M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Crank Hub Issue
      08-16-2018, 12:31 PM   #1
FSU_Logan
Drives: 2019 M2C DCT
Crank Hub Issue
Title says most, what is the general consensus on the crank hub issue? I'm assuming no fixes have been put in play..
2019 M2C DCT | Alpine White
Full AA exhaust (catless DP/signature exhaust) | M Performance Coilovers | Need to find some new wheels!
      08-16-2018, 11:00 PM   #2
chris719
Drives: '08 M Roadster
They updated the bedplate at some point, who knows if it was related. The failure rate is very low, seems to mostly affect earlier production DCT cars that are tuned. A worry if you are going for big power maybe, none of the bolt capture mods etc. have proven to work 100%. Most reports seem to have this happen on the dyno or while almost lugging the engine (7th gear 2k RPM and a lot of throttle, etc.).
I have followed the E92 M3 forums since release and the F8x forums and the failure rate is way, way below the rod bearing issue for S65. I might think twice about tuning during the warranty period though.
      08-17-2018, 04:50 AM   #3
FSU_Logan
Lugging the engine on any car is dangerous, especially a turbod one. I'm pretty sure I'm going to tune it 2k miles after I get it. It looks like the realistic worse case scenario is having to re time the vanos (and replace the crank hub so it doesnt happen again).
Catastrophic damage damage could be scene of the car is continued to be driven/beat on but I dont believe the valves being bent is that common. If the issue itself is .5% of cars, I'm pretty sure only like 10% of those get the catastrophic damage. That's pretty damn rare.
      08-17-2018, 05:51 AM   #4
dmk08
Gone Fishin’
dmk08's Avatar
Drives: Walks
Its not a huge issue. As someone the bedplate was changed when the comp pack came out (in all S55) and it seemed to help.
IIRC its more prevalent on highly modified DCT cars. Some theories that the no lift shifts or kickdown can be factors.
      08-17-2018, 09:11 AM   #5
David1
David1's Avatar
Drives: 09 E92 09 X5
Someone with 2018 M3 with 2k miles had a spun crank hub. It's just luck of the draw.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
M2C_PLUS1774.00
FSociety3812.50
StavsM2C119.00
      08-17-2018, 11:23 AM   #6
FSU_Logan
That's why I'll break it in 2kish, haha
      08-17-2018, 09:41 PM   #7
ceedawg
ceedawg's Avatar
468
Drives: 2k15 335i xdrive MSport 6spd
Even happens on the N55s with Big HP 2k11 to 2k13
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2
      08-17-2018, 11:03 PM   #8
Lucky1
Drives: '08 128i Coupe SGM 6MT
And luckiest when you lose the draw within warranty I guess?
      08-18-2018, 08:00 PM   #9
hellrotm
Drives: F80
Yup, E/F series N55 and S55 share the exact same crank hub parts.
ceedawg467.50
FSociety3812.50
      08-19-2018, 08:30 PM   #10
akkando
akkando's Avatar
5865
Drives: 17 M2 DCT LBB,11 e90 M3 ZCP IB
On the f80 forums it seemed higher hp cars were more likely to have the issue, but could be coincidence.
      08-19-2018, 08:56 PM   #11
FSU_Logan
I saw multiple people state 100% stock cars had it happen, so I really don't know.
FSociety3812.50
      08-19-2018, 09:40 PM   #12
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Seen more reports on 2018 so far than 2017.
6MT 2 of them
DCT 3 of them
Stock & Tuned, mostly related to kickdown or moneyshift(6MT) and bad tune.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      08-19-2018, 09:51 PM   #13
akkando
akkando's Avatar
5865
Competition cars that are stock are running higher hp than non competition. The thread I was looking at seemed to indicate higher hp pre competition cars more likely to have issue. In later model years, street l after the comp pack suddenly more untuned cars had an issue than before, at least with the small data set in that thread. I assumed that because to had higher hp stock cars because of the comp pack.
      08-20-2018, 01:10 AM   #14
chris719
Well, it appears from searching on the other forums that many of the tuners working on really high powered cars (600+) have had issues with the crank hub and have had to work on measures to stop it, with varying degrees of success. It certainly seems to be exacerbated by power output when you get to those levels.
      08-20-2018, 01:12 AM   #15
chris719
Comp cars are making more power but not sure if they make more torque, they might actually make a little less early in the rev range. I think the sample size is too small to know though, as you mentioned.
      08-20-2018, 08:11 AM   #16
FSU_Logan
I'd be curious to see what the tuners would be altering.
FSociety3812.50
      08-21-2018, 12:37 AM   #17
chris719
I'd post the link but it's censored...
search Google for What-is-the-best-BMW-F80-M3-F82-M4-S55-crank-hub-solution-Comparing-Maximum-PSI-s-multi-piece-keyed-crank-hub-to-Gintani-s-single-piece
      08-21-2018, 07:26 AM   #18
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Torque down low mostly
IG: @bmwF9XG80
      08-25-2018, 08:40 AM   #19
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
As it should because the design is a carryover from the N55.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      09-06-2018, 10:00 AM   #20
Shankska
Shankska's Avatar
Drives: 2019 BMW M2 Competition
2019 BMW M2 Comp  [0.00]
2016 BMW M2  [0.00]
2014 BMW M235i  [0.00]
subscribed. I read a lot of the F8X forums about this. Seems most were DCT while using the kickdown. Also, a hand full of 6MT experience this, from possible money shifting? It definitely makes me more cautious of mine. Hopefully we dont hear of this happening on the M2C.
2019 F87 M2C, Long Beach Blue, Exec, 6MT
2016 F87 M2 - Sold 9/2018
2014 F22 M235i - Sold 5/2016.
      09-06-2018, 10:25 AM   #21
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
What I don't understand is how can you live without kickdown!
It's such a pain not being able to when every other bmw engine can.
      09-06-2018, 04:41 PM   #22
GerardzM
Drives: BMW M2
Damn, gonna read up on this....kick down on the DCT is pretty damn aggressive, which would be exacerbated with a tuned car!
Tags
s55
m2
