Sudden hiccups/studdering
06-12-2018, 05:58 PM | #1 |
Rep 411
E90 N55 70k miles
I have MHD installed but no map or custom tune flashed. Driving down the road at constant speed and it just started hiccuping or missing every 10 seconds or so. It does it immediately if you put a load on it. I did just fill up with 93 octane about 10min prior so i thought maybe bad gas but I do have an ethanol sensor and it says E11. I would assume if there was a bunch of water in the gas that it would read higher. The plugs are maybe 1k miles old. I could probably open the gap up a little since I'm not running a tune or ethanol at the moment but it wasn't a problem previously so I don't think that's the cause. My last guess was maybe it's time for coils? I wouldn't be surprised if they were original. I have the service records from ~35kmiles up to now and they don't appear to have ever been changed. Same with the HPFP. I took a quick log around the neighborhood hoping someone smarter than me would see something that stands out and maybe point me in a direction to start. Thanks guys. https://datazap.me/u/kevinc39/misfir...?log=0&data=11
E90 N55 RWD 6MT MHD Speedtech EFR7670 MFactory LSD
06-16-2018, 08:06 AM | #2 |
Rep 411
No codes other than Cat codes from the downpipe. Nothing popped up in the dash either. I've driven it twice since then and had no issues So who knows. Was going to just buy some coils to have on hand if it acts up again.
06-18-2018, 08:36 AM | #3 | |
Rep 255
06-19-2018, 02:48 PM | #5 |
Rep 255
I'm at 63k miles and just replaced mine. Was having having intermittent episodes of pretty sever misfiring and showing low fuel pressure. Put a new one in and it solved misfires as well as longish crank and hidden fuel pressure code.
Kevin39164.00 |
06-19-2018, 04:17 PM | #6 |
Rep 411
Awesome. Sounds like that's probably what it is.
Where is everyone buying pumps and coils these days? I also saw there were both Bosch and Delphi (I think) coils on rock auto or fcp euro. Any reason to go with one over the other? |
06-20-2018, 07:12 AM | #7 |
Rep 255
I can't speak to the best place to get coils but I got my pump from getbmwparts. I went with a slightly older model because it was less than half the price of the most recent one and seemed to perform the same. I figure if I can get another 60k miles out of it I'll be happy. Here's the link:
https://www.getbmwparts.com/oem-part...00-13517616446 Also you can return your used pump to them for around $50 back. |
Kevin39164.00 |
06-20-2018, 02:39 PM | #8 |
Rep 245
Yeah, your pump is gone. No signs of coil trouble but if you want to replace them try to find a place that sells genuine Bosch/Delphi parts. Rock Auto coils are Chinese counterfeit junk.
