BMW M3 Forum (E90 E92)
      06-19-2008, 04:43 AM   #1
MDCTFTW
Drives: E92 DCT
Arrow DIY: E92 M3: OEM Alarm Install
Much of this is the same as the install for the regular 3 series, but I thought it'd be nice to get some pics of an install on an M3. Our install is actually easier than the regular 3 series because we already have the hood switch sensor installed. Here goes ...
Assumptions (I won't go over how to do these):
- You know how to disconnect the negative terminal of the battery.
- You can safely jack up the car and remove a wheel.
Tools Needed:
- 10mm socket wrench
- 6mm socket wrench (someone mentioned it's an 8mm not a 6mm)
References:
E90 install: http://www.e90post.com/forums/showthread.php?t=1487
PDF: http://www.e90post.com/forums/attach...5&d=1171605521
1. Disconnect the negative terminal of the battery.
2. Install the motion sensor in the rear dome light (not the front light module). I found it easier to pull the module down from the front instead of at the lights.
3. Remove the two connectors (1 for the lights, 1 is plugged into nothing). Now you can snap in the motion sensor, there should be an empty space that's perfect for it. If there isn't you probably pulled off the front dome light module. Connect the connector back to the lights and now connect the other black connector to the motion sensor unit. Snap the lighting module back in place in the headliner.
Look at that carbon fiber on the right! I should have taken a closer look. Sweet.
4. Jack up the car and remove the driver's side rear wheel to install the siren. If you don't know how we'll need to link to other DIYs for this.
5. Unbolt various 10mm and 6mm bolts that are holding the wheel well lining in. There's quite of them so be sure to get all of them. There's a 6mm underneath the side skirt. I don't think I photographed all of them so double check. It will be much harder to remove the lining with any bolts still attached. You'll probably rip something if you forget. Haha.
M3 stamped in the wheel lining. Nice touch.
6. Carefully pull the lining out. Be careful not to force it out along the edges of your bumper because you could ruin it as well as the paint.
7. Now you have a bare wheel well. The siren will be installed where the red circle is.
8. First bolt the siren bracket to the 3 screws and use 3 of the 4 bolts that came with the kit.
9. Use the last bolt to fasten the siren to the big piece of rectangle plastic that comes with the kit. There should be a dangling connector for the siren and it should have a cap on it. Remove the cap and plug in the siren.
10. Use the 2 screws that came with the kit and screw the siren to the bracket. After you're done it should look like this.
11. Reassembly. Wheel well lining reinstall, wheel back on and reconnect battery. Now when you lock your car you should get a blinking red nose on your rear view mirror. Now you need to get everything programmed at the dealer.
Presto! This was one of the easier installs I've done and I think anyone with some basic skills can do this. I was amazed at all the M stamped parts in the suspension area. We even get an M stamped wheel lining. I wonder if that means they can exclude that from the list of parts that are the same as the regular 3 series. LOL. I wouldn't be surprised. Enjoy and good luck!
MDCT ... so you can drive and eat a hamburger at the same time.
      06-19-2008, 10:23 PM   #2
RealSanaii
RealSanaii's Avatar
Drives: 2008
Only seeing bunch of x boxes..
I get it now... BMW FTW!
      06-19-2008, 10:25 PM   #3
Big Windy
Big Windy's Avatar
Drives: None
he said he'll re upload tonight.
      06-20-2008, 03:11 AM   #4
MDCTFTW
Drives: E92 DCT
Looks like an admin fixed it. Whoever did that let me know if you need me to upload the pics in this thread.
EDIT: Ok looks like it's not fixed. I tried to upload them using "new thread" and then linking to the pics without creating that thread, just so I can keep these images on the forum server. Also so //Mantis can see them at work ... haha. Looks like I have to do it this way.
      06-20-2008, 04:14 AM   #5
KKSigs
M4 CSL FBG
KKSigs's Avatar
Drives: M4 CSL FBG
not fixed yet
16' M4 GTS Frozen Dark Grey Metallic
14' i8 Sophisto Grey Pure Impulse World
08' E92 M3 Jerez Black
      06-20-2008, 11:47 AM   #6
MDCTFTW
Drives: E92 DCT
Last 2 pics. Does the original post work now?
