E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Bms intake for n55 e9x, any problems?
      06-27-2018, 11:10 PM   #1
Slavsky
Drives: 2011 335i x drive
I can't seem to find a clear answer but every time I look at reviews of any aftermarket intake for n55 some people say it gives them no issues with coding and some say it gives them all sorts of issues. I just want to ask directly. Does anyone here have an n55 E9X with an aftermarket intake (or specifically what I'm looking at, BMS)? Have you had any issues with it what so ever? Or is it stress free?
Thanks for any input!
      06-27-2018, 11:32 PM   #2
Toome
Member
Toome's Avatar
Drives: 2012 E92 335i M-Sport
I had issues with my BMS intake and removed it. My idle was off. I believe you can fix this with maf scaling, but I've had a much better experience with the stock intake on MHD Stage2+.
12’ E92 335i 6AT - Alpine White M-Sports Package
Mods - | MHD Stage2+ ACN91 OTS Map | K&N Drop-in | VRSF Kittenless D0wnpipe | VRSF CP | VRSF 7” FMIC | xHP Stage 3 | Euro Headlight Switch | Avant Garde M359 | Michelin PS4S
      06-28-2018, 03:05 AM   #3
xxMike61
xxMike61's Avatar
78
Drives: 2011 335i Coupe
Honestly, the cons out weigh the pros with the only real pro being it sounds cool. It's basically a hot air intake.
2011 335i M-Sport E92
MHD E30 | Phoenix Racing CP | K&N Drop In Air Filter |Fuel-it Stage 2 LPFP | xHP Stage 3 | VRSF DP | ARM 5" FMIC + Hose Upgrades | GFB DV+ | VMR 19" v703
      06-28-2018, 07:59 AM   #4
Slavsky
What issues did you have with yours exactly, I just wanted a more aggressive sounding spool but if it's gonna idle weird and throw codes then I'm not gonna even bother
      06-28-2018, 08:33 AM   #5
OneMoreAlex
OneMoreAlex's Avatar
45
Drives: 2012 e92 335i
Had the same issues as Toome, went back to stock with drop in filter and it's been great since. BMS does sound nice, but not worth the frustration that comes along unless you plan to fix maf scale.
12' 335i
| CP-E CP | MHD | VRSF DP | ALPINA B3 |
      06-28-2018, 09:37 AM   #6
ap485
Drives: 2011 BMW E92 335i
Well, I didn't experienced any issues while I was running the BMS intake for three years. The first year I run it with JB4 alone and two more years later with PS2, JB4+MHD BEF.
2011 E92 335i | ABR N55 Built Engine | 6HP19 Built Trans | Speedtech Kit BWS369 Turbo | Radium Eng FHST | EOS Manifold + PI | Reflex | E85 | MHD Tune by Wedge
      06-28-2018, 11:05 AM   #7
SnapCoupe
BMW Portland
Drives: Z4M Coupe/E90 335i
I have had a BMS intake for just under a year now and I haven't had any significant idle issues. Sometimes at warmer temps, when coming to a stop the idle will dip to 450-500 rpm for a second and then pop back up. Though, it would never feel like it was going to die and never created more NVH when it did drop.
I personally enjoy the BMS intake for the character it gives the car. Combined with my exhaust setup, the car makes some fantastic noises and really helps to create a unique experience whilst driving spiritedly. I think it is well worth the $200 or so price of admission.
2011 335i N55/6MT/M-Sport
MHD Stage 2+, VRSF Downpipe, VRSF 7" FMIC, BMS Intake, BMS Chargepipe, Performance Exhaust Mod, F10 550i Clutch, BMS CDV, BMW Performance SSK, M3 Control Arms, ST Coilovers, Apex ARC-8 wheels, Michelin PS4S
      06-28-2018, 12:39 PM   #8
Toome
Member
Toome's Avatar
My issues were minor as you described. I loved the sound, but saw an increase in IAT's compared to the stock intake after prolonged sessions of hard driving. It has been proven many times that sucking air from the top of the engine can become a hot air intake. IMO go for a more expensive intake that sucks clean air in from the front (like Injen or AFE) or keep your stocker.
      06-28-2018, 01:26 PM   #9
ShaneN55
Member
Drives: BMW M3
2011 BMW 335i  [0.00]
1966 Mustang  [0.00]
Glad this thread is coming up, hopefully more people can talk about this. Air intake was next, figured new turbo might as well. Haven't found a clear answer on the best intake available.
E92 M3, 958 Cayenne S, 1966 & 1968 Mustang @ 958.shane
      06-28-2018, 02:19 PM   #10
Welcome to NBA Jam
Is it the shoes!?
