BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    F90 JB4 - 10,8s
      07-18-2018, 03:54 AM   #1
Maltman
Maltman's Avatar
Germany
230
Drives: BMW M4
2014 BMW M4 F82  [0.00]
F90 JB4 - 10,8s
Hey Guys,
first 1/4 mls results. Last weekend at Asphaltfieber meeting, the F90 from Aulitzky Tuning made a solid 10,8s on JB4 Map3 (102 Pump Gas)
      07-18-2018, 05:44 AM   #2
felixleasing
Drives: 2018 M5
If my eyes serve me correctly looks like a bad 60ft which means your car has a faster pass in it!!
      07-18-2018, 06:38 AM   #3
onfireX5
Drives: F90M5,F85X5M
Excellent ! No prep either. It will be quicker / faster on a prepped track. Good job.
      07-18-2018, 07:46 AM   #4
somer
Drives: F10 M5 CP
also 134 trap speed, incredible!
      07-18-2018, 08:55 AM   #5
felixleasing
Drives: 2018 M5
Possible mid 10s car with just a TUNE
      07-18-2018, 06:49 PM   #6
koko f90
Drives: bmw m5 f90
You right
I did 1.6 and I bet I can do better I need to practice a bit
So he should do way better
      07-18-2018, 08:23 PM   #7
///M ARMY
Drives: F90
and this is the only the beginning.
2022 RAM TRX
2021 Ford Bronco
2022 BMW M3
      07-19-2018, 01:16 AM   #8
Maltman
Maltman's Avatar
Germany
230
Drives: BMW M4
Originally Posted by koko f90 View Post
You right
Hm it’s the best 60ft from all?! On map3 car had wheelspin on all 4 wheels
      07-19-2018, 11:06 AM   #9
felixleasing
Drives: 2018 M5
Doing the break in service then taking to the track soon.
Then I will go back with a tune
      07-26-2018, 12:18 AM   #10
felixleasing
Drives: 2018 M5
Break in service done feels great!!
      07-29-2018, 12:42 AM   #11
Speedwell-Industries
Speedwell-Industries's Avatar
Drives: 2017 YMB M3
That is fast!!!
      07-29-2018, 10:21 PM   #12
TTHURACAN
Drives: Lamborghini
Didn’t C&D do 10.9 stock? A tune for .1s gain hardly seems worth it. However the increase in trap speed is certainly a plus from a roll....
      07-29-2018, 10:24 PM   #13
onfireX5
C&D is corrected to sea level. Be curious to know the OP’s altitude. That mph shows he was spinning.
      07-30-2018, 11:08 AM   #14
TTHURACAN
Drives: Lamborghini
He is running the NA equivalent of ~96 octane and map3....
      07-31-2018, 09:19 AM   #15
Imran@Evolve
Imran@Evolve's Avatar
Drives: All of them
You can't really compare unless it on same track and in same conditions. The best I could do was 11.6 stock without LC. Even with LC I can't see getting down to 10.9.
      07-31-2018, 10:29 PM   #16
TTHURACAN
Drives: Lamborghini
I know , no one seems to be able to replicate C&D numbers for the M5, it was the same thing for the Huracan...
      07-31-2018, 10:32 PM   #17
TTHURACAN
Drives: Lamborghini
He did post above that all 4 wheels were spinning on map3....
      07-31-2018, 11:21 PM   #18
M5speed
Drives: 2020 BMW M5
Whats a man gotta do to get this thing to 10.5?
Itd be nice to see the full picture of intake, downpipe, tune, exhaust. I dont think were going to get there the way its looking.
      08-01-2018, 07:56 AM   #19
TTHURACAN
Drives: Lamborghini
The trap speed @134mph is plenty powerful to achieve a 10.5, the issue is wheelspin. First step is to lower tire pressure, if that does not work, swap the stock rubber for drag radials....
      08-01-2018, 08:20 AM   #20
M5speed
Drives: 2020 BMW M5
Great idea. I was meat-heading it at the track then. Couldn't get l/c to work and the track seemed to prevent me from "hooking" as they say.
      08-01-2018, 08:48 AM   #21
onfireX5
My stock 11.2 runs at 4000ft has perfect traction. I hear one chirp from the rear tires and then it plants hard and goes. On stock radials it will take more power, but at some point it will cross over into wheel spin and you’ll lose ET on stock tires. I’m at 20.5psi peak stock now. I’d like to try 23psi down the road. Have you logged the psi on The TDI ?
      08-01-2018, 06:44 PM   #22
Sheharyar_rr
Drives: 14' 335xi M-Sport
The car is well capable of doing 10's in stock configuration... you just need to know what you're doing. I pulled off 11.3 @ 121 repeatedly with Jb4 on the M550i. Granted the gear ratio's are slightly taller but F90 has more power to offset that too
2021 M5 Competition | Imola red
2020 Z4 M40i | Misano blue Pure850/PI/LPFP
Gone: 2018 M550i xDrive | DME Tuning BEF / JB4 / BM3 / DPs | 10.95 @ 125 1/4 Mile
Gone: 2014 335i xDrive | Bootmod3 Stage 2 93 Map | 12.2 @ 113 1/4 Mile
m5post
