E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > xi Drive Shaft/Oil Pan Leak
      06-22-2008, 10:41 PM   #1
GarySL
GarySL's Avatar
1471
Drives: 2006 Carrera 4S
So does anyone have experience with this? I understand the industry standard design engineers the front drive shaft through the oil pan to maintain clearance. What appears to be a small oil leak has developed in my car @ 1,800 miles. The leak is occurring where the shaft enters the oil pan. The techs at the dealership diagnosed that the o-ring seal was mis-aligned and needs to be replaced.
I was sent home with the car until they can get parts. I've not heard of this on any forum & the SA said the same (although I gather it's a common refrain in the service dept of absolute shock that a problem has developed in one of their new cars). Thanks.
'08 335xi (E90), 6MT, Arctic/Black, ZPP, ZSP (18"s), ZCW, CA, PDC, i-Pod
Ordered-March 7, 2008, Shipped via Graceful Leader-March 21, 2008,
Arrived Port Hueneme-April 11, 2008, Delivered-April 21, 2008
      06-27-2008, 02:44 PM   #2
sparkyg
sparkyg's Avatar
Drives: work truck
First I've heard of it. I've been on here since last fall.
      06-27-2008, 03:04 PM   #3
cadbimmer
BeeeeYaaaaa
Drives: 335xi
Dont think anyone is experiencing leaks cause i had my front diff leaking and it was a front seal but no one else , even the dealership, had heard or seen one leak. Good luck man
      07-07-2008, 05:17 PM   #4
GarySL
GarySL's Avatar
1471
Leak fixed
So it was a relatively easy fix that took approximately 2.5 hrs. Similar to cadbimmer, the dealer SA or tech had not seen this previously.
They removed & replaced the leaking o-ring at the engine oil pan and front drive axle housing, which included removing the front right axle. The axle housing was removed & cleaned and front differential was then filled with new differential fluid. Four parts were replaced including the front shaft seal lock ring, o-ring, self-locking hex nut & collar nut.
Estimated cost would be ~$800.00 but was replaced under warranty. Thanks to all and trust this issue is past and was simply a day w/o my wheels.
      07-07-2008, 06:01 PM   #5
pdjafari
pdjafari's Avatar
152
Drives: Axe Murderer with headlights
I had this problem around 3k miles. Took the car to the dealer they said input shafts on both sides (o rings) tend to be misaligned from factory on the XI models. You wont see this problem on the I. Just do a search on 'oil leak' and you will see my thread w/ pics and some other guy who had the same problem!! I think they also change the 'mechatronic seal'
      07-08-2008, 02:08 PM   #6
pdjafari
pdjafari's Avatar
152
Gary,
Here you go man!! Take it to the dealer, I was scared b/c my car was new but the dealer said its common w/ the XI!! They fixed it and after 4-5k miles I havent seen another drop!!
Here is my thread w/ pic's
http://www.e90post.com/forums/showth...light=oil+leak
And here is a thread I referenced!!!
      07-08-2008, 02:28 PM   #7
sparkyg
sparkyg's Avatar
Drives: work truck
Thx for the info guys.
      07-08-2008, 08:26 PM   #8
scooby9
scooby9's Avatar
Drives: 2007 E90 BMW 335xi
Although the car has been glitchy, the warranty service is awesome. I just got my driver side mirror repaired, the starter replaced, the transfer case servo motor replaced, and the door lock mechanism repaired... lol
I can't even imagine the cost if it wasn't for warranty!
2007 BMW 335xi 6MT TiAg
      08-05-2009, 03:10 PM   #9
dmooreco
Drives: X3
I have this same problem in a 2009 335i xDrive 2200 Miles, a week to order an O-Ring??
2009 335i xDrive/Le Mans Blue/M-Sport/Prem/Nav/HD/Sat/Alum
      08-05-2009, 04:46 PM   #10
JeffL
JeffL's Avatar
35
Drives: C63
Originally Posted by pdjafari View Post
Gary,
the pictures from your thread, where are they taken from. Or what part of the car did you find the oil on? I can't tell from the pictures.
no sig.
      08-12-2009, 11:22 AM   #11
pdjafari
pdjafari's Avatar
152
If I recall, it was the central rear portion of the transmission housing. If you look under your car, you'll see the silver housing with 2 holes which I believe are towards the rear of the car.
      08-12-2009, 01:49 PM   #12
JeffL
JeffL's Avatar
35
Drives: C63
thank you. Will give a check.
no sig.
      08-12-2009, 02:45 PM   #13
pdjafari
pdjafari's Avatar
152
Originally Posted by gofast! View Post
Hmmm good to hear they fixed this under warranty, but I'm concerned that they may not cover this for those of us who have installed coilovers on our cars. Any thoughts?
I dont see how coilovers or springs or suspension mods could cause the o rings or the mechatronic seals to come undone. My SA told me its common on some XI models for this to happen
e90post
