E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Mods to support E30 or more?
      07-11-2018, 10:00 AM   #1
eyehategod
eyehategod's Avatar
41
Drives: 2012 335i Xdrive (E92)
Hey all, I've never been able to find a really clear answer about this. Can our cars run the MHD E30 map without modifying the fueling system or anything else? I've got FMIC, Charge Pipe, Catless DP and I'm on MHD Stage 2+ but I'm interested in running E30 for the power gains, and also because during the 2 days I was on the E30 map previously, my car had never idled so smoothly and ran so nicely. It even solved timing correction issues I get when I do logs.
What's safe for E30? I've heard some people say with the map we can run E30 on stock parts, while my mechanic told me without upgrading my fueling system I'd just be on borrowed time. What about something higher, like E50? Fuel-it sells kits for Flex Fuel, Fuel Lines, Fuel Pumps and Fuel Injection, and I really don't understand which kit is necessary or any of them at all?
And when I die, make sure you spread my blood on a BMW
2012 E92 335i xdrive | KW V1 Coilovers | ER Chargepipe | VRSF 7" HD | VRSF Catless DP | MHD Stage 2+ | xHP Stage 3
      07-11-2018, 11:46 AM   #2
biz77
Drives: 2021 X3 M40i
As long as your low pressure pump and high pressure pump are in good working order, early N55s have no issues running E30 on the stock turbo.
JB4N78.50
      07-11-2018, 12:53 PM   #3
weehe126
Drives: 2017 340i
I used to run E40-45 on the stock turbo and max it out. You will have no issues running E30 and you will not be on borrowed time for your fuel pumps. This assumes you have a 2011.
      07-12-2018, 10:29 AM   #4
eyehategod
eyehategod's Avatar
41
You both mentioned early N55's, did the design of the pump change later on? Mine is a January 2012 build
      07-12-2018, 11:17 AM   #5
ap485
Drives: 2011 BMW E92 335i
N54's and early 2011 N55's uses a rotary pump. Post 2012 N55's uses plunger pump.
2011 E92 335i | ABR N55 Built Engine | 6HP19 Built Trans | Speedtech Kit BWS369 Turbo | Radium Eng FHST | EOS Manifold + PI | Reflex | E85 | MHD Tune by Wedge
      07-12-2018, 11:18 AM   #6
eyehategod
eyehategod's Avatar
41
So with an early 2012 build I shouldn't plan to run E30 without upgrading the pump? Just the LPFP?
      07-12-2018, 11:21 AM   #7
Kevin39
Drives: 2011 E90 N55
It's not the LPFP that's the problem
      07-12-2018, 11:23 AM   #8
eyehategod
eyehategod's Avatar
41
What is it then? Just trying to figure out exactly what's needed to safely and reliably run an E30 or higher blend.
      07-12-2018, 12:12 PM   #9
Turbod
Turbod's Avatar
Drives: 2014 E84 X1 35i M Sport
According to realoem.com they made the change in March of 2012 which would mean you have the older higher flowing HPFP. An easy way to tell is the DME. If you need a bench flash then you have the new HPFP. No changes would need to be made with either HPFP you have. I have not heard much from MHD in regards to the new DME/HPFP and their E30 map. Trying to create a tune that fits all or most applications means they wouldn't push boost to the limit. I would assume they would bump timing up quite a bit to make more power on lower boost.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      07-21-2018, 12:26 PM   #10
E90joee
Drives: 2011 335i xdrive
Isnt it suggested to upgrade fuel pump?
      07-22-2018, 11:14 PM   #11
Turbod
Turbod's Avatar
No reason to unless you're needing more fuel than it can provide.
2023 G80 M3 xDrive
      07-22-2018, 11:17 PM   #12
E90joee
Hmm i guess ill try e85 tomorrow
      07-23-2018, 12:39 AM   #13
Turbod
Turbod's Avatar
E30 is really the sweet spot. If you're running the JB4 without a BEF that will be the limit with that tune. If you're running MHD only they have a E30 flash. There really isn't a need to go past E50 unless you're maxing out a larger turbo and have supplemental fueling.
2023 G80 M3 xDrive
      07-23-2018, 12:41 AM   #14
E90joee
Oh didnt know, i am running MHD only but i dont know where they have E30 in NY E85 is more accessible
      07-23-2018, 01:09 AM   #15
Turbod
Turbod's Avatar
E85 is 85% ethanol blended with pump gas. You would need to estimate how much pump gas to mix with ethanol to get to E30.
http://www.georgebelton.com/E85Calculator.php
2023 G80 M3 xDrive
      07-23-2018, 01:11 AM   #16
E90joee
Thanks for that
      07-23-2018, 07:19 AM   #17
tyson413
Drives: 2012 bmw 135I
There is one gas station by JFK airport that has E85
      12-06-2020, 04:06 AM   #18
E92only
E92only's Avatar
Drives: 2011 E92 335i 6MT M-Sport
Hey guys how do you like the MHD e30 OTS map? I'm getting some timing corrections that I'd like to fix. Plus I just recently installed a new HPFP on my 2010 build N55. How are the power gains compared to 91 ACN?
2011 E92 335i 6MT | MHD | AA FMIC | AR Design DP | ER CP | PE | AutoSolutions SSK | SouthBend Stg3 | MFactory SMFW | Bilstein B14 | M3 Arms | -2.75° camber |
2020 Porsche Macan S PASM
      12-06-2020, 12:47 PM   #19
Turbod
Turbod's Avatar
E30 is a noticeable jump over 91 octane. I haven't ran any of the OTS maps so no feedback there. If you have some timing corrections then I would add just a little more E85. How are you verifying your mixture is E30?
2023 G80 M3 xDrive
      12-06-2020, 12:55 PM   #20
E92only
E92only's Avatar
I'm using an online fuel mix calculator. If I use 4 gallons of e85 and 12 gallons of 91 I come to a blend of e29. Do you recommend a better method for calculations?
      12-07-2020, 05:12 PM   #21
Turbod
Turbod's Avatar
If you're running into timing corrections then I would just mix a little more ethanol than you have been previously. Your fuel trims should be able to make up for the difference and the higher ethanol content should provide more knock suppression. I'd do your calculation based on E35 and see what that looks like.
2023 G80 M3 xDrive
e90post
