E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > JB4 ISSUES
      07-17-2018, 08:53 PM   #1
jaytes
Drives: 2011 335ix M-sport
JB4 ISSUES
Hi recently purchased a JB4 from some online (E-N55) I have 2011 335ix. I am pretty confident I have installed it correctly. The car starts up fine and no error codes. The issue I am having is that I cant map. The volume down and minus buttons dont do anything. Also, I have tried to attach the JB4 to a laptop and not getting a connection. Is it a bad board or the wrong JB4, I noticed in marker there was something written like F-n55 on the casing.
Would purchasing a new/correct board be my best option?
the board installed says "Burger Motorsport, LLC --N55 Stage 2 Rev 1.0"
...might cut my loses and go for an MHD.
      07-18-2018, 02:07 PM   #2
Azines
Drives: 2012 E92 335i Xdrive
I would send pictures and contact BMS for the best solution. Are you sure it was installed correctly? Do you get a gauge sweep on startup?
      07-18-2018, 02:53 PM   #3
orteeze
Drives: 2018 YMB F80
I'll give it a shot..
Pop open the case and verify the diode is cut so you can load the latest ISO firmware. Follow these directions:
First try to establish connection with the JB4 via USB
If using Windows go to Control Panel>Device Manager to locate what COM port the JB4 data cable.
Go to your JB4 Inerface>settings>Available Ports and select the correct COM port.
If connected, update the firmware to the latest revision found here for E Series JB4 located on Post#2.
http://www.n54tech.com/forums/showthread.php?t=13189
If you updated successfully, enter default settings per ISO firmware notes.
All PWG N55 boards are the same for E and F series N55 cars. If it says F on the case, most likely it's the wrong firmware loaded. It'll work as long as the correct firmware is loaded.
2008 MB 335i-SOLD
2011 AW 335i M Sport- SOLD
2011 BSP 335i-SOLD
2011 BSP 335is- FOR SALE
2018 YMB M3- Current
      07-18-2018, 03:01 PM   #4
jaytes
Hi orteeze,
Thanks for the info, my diode is not cut. I have tried connecting it to a laptop but no luck, failure to communicate with the comm, I tried it on different ports and 2 laptops. Does it need to be a BMS RS232 cable, i just picked one up at best buy..
      07-18-2018, 03:10 PM   #5
jaytes
Hi Azines,
I sent pics through a forum, waiting to hear back. I am pretty confident it was installed correctly. I honestly didnt notice.. i will check later today.
Thanks for your input!
      07-18-2018, 03:31 PM   #6
Soden82
Drives: 2011 BMW M3
2011 BMW M3  [0.00]
My guess is that you bought the wrong harness type for the jb4. Sounds like you have an e series n55 and may have gotten the version for the f series car. Definitely send a picture to burger first before spending unnecessary money on trying to fix the board
2009 BMW 335i 6MT
*big single (eventually)*
For now...
MHD tuned
VRSF Race IC
DCI
ATM exhaust
      07-18-2018, 03:42 PM   #7
orteeze
Hi orteeze,
BMS data USB is not a standard RS232 cable. It requires a 5v TTL leveling cable. Just buy one from BMS. I bet it's got the wrong firmware on the board.
I might have one laying around I could sell you.
2008 MB 335i-SOLD
2011 BSP 335i-SOLD
jaytes5.00
      07-18-2018, 03:44 PM   #8
orteeze
Harness between E and F are identical except the CAN cables go to the DME ( I know, there's no DME in there) on E series instead of the OBD2 port on F series.
Ask me how I know
2008 MB 335i-SOLD
2011 BSP 335i-SOLD
      07-18-2018, 09:00 PM   #9
jaytes
Thanks for the info orteeze, I just purchased a cable from them and will test it out!!
Soden82478.50
      07-18-2018, 10:05 PM   #10
Soden82
Drives: 2011 BMW M3
2011 BMW M3  [0.00]
Ask me how I know
I have a feeling the car gods weren't with you that day
2009 BMW 335i 6MT
For now...
MHD tuned
VRSF Race IC
DCI
ATM exhaust
      07-18-2018, 10:09 PM   #11
orteeze
In fact, they were. Shorten the CAN cables and tap at DME and update firmware.. done.
      07-20-2018, 10:42 PM   #12
jaytes
thanks man!!! it's working.
      07-23-2018, 06:00 PM   #13
Omar335in55
Drives: 2012 335i coupe xDrive
How are you liking the jb4?
      07-23-2018, 11:42 PM   #14
Azines
Best $500 you will spend on your car.
      07-24-2018, 08:10 AM   #15
jaytes
He is aint lying. I love it and will be adding a VRSF FMIC/Charge pipe and down pipe this weekend!
best mod I ever spent money on.
      07-24-2018, 08:11 AM   #16
jaytes
Love it! Looking to go full bolt on this weekend.
      07-24-2018, 11:26 AM   #17
orteeze
Was it just the firmware?
      07-24-2018, 03:37 PM   #18
Omar335in55
If you add catless downpipes does it burble at all?
      07-24-2018, 05:56 PM   #19
jaytes
yeah it was, once I got the cable from BMS, it connected and uploaded the latest firmware:
N55_ISO_5_17_T5.hex
Didnt have to clip the diode.
      07-24-2018, 05:58 PM   #20
jaytes
I have not heard one first hand and hoping to install it this weekend. I will keep you posted.
Tags
controls, jb4, n55
e90post
