F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > Transfer case VTG Error
Studio RSR
      04-10-2018, 03:10 PM   #1
cwayz
Drives: F30
Can anyone help?
I have a permanent DSC error light on my car and after I clear the fault codes after a short drive after I turn the car off the error comes back.
I have tried re calibrating the VTG unit (currently about 60 degrees) and replacing VTG within ISTA, is my transfer case knackered?
440101 Transfer box (VTG) End of transmission service life reached
440115 Transfer box (VTG) calibration angle deviation outside tolerance
48097D Transfer box Fault clutch position known no four wheel drive
      08-30-2018, 06:14 PM   #2
arsh540
Drives: 2013 328i Xdrive
hey- take it to BMW ... check is out
https://testing-public.carmd.com/Tsb...0B27%2003%2015
hope it helps
      08-30-2018, 07:39 PM   #3
Enabled
Drives: 328xd Wagon, M2 Competition
Thank you for that document.
It proves my thought that BMW may have installed wrong differential ratios. It may explain why people with multiple transfer case failures have them often... While others don't have failures at all.
It's wise to check front and rear diffs.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp
-2016 Mini Cooper S, MT. Many plans.
Others:
-E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe.
      08-30-2018, 07:41 PM   #4
Enabled
Originally Posted by cwayz View Post
Can anyone help?
How many miles on the car? This is what a fully worn transfer case clutch pack would show.
Others:
      09-12-2018, 08:06 AM   #5
arsh540
My transfer case is getting replaced this week but i will as the dealer to check the gear ratio on the differentials... if they dont match they will also need to be changed right as per the document right ? not sure how that will work though as the car is out of warranty....
      11-21-2018, 02:23 PM   #6
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
Sorry, but replacing diffs is fairly labor intensive...how in the world are the wrong ratios getting installed?
      11-21-2018, 03:24 PM   #7
Enabled
Multiple assembly locations, for whichever market the car is meant for. I guess someone makes a simple computer database mistake and cars go through automated assembly.
Others:
      11-21-2018, 04:57 PM   #8
kdog_x
Drives: 14 328d
Have any forum members actually found that they had the wrong differential pair installed? I'm definitely planning to look at them the next time I get a chance seing as I am on transfer case #3, but I'm sure all of the plastic covers and probably the big metal one under the engine will need to be removed to get a look at it. This is definitely a PITA to do on a garage floor. Wish I had known to look when I had it apart!
      11-22-2018, 11:42 AM   #9
Enabled
Probably very few, or even none? No one, not even BMW seems to be doing much investigation as to what is going on, but rather just swapping transfer cases like they are consumables.
Did you know that the front diff is a fully locked differential? All the slip/wheel speed differential between left and right wheel, is all done through the front driveshaft and transfer case. If the clutches clamp too tightly on big turns, the stress goes on to the next weakest thing.
It may even be worth looking at software fixes by BMW.
Others:
      02-20-2019, 06:26 PM   #10
Crz13
Drives: F32 435d M Sport xDrive
Can anyone help?
Hi, do you mind sharing the end result?
I have the exact same codes (apart from 2nd calibration code) on my 435d xdrive
Would very much appreciate your feedback.
Many thanks
f30post
