Help me diagnose my long crank/cold start issue
05-31-2018, 03:16 PM | #1 |
BMW Portland
224
Rep 524
Since purchasing my car last September with 70k miles (now has 86k) I have been fighting a long crank/cold start issue with little to no progress. The long crank occurs whenever the car has been sitting 4 hours or more and the temperatures are 60 degrees F or lower. Every morning when I go to leave for work, i'll start the car and it will continue to crank until I press the button again to turn it off, and once more to restart it. Upon the second attempt it will fire up immediately. Last month I had a factory fresh N55 installed by BMW and the problem is still there, so that rules out injectors, vacuum, and a few other things.
I have run multiple fuel pressure tests and my HPFP passed with flying colors and holds pressure just fine under load. This leads me to believe that it might be the low pressure pump that might be the issue, but considering the pump primes as it should every time I unlock the car I am unsure how it would contribute to the long crank. This morning I logged a long crank in hope of getting to the bottom of this. I started logging before starting the car for the first time and it continued to crank as always. When I pressed the button again to stop it/restart it, MHD decided to stop logging. What you're seeing in the log is what the car is doing during first crank. httphttps://datazap.me/u/geirsenk/co...og=0&data=3-11 Thanks in advanced for any help!
2011 335i N55/6MT/M-Sport
MHD Stage 2+, VRSF Downpipe, VRSF 7" FMIC, BMS Intake, BMS Chargepipe, Performance Exhaust Mod, F10 550i Clutch, BMS CDV, BMW Performance SSK, M3 Control Arms, ST Coilovers, Apex ARC-8 wheels, Michelin PS4S |
05-31-2018, 03:55 PM | #2 |
Rep 3,189
Took over a year for my hpfp to throw a code while I had long cranks. All pressure tests were fine as well. Replaced the HPFP and no more long cranks.
05-31-2018, 04:48 PM | #3 | |
BMW Portland
224
Rep 524
I just showed the log to an experienced tech at my dealership and he mentioned that the LPFP could be slowly dying and not providing enough pressure to fully prime the system all the way up to the HPFP. I'm going to get a fuel pressure gauge on the car right before the HPFP and try to get some readings in the next couple of days. If that's not the case i'll just bite the bullet and replace the HPFP.
05-31-2018, 08:30 PM | #4 | |
Rep 3,189
06-01-2018, 07:43 AM | #5 |
Rep 255
SnapCoupe I was having semi-long cranks since I bought my car in September 2017 with 54k miles. Once it fired up the car would run fine until very recently. I took some logs at idle and WOT to compare rail pressure. The pressure at WOT was fine at ~2200psi. However at idle my pressure was ~80psi which is very low. I replaced my HPFP on Wednesday and the car has been starting, idling, and running much better. No more long crank and plenty of pressure at idle. Hope this helps.
06-01-2018, 09:38 AM | #6 |
Rep 2,014
It could be your starter. My car had the same symptoms and one day the starter died without throwing prior codes.
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
06-02-2018, 12:07 PM | #8 | |
BMW Portland
224
Rep 524
I agree. I think i'm going to replace the pump soon to see if it improves.
