP | BMS OCC | BMS Sport OCV | N20 TMAP | MHD E30 v1.51 beta | xHP Stage 3 v2.0 | 19” 351m wheels | M Sport springs | Bilstein B8 |
IG: @liquidrevup
e90post
