E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > 2c57 cel low boost
      07-27-2018, 05:32 PM   #1
Ghostisdead
Drives: 2011 335i M-Sport
2c57 cel low boost
Hi i drive a 2011 335i m-sport sedan and for the past week have been dealing with my car not having full power. I only have a jb4 and now I just installed the arm charge pipe. The car has less power always but only shows the check engine light at wot after a while. I thought it was the chargepipe but when I took it out it was perfect and it still didn't work properly after putting the metal one on. I have gone under the car and removed the intercooler to charge pipe plastic piece and that was fine too. I think it may be the boost solenoid but I'm not sure. The car is under boosting and normally on map five I'm close to 15 psi. Heres a log
https://datazap.me/u/ghostisdead/log...&data=1-3-4-36
      07-27-2018, 05:34 PM   #2
Ghostisdead
here's another one
https://datazap.me/u/ghostisdead/log...log=0&data=1-4
      07-27-2018, 07:51 PM   #3
xxMike61
xxMike61's Avatar
78
Drives: 2011 335i Coupe
I had the same issue with the JB4. Even ordered a new CP to see if that would help but nope. Ended up removing jb4 and boost came back. Never figured out what it actually was but it was with the JB4
2011 335i M-Sport E92
MHD E30 | Phoenix Racing CP | K&N Drop In Air Filter |Fuel-it Stage 2 LPFP | xHP Stage 3 | VRSF DP | ARM 5" FMIC + Hose Upgrades | GFB DV+ | VMR 19" v703
      07-27-2018, 10:10 PM   #4
Ghostisdead
Ill remove the jb4 and see if that fixes my problem thanks
      07-28-2018, 03:37 PM   #5
LiquidREVUP
LiquidREVUP's Avatar
Drives: 2011 335i E90 N55 6AT
Check for boost leaks or possible cracked DV. Also any other codes besides that one because a bad boost solenoid would throw a code.
Daily E90 N55 6AT:
VRSF 7’’ HD core FMIC | VRSF 2.5’’ Lower CP | VRSF 3’’ Upper CP | VRSF 3.5’’ Catless DP | BMS OCC | BMS Sport OCV | N20 TMAP | MHD E30 v1.51 beta | xHP Stage 3 v2.0 | 19” 351m wheels | M Sport springs | Bilstein B8 |
IG: @liquidrevup
      07-31-2018, 11:59 AM   #6
WeekendWarriorz
WeekendWarriorz's Avatar
670
Drives: 2006 Z4M
Bad boost solenoid
2006 Z4 M Roadster Black/Imola Red, FBO VF-Engineering, e85 Flex Fuel-Sold
2012 BMW 135i N55 DCT Alpine White/Coral Red, FBO, TBI, Full e85, JB4 BEF-Sold
2006 Z4 M Roadster Black/Black-Sold
2021 M2 Competition DCT Hockenheim Silver
      08-03-2018, 12:33 AM   #7
MTK24
MTK24's Avatar
Drives: 2011 335I X Drive
2c57 code could mean anything. I would get it when accelerating on the highway
I had no boost leaks and my boost solenoid was fine. The code only seems to appear on Map 0 or Map 1 with the jb4.
After staying in Map 5 it doesn't show anymore
Vermillion Red
      08-03-2018, 06:37 AM   #8
lwgrenier
Drives: 2011 e92 335i XDrive
Make sure you transferred over the O ring to the new charge pipe.
      08-03-2018, 10:35 PM   #9
Ghostisdead
I went swimming this weekend and lost my keys in a river and i only had one fob . Thats why I hvemt been able to try any of these things but when i get my car back im going to try changing the sollenoid. I bought the arm cp which comes with a replacement o ring which i made sure to oil up. It comes up in map 0,1,4 and 5 so its not map related it think. I will remove the jb4 and see if that does anything but I doubt it because it is targetting properly just not getting up there.
      08-10-2018, 11:09 AM   #10
korchen
Drives: 2011 e90 335i deep sea blue
Not sure if a boost solenoid is the same thing as a charging control module, however my mechanic just replaced the charging control module for $100 and it fixed the 2C57 code with my car; similar symptoms but my engine light came on between 2-3k rpms, medium throttle.
      08-11-2018, 12:23 PM   #11
WeekendWarriorz
670
Drives: 2006 Z4M
What is a charging control module? Is that the chargepipe? Change out the boost solenoid man if you're still getting CEL's at half throttle, happened to me on my previous 35xi
      08-11-2018, 07:19 PM   #12
Ghostisdead
Hi guys thanks so much for the help I replaced the boost solenoid with one from the n54 engine because it was cheaper and I had a guy selling it locally and it fixed my problem
Now my car runs better than ever. Im hitting 18.8 psi which seems a bit hit and wanted to see if you guys think there is anything off about this new data log that I took.
      08-13-2018, 11:29 AM   #13
lwgrenier
That log looks very strange. Maybe it's a JB4 thing. It says your boost target is around 12 but you're hitting 18 so something is up. Unless the ecu_psi is what I should be looking at.
      08-15-2018, 01:36 AM   #14
Ghostisdead
I think it was just map five learning my car, now when i get on it it starts at close to 15 and sliwly tapers off to like 13, which brings up another question how do people run like 18 psi flat what makes my boost taper off compared to others? Do they have upgraded turbos?
      08-15-2018, 06:12 AM   #15
lwgrenier
Upgraded FMIC and typically catless downpipe
e90post
