03-28-2018, 10:09 AM | #1 |
Rep 245
If you had the new M2 Competition, will you put a tune on it?
Coming from the F30 to my F87, I was thinking that the F87 would have plenty of power and that I wouldn't need to mod it much. Maybe just cosmetic mods...but after browsing the forum and seeing what's available, I just pulled the trigger on the Hex tune and a Fabspeed DP.
This got me thinking...if I were actually getting the new M2 Comp, would I put another tune on it just because I can? My initial thoughts are no, there's no need...but I think when the tunes come out and I see that there's not much more cost to add a significant amount of power (obviously, not really needed), I think I would still pull the trigger once again to add more power just because I can, but not because it's necessary. What's wrong with me? lol So what about you guys? Are you guys just as messed up as me? |
03-28-2018, 10:23 AM | #3 |
Rep 245
03-28-2018, 11:47 AM | #4 |
Rep 3,659
Drives: 981 Cayman GTS
Nothing crazy since I'll track it but planning on getting a M4 CS or GTS flash tune.
just blaze310.00 |
03-28-2018, 11:58 AM | #6 |
Rep 4,551
Drives: 2015 328d xDrive
If I had an S55 I would 100% BM3 the shit out of it. The S55 platform is WAYYYY more tunable than the N55. S55 will break the 500 barrier with DP and Tune while the N55 will struggle to break 400 with the same mods. Current M2 just isn't really as good of a tuning platform. N54/B58/S55 are much better in that aspect.
03-28-2018, 12:12 PM | #7 |
enthusiasm > practicality
4021
Rep 2,247
Drives: 987 CS | G35x
^Exactly. The S55 is very modifiable. No way I'd keep it stock. That'd be the only reason why I would trade up.
FSI 3.8L Stg II|6MT|SOUL|IPD+GT3 TB|Numeric Racing|KW|Tarett|Rennline|Raceseng|APEX|Recaro|7.3 lb/hp
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp Left lane campers, GTFO! Last edited by No Boost; 03-28-2018 at 01:56 PM.. |
AndrewC198910931.00 NYC Bimmer259.50 |
03-28-2018, 12:27 PM | #8 |
Rep 763
I'm sure the car will be properly quick out of the box. That will keep me entertained... until it doesn't and I get the itch for moarr powaaa . Then the mods start incrementally, first tune (especially with the ease of OBD flashing), then DP, brakes, wheels/tires, and supporting mods. Makes long term ownership more appealing when you can make improvements over time.
03-28-2018, 02:37 PM | #10 |
Rep 207
There's no point getting the S55 M2 if you don't tune it. No way would I put up with the extra cost and its drawbacks for measly 40hp over the N55. I am actually not getting an S55 M2 but just speaking hypothetically...
Gone but not forgotten:
'14 Corvette Stingray (2014-2017) '05 Boxster S (2005 - 2014) '00 S2000 (2000-2005) |
alscks0414690.00 |
03-28-2018, 02:51 PM | #11 |
Rep 3,659
I believe 40hp difference will be only on paper. BMW usually underrates their engines and their claimed HP is usually the HP at the wheels. I keep saying "usually' because for instance this wasn't the case with the M2. A completely stock M2 dynoes around ~330whp at best depending on various factors. However, if you look at the examples of S55, a fully stock M4 ZCP can make ~440-450whp or a Non-ZCP ~420whp. What I'm getting at is the HP difference between the N55 M2 and the S55 M2 might be more than just 40hp in real life. In any case, as others mentioned, S55 has a huge tuning potential and you can reach near 550whp pretty easily.
dmboone254972.00 |
03-28-2018, 02:59 PM | #12 | |
Rep 6,635
Also I suspect it's going to be quite a bit more than 40 hp, it will only be 40 hp on paper but more in reality when actually tested on a dyno. Higher redline and pulls all the way to 7500 probably as well. |
dmboone254972.00 |
03-28-2018, 03:17 PM | #13 | |
Rep 3,622
Only argument I see constantly is sound, which is completely subjective. N55 is a run of mill BMW engine, nothing special about it. In fact I'd rate the N54 over the N55. |
03-28-2018, 08:45 PM | #14 | ||
Rep 207
1. Weight - speculating 70 lbs heavier but you can come up with your own number 2. Turbo lag - well documented and to be expected when there are only 3 cylinders boosting each turbo 3. Sound - one can say the flat 4 sound in Subie and 781 is subjective, too. Or just call a spade a spade To be perfectly frank I would not trade N55 for S55 for even money, but hey, it's subjective
03-28-2018, 08:57 PM | #15 | |
Rep 7,594
Drives: '19 M2C
qnet681.50 Spartan King79.50 |
03-28-2018, 09:58 PM | #17 | |
Rep 10,200
Drives: 2024 Golf R / 2022 718 Spyder
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
Who?484.50 |
03-28-2018, 11:02 PM | #18 |
Rep 3,622
The N55 in M2, is a N55 with some forged internals and higher boost. It is definitely not closer to the S55. They don’t even share the same block, the foundation of the engine.
03-28-2018, 11:26 PM | #19 | ||
Rep 207
That's me being logical on something that is irrational lol
dmboone254972.00 |
03-28-2018, 11:51 PM | #20 |
Rep 444
Drives: 2017 M2 6MT, 2022 X7 M50i
No, I would invest the money to improve driving skills. HPDE ftw.
03-28-2018, 11:53 PM | #21 |
Rep 2,829
Drives: E36M,E46M,E90M,X5M,i3,M2,i8
Hex tune and downpipe done deal ///
BMW I12 i8 Frozen Yellow- H&R springs, 22" Radenergie F10 Monoblock Forged /// F87 M2 Aw -Vorsteiner Aero Kit, VFF-107,Macht Schnell-Springs,VF-Engineering/Hex tuning Stage Two,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe/// Wish list :Mexico delivery 2024 BMW M2 (G87) |
///cbrash226.50 |
03-29-2018, 01:23 AM | #22 | |
Rep 2,577
M4 base and M2 whp difference is 50-60whp, not more as many think. Detuned S55 with M2 Comp probably has 10whp less, that's around 45whp more over N55 M2, stock for stock. As for tuning potential, on stock turbo and pump gas, breaking 500 with S55 is just as hard as breaking 400 with M2 N55. S55 also has a ugly top end when you push that hard. Lastly, M2 N55 has just a bit more power potential than N54, given stock turbo. Come on guys, fit a PS2 to match S55. Above 450whp I doubt you'd even care 10 or 20 more or less.
Lemania 2320
