Passing Emissions without DP Fix *SOLVED*
07-27-2018, 07:27 AM | #1 |
Rep 124
I'm sharing this in hopes that saves other N55 owners time and money. I originally bought the o2 sensor simulator from Area54 a few years ago and it worked perfectly. I recently tried to use the DP Fix from VRSF, which is supposed to be the same, but after trying 2 different units I just could not get it to work. It would throw o2 sensor Delayed and Slow response codes, which prevented me from passing emissions.
I removed the fix, flashed the MHD Stage2 map and drove around for a week. I'm in MD, but many other states allow for 1 of the monitors to be "Unready" or "Incomplete". So I kept checking MHD until only one of the monitors remained that way. Passed just fine. Wish I had done that from the start. Last edited by jake1220; 07-27-2018 at 07:43 AM.. |
07-27-2018, 07:35 AM | #2 |
Rep 1,753
Thanks for sharing
My question is when you use MHD to not display the engine check light (Hide the code), what happens when you get other engine check light codes does it hide them too ? Codes that might be other issues ? |
07-27-2018, 07:42 AM | #3 |
Rep 124
It looks like the MHD maps disable the Post-cat o2 sensor all together. In the emissions check they are marked as "Not Available". MHD does not hide any other codes. You will get normal codes if need be.
07-27-2018, 09:28 AM | #4 | |
Rep 1,753
Do you see any other fuel trim or AFR related codes after the DP install ? |
07-27-2018, 09:37 AM | #5 |
Rep 124
07-27-2018, 11:19 AM | #6 | |
Rep 46
I am a little confused but in the same situation. I have an 2011 335i Xdrive N55 and got the VRSF DP fix- followed the DIY instructions thread that Tiago sent me and I had the same issues/codes that you described. Tiago just mailed out an replacement unit today as the first one did seem to be defective. I am flashed to MHD Stage 0 aka STOCK. This enables the 02 monitors etc. With flashed to Stage 2 or any other stake with catless downpipe it disables the 02 and Catalyst monitors I believe which would automatically FAIL the NY State inspection- unless I am missing something? Is there a way you can post a screenshot of your Monitors within MHD so we can see what they look like? Many thanks in Advance. |
07-27-2018, 12:09 PM | #7 | |
Rep 124
07-27-2018, 03:03 PM | #8 |
Rep 46
Yeah Evap can take forever to be in a COMPLETE State...
If you don't mind can you take a full screenshot of the MHD Window where it also shows what Tune/Stage you are running? Pretty sure when I was on stage 2+ Oxygen Sensor and Heater said Not Available and I want to say same with Catalyst. |
07-27-2018, 03:14 PM | #9 |
Rep 2,014
This has already been discussed in other threads and is not really new...I removed my o2 fix but I would recommend looking into the emissions requirements of your state since it varies.
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
07-27-2018, 03:23 PM | #10 | |
Rep 124
07-27-2018, 03:27 PM | #11 |
Rep 124
I actually never saw this mentioned here. My friend with an N54 told me to do it this way and it worked. My point is to show that the DP fix/O2 Sim is unnecessary. I did not have it installed when I went through emissions.
Johnny Boost323.50 |
07-27-2018, 04:11 PM | #12 |
Rep 46
Thanks Jake- I guess I will give it a shot.
But wouldn't Not Available for Catalyst and Heated Catalyst be like an automatic fail if says NOT AVALIABLE? Anyone familiar with NY State inspections- feel free to chime in |
07-31-2018, 07:38 PM | #15 |
Rep 46
Just wanted to take a minute and post my experience.
After having doubts about Jake's success and since I was in the same situation... I took out the DP Fix (Box) and flashed the car back to MHD Stage 2+ which obviously reset all the monitors. Drove for 15 miles and the only 2 not ready were EVAP and Heated O2. Let the car sit overnight- fired up in morning (cold start) and Heated O2 was ready as well. So I just had 1 Monitor not ready which was EVAP. Catalyst and Heated Catalyst say NOT AVALIABLE. Took it to get inspected and it passed just fine. So to sum it up- if you have an N55 engine with Catless DP and MHD Tune- you do not need a DP fix. I lost 3 weeks on and off playing with the O2 Simulator (DP Fix) which just did not work for my car. I no longer even get the codes about O2 sensors which it was throwing with the DP Fix in the car. Jake1220- thank you once again for sharing your story. I was able to replicate and don't have to worry about inspection until 7/2019 |
08-01-2018, 01:01 PM | #16 |
Rep 321
In Ma for example, if Catalyst is in the "Not Available" state it is an automatic fail. MHD has to be checked to the OEM/catted downpipe option before flash to enable the rear o2 sensor. If people in states like Ma don't have the dp fix, just make sure you do a couple EXTREMELY light driving cycles and you might be able to get the Catalyst to read ready. Coming from Audi, that is how we pass emissions since there is no fix for it. Spacers are used to take the sensor out of the direct path of the exhaust flow. I am not sure why a few people are having such a hard time with these fixes though. It is understandable if you get a faulty box. There shouldn't be any problem if the directions are followed step for step. People also need to make sure to buy the positaps listed in the instructions. Mine worked flawlessly and I still have mine installed after 7 months without any issues.
Current: 2011 BMW 335xi | Wedge Tuned | Meth | VRSF DP | VRSF 5" Intercooler | VRSF Chargepipe | BMS Intake | xHP Stg 3
Totaled:2014 Audi A4 CTS K04 APR Tuned |
08-02-2018, 09:08 AM | #17 | |
Rep 46
08-02-2018, 09:32 AM | #18 | |
Rep 1,354
MD does require that catalyst readiness be true but you may have tested at a facility that does not monitor it. I when through the cat issue in MD even with high flow cats. |
03-11-2019, 06:54 PM | #19 |
Rep 19
Wait.. What?? I have an E82 2013 (N55) with MHD Stage 2+ map and got the check engine light because of the catless DP.. I always untick the catted DP option when coding.. I was so sure that MHD didn't take care of catless DP CEL light...
10-18-2022, 08:49 AM | #20 | |
Rep 12
Sorry to Necro the shit out of this but I’m having this issue now. Will this work with JB4 and an MHD backend flash? Or do I have to drop the JB4 and just go with MHD? Thank you. |