Welcome to NBA Jam's Avatar
3884
Drives: (Sold) 2011 E92 335i ZMP 6MT
I used an aftermarket intake, removed it, and sold it. It caused a check engine light (lean condition), and hesitation at 3k RPM. It was an aFe Magnum Force Stage 2 Si. I tried in two cases: removed the aftermarket intake, installed the stock intake. All performance symptoms disappeared immediately, and the CEL would disappear after 3 drive cycles. Removed the stock intake, installed the aftermarket intake: symptoms and CEL returned.
Coupled with past experience on different intakes, I concluded that aftermarket intakes are a waste of money, and I'd rather spend that money on mods that make a noticeable difference in reliability and performance.
I used that money and bought a charge pipe, and put the remaining towards MHD.
      06-28-2018, 02:56 PM   #11
SnapCoupe
BMW Portland
I bought my intake with my first set of mods as it was cheaper and considering this was my first turbo car, I wanted to get into the "woosh woosh" gang as soon as possible.
I never did any data logging with the stock box, so I don't really know what my IAT differences would be between the two. I still have my stock box, so I might throw it on just to see what kind of difference it would make. Do the Injen/AFE or any other more "closed" intakes have a significant reduction in noise compared to the open style BMS?
      06-28-2018, 03:03 PM   #12
Toome
Member
Toome's Avatar
You'll see a small difference in IAT's, and even more so when it's hot out. As far as the sound, I couldn't tell you because I haven't heard them in person. Although in videos they are still pretty loud.
      06-28-2018, 03:36 PM   #13
mike@x-ph.com
BimmerPost Supporting Vendor
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
Our most popular intake for this car, sounds great, no issues.
We have 10 customers reviews on this product, all 5 stars
https://x-ph.com/sale/
Phone number 702-494-9435
      06-28-2018, 05:17 PM   #14
Turbod
Turbod's Avatar
Drives: 2014 E84 X1 35i M Sport
The only "issue" I have with my BMS intake is that the little holder that secures it to the bottom of the stock airbox didn't fit correctly. I do agree that the IATs get hot when sitting still and I have never taken it off to monitor the temps with the stock unit. I figure when running 20+ psi that using the stock box will be leaving a little bit of power on the table.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      06-28-2018, 06:55 PM   #15
Slavsky
Wow! Thanks for all the responses guys this information really helped. Since it's relatively cheap Im just gonna go ahead and order it. If it does end up giving me any issues, then I guess lesson learned lol.
      06-28-2018, 07:48 PM   #16
Kevin39
Drives: 2011 E90 N55
Yeah that thing is pretty silly. But other than that, I've not had any issues either.
      06-29-2018, 10:04 AM   #17
NRigs
Drives: 2011 BMW 335xi
I have had the BMS intake on for 36,000 miles with no issues. Just make sure you order a filter cleaner to clean it every now and then.
Current: 2011 BMW 335xi | Wedge Tuned | Meth | VRSF DP | VRSF 5" Intercooler | VRSF Chargepipe | BMS Intake | xHP Stg 3
Totaled:2014 Audi A4 CTS K04 APR Tuned
      06-30-2018, 10:40 AM   #18
turo
Drives: Yes
2011 BMW 335i  [8.40]
2024 BMW M2  [9.00]
2018 BMW 340i XDrive  [10.00]
Been running it with a JB4 for a few years now, no issues. I did see slightly higher IATs in the summertime in stop-and-go traffic(stock intercooler too), but that's it really.
I'm ashamed to say that I got it for the way it sounds.... and I'm very happy with my purchase
      06-30-2018, 01:05 PM   #19
Johnny Boost
Drives: '21 M850i GC
I personally never had any issues with the BMS intake. Make sure to get a recharge kit so that you can clean and oil it periodically.
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3
Michelin PSS | M3 Control Arms
LUX v4 LEDs | Shadowline Grills | Lip Spoiler
      07-03-2018, 07:42 AM   #20
NRigs
I just cleaned mine with the kit yesterday. It looks brand new.
      07-03-2018, 08:08 AM   #21
Cchristianh20
Drives: Bmw 335i n55 e93
2011 BMW 335I  [0.00]
I just ordered that intake im a little worried now I haven been able to install it because im deployed do you know why it would throw codes??? I don't have a tune not running jb4 or mhd
      07-03-2018, 11:01 AM   #22
NRigs
When installing, I would make sure the MAF is screwed in and seated properly as well as connected. People have gotten codes and figured out they forgot to plug the MAF back in. Also, when handling the MAF, make sure you don't damage the sensor that sticks into the intake.
e90post