      06-20-2008, 09:52 PM   #7
Big Windy
Big Windy's Avatar
Drives: None
Thanks for the great DIY...good pics. Can't wait to do it on mine when it finally arrives.
      06-23-2008, 02:34 PM   #8
ideliver
ideliver's Avatar
238
Drives: E60 M5, E71 X6M, E46 M3
2006 BMW E46 M3 'vert  [0.00]
2008 BMW M5  [0.00]
2011 BMW E92  [0.00]
2012 BMW X6M  [0.00]
2003 E46 M3  [0.00]
Great pics!!!
Thanks for taking the time to do this
Current: 2006 E46 M3 'vert 6-sp 2008 E60 M5, 2011 E92 328 6-sp, 2011 E70 N55, 2012 E71 X6M
      06-28-2008, 04:55 AM   #9
Nucking Futs!
Nucking Futs!'s Avatar
Drives: E70 X5 M
2013 BMW X5 M  [0.00]
Very nice & thx! This will come in handy when the oem alarm arrives.
'13 E70 S63B44A
'17 95B GTS
      07-30-2008, 12:58 AM   #10
moog55
moog55's Avatar
Drives: E92 M3
great post! just wondering how many hours of labor you paid for to have them program it.
also, who has the best deal on buying the alarm kit?
      07-30-2008, 02:51 AM   #11
MDCTFTW
Drives: E92 DCT
Sadly it's not even programmed yet. Haha. I think I got it from Tischer in the low 200's.
      07-30-2008, 11:05 AM   #12
GregW / Oregon
Commander-In-Chief
2070
Drives: 2023 M2 Coupe, 2020 GLE 450
Most charge 1 hour. Circle has it for $238, I believe.
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      07-30-2008, 12:12 PM   #13
MDCTFTW
Drives: E92 DCT
Oh ya, that's where I got it from.
      07-30-2008, 12:52 PM   #14
Big Windy
Big Windy's Avatar
Drives: None
Thanks...will definitely do this.
      07-31-2008, 12:28 AM   #15
moog55
moog55's Avatar
Drives: E92 M3
cool. thx, greg.
*ordered*
      07-31-2008, 02:47 AM   #16
///M3BEAST
///M3BEAST's Avatar
Drives: -
awesome DIY. it worked on my friends car. He paid $145 to get it installed tho : (
      07-31-2008, 12:28 PM   #17
MDCTFTW
Drives: E92 DCT
Ouch, hopefully that included enabling the alarm as well. As you can see anyone that has a wrench can do it and there's not much you can screw up.
      07-31-2008, 12:45 PM   #18
GregW / Oregon
Commander-In-Chief
2070
Installation takes about an hour, plus the coding time for the dealer. On the regular 3 Series it takes a little longer because the hood switch is not preinstalled. On mine something went wrong when the coded it, and they ended up having to keep the car over night and reinstall all the software modles for the car. Pain.
      08-12-2008, 08:18 AM   #19
M3MIKE
M3MIKE's Avatar
Drives: 2008 M3 COUPE
After getting two quotes of $900from Long Beach BMW and then $700 after I bitched about price, I called Center BMW. They quoted me $600. So yesterday I picked up alarm and installed myself. Thanks to MDCTFTW for the great DIY write up. I installed alarm in under 1 hour. Very easy install. It just amazes me how a $70K BMW comes without alarm.
      08-18-2008, 03:15 PM   #20
uthatch
uthatch's Avatar
Drives: AW/FR E92
Is it OK to use the car without the alarm being coded for a couple weeks? I have the alarm and am ready to install, but I don't have an appointment to get the coding done yet.
      08-18-2008, 03:20 PM   #21
M3MIKE
M3MIKE's Avatar
I installed my alarm then had it coded 4 days later with no problems or error messages.
      08-18-2008, 03:22 PM   #22
uthatch
uthatch's Avatar
Drives: AW/FR E92
Good to hear...thanks.
m3post
